Re: Anybody running an Reilly Street Lynx rear suspension? [Re: B5 Bee] #1755958
02/18/15 11:55 PM
02/18/15 11:55 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
If spherical rod ends were used on a triangulated 4-link instead of bushings, wouldn't that eliminate binding during extreme body roll?
Even a 3 or 4 link with a Wishbone or Watts linkage would bind if the 3-4 links had bushings instead of rod ends.
Assuming we are talking about "handling" and not drag racing, in roll, spherical bearings would increase bind, leading to "snap oversteer", when the spring rate rises extremely fast as system binds. The fact the fox body is a tin can, it works until it rips apart, and the reason there must be some compliance in the design, dual durometer bushings, flexible upper arms in twist, etc. The arms are all? swinging thru different competing arcs, causing the bind.
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: AndyF] #1755959
02/19/15 01:02 AM
02/19/15 01:02 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
They sell a lot of those suspension kits. I know since I make one of the parts that goes into the kit. There doesn't seem to be a lot of Moparts members who run that kit but that doesn't mean that there aren't a lot of kits sold.
Now I have to crawl under my car and figure out which is the part that you make....thanks!
A new iron curtain drawn across the 49th parallel
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: 67autocross] #1755960
02/19/15 01:28 AM
02/19/15 01:28 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I have the OP's RMS supplied rear link system on my 70 GTX. I have only driven it 70 miles and decided to rewire it(another story) I liked the ride. I did NOT build the car to race so that level of performance is beyond what I am knowledgeable enough to comment. I like the idea of the independent shocks and the adjust ability of stiffness and ride ht, you don't get that with a stock leaf spring suspension.
Here is a pic and a few to follow
Driving modern convenience in classic beauty
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: Darius] #1755961
02/19/15 01:29 AM
02/19/15 01:29 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
another
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: Darius] #1755962
02/19/15 01:31 AM
02/19/15 01:31 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
one more
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: Darius] #1755963
02/19/15 01:33 AM
02/19/15 01:33 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Finished install
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: Darius] #1755964
02/19/15 01:37 AM
02/19/15 01:37 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
nuther
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: Darius] #1755965
02/19/15 01:59 AM
02/19/15 01:59 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That is not true. You can adjust the stock leaf's stiffness and ride height. It's not as obvious as a coil over setup, nor as complicated as one either. BTW, collapsing a coil spring doesn't change it's rate unless it's a variable rate coil, in which case you just defeated the variable part.
Don't be the exception.
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: Supercuda] #1755966
02/19/15 02:20 AM
02/19/15 02:20 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
It is nice that with the coil overs you can change the ride height of the car a couple of inches in a few minutes as well as change the stiffness, for a daily driver it's great to be able to change it quickly.
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: Supercuda] #1755967
02/19/15 10:54 AM
02/19/15 10:54 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
How is turning a knob (valve) or turning the ht adjustment screw on a QA-1 MORE complicated than anything you would have to do with leaf springs?
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: Darius] #1755968
02/19/15 10:44 PM
02/19/15 10:44 PM
Oklahoma City OK
Cudajon Offline OP
Cudajon  Offline OP
Oklahoma City OK
I'm loving this thread, I've been waffling between backhalving and just leaving it pretty much stock and everything in between. I like to race the car every once in a while but its never gonna be a "race car". I really need to shorten the rear end to get more rubber under it and I was thinking at the same time changing the suspension. I have the kit to move the springs in but when I do that I want to mini tub it. So much to do, so little time.
Re: Anybody running an Reilly Street Lynx rear suspension? [Re: B5 Bee] #1755969
02/20/15 12:37 AM
02/20/15 12:37 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
If you are wearing asbestos underwear, this link may be entertaining in regards to your comment. You have been warned.
http://corner-carvers.com/forums/showthread.php?t=43991
