need help asap please.car olny sparks when turn key off #175565
12/26/08 07:57 PM
12/26/08 07:57 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
buddy has a 71 charger that ran fine with the factory points (small block) then one day his wife drove it to work and came out ..nothen so brung it home thinking the points burnt up so now is good time to upgrade to eletronic. so bought a conversion droped it in still no start so bought a new coil still no start
got a couple of differnt digrams and evert thing is hooked up right but the only time it will spark is when you turn the key off and its just a one time spark till next time turn it off
have a 73 car that runs fine and checked the power to both sides of the coil both with key in run and start and the exact as the one that wont run so what the heck is the deal box is grounded even swaped the box off the running car still nothen why is it only getting a spark from the coil when turn the key off thanks in advance guys
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: need help asap please.car olny sparks when turn key off [Re: toplescuda] #175566
12/26/08 08:03 PM
12/26/08 08:03 PM
Andrewh Offline
Andrewh  Offline
Little jumbled.
Let me get this straight.
The car has no spark when cranking.
You replaced everything but the ballast resistor.
You now have electronic ignition.
You see a spark when you turn the key off, but at no other time.
You get voltage to the coil in run and start.
What voltage do you get?
12 volts in both places?
Bad ballast, but the car should start and die when you let go of the key.
Re: need help asap please.car olny sparks when turn key off [Re: toplescuda] #175567
12/26/08 08:03 PM
12/26/08 08:03 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
maybe ballast resistor or ignition switch. will it fire if you jump the starter relay?
Re: need help asap please.car olny sparks when turn key off [Re: JeffC] #175568
12/26/08 08:12 PM
12/26/08 08:12 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
car cranks over fine and the ballist is good it just dont spark from any time you turn the key on(even cranking) till you turn the key to the off postion then it has one nice spark
1971 charger
Re: need help asap please.car olny sparks when turn key off [Re: toplescuda] #175569
12/26/08 08:18 PM
12/26/08 08:18 PM
Andrewh Offline
Andrewh  Offline
eliminate the key and hot wire it.
Put a 12 volt positive to the coil and hit the relay so it turns over and see if it starts.
Nothing else in the circuit really.
Re: need help asap please.car olny sparks when turn key off [Re: Andrewh] #175570
12/26/08 08:24 PM
12/26/08 08:24 PM
New York City
groundpoint6 Offline
New York City
Sounds like a bad distributor pick up coil
Re: need help asap please.car olny sparks when turn key off [Re: groundpoint6] #175571
12/26/08 09:02 PM
12/26/08 09:02 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
The box is gone !! Sorry reread your first post , As the above poster said , looks like the pick up coil in the dist is not working or the gap is too wide to trip the ECM which in turn unloads the coil
Re: need help asap please.car olny sparks when turn key [Re: mopar_man] #175572
12/26/08 09:37 PM
12/26/08 09:37 PM
Taylor MI
spl151 Offline
spl151  Offline
Taylor MI
Yep thats the problem had it happen to me!
Re: need help asap please.car olny sparks when turn key off [Re: toplescuda] #175573
12/26/08 09:59 PM
12/26/08 09:59 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Check to see if the coil wire is not seated properly on coil or distributor (audible click).
If that's not the fix, check connections to the starter relay - those wires from the Neutral Safety Switch and ignition switch (yellow wire) aren't too weather-tight.
Re: need help asap please.car olny sparks when turn key off [Re: IronWolf] #175574
12/26/08 10:16 PM
12/26/08 10:16 PM
set the reluctor gap to .008". key on coil wire 1/4" from ground & jump coil neg to ground & make & break it. if the 73 is a SB borrow it's dist
Re: need help asap please.car olny sparks when turn key off [Re: toplescuda] #175575
12/26/08 10:23 PM
12/26/08 10:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You most likely could be fighting the original problem. The car did not run with points so maybe the problem is in the ignition switch or wiring. It may not have anything to do with the conversion.
Re: need help asap please.car olny sparks when turn key off [Re: NITROUSN] #175576
12/26/08 10:27 PM
12/26/08 10:27 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
bad idea to assume the points were bad and do a conversion without confirming the original problem, because now you don't really know what the original problem was...
start there, and good luck!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: need help asap please.car olny sparks when turn key off [Re: AdventurerSport] #175577
12/26/08 10:54 PM
12/26/08 10:54 PM
New York City
New York City
Dist pick up coils are a/c generators. Set your DVOM to an A/C voltage low scale and hook the leads up to the pick up coil. Crank the engine, if you get any reading at all the pick up coil is good, if not change it
Re: need help asap please.car olny sparks when turn key off [Re: toplescuda] #175578
12/26/08 10:55 PM
12/26/08 10:55 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
I had this problem when I converted to electronic ignition. In my case, I wired the ballast reistor wrong. Mine was trying to start with the resistor in the cicuit, the starter was drawing enough power to prevent the ignition from getting enough power to ignite. It turned out that I had the bypass for starting on the wrong side of the resister. Just a thought.
Re: need help asap please.car olny sparks when turn key off [Re: JonC] #175579
12/26/08 11:21 PM
12/26/08 11:21 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I had the exact same symptoms when my brand-new ECU box died...stupid Mopar Orange ECU!! You would get no spark when you cranked the motor until you turned the key back then one nice spark...
Other than that check the grounds on your ECU and voltage regulator with a continuity meter...
Re: need help asap please.car olny sparks when turn key off [Re: Andrewh] #175580
12/27/08 12:14 AM
12/27/08 12:14 AM
pana illinois
bigblock4x4 Offline
bigblock4x4  Offline
pana illinois
the ignition box was bad on my truck,it did the same thing bought msd
Re: need help asap please.car olny sparks when turn key off [Re: bigblock4x4] #175581
12/27/08 02:11 AM
12/27/08 02:11 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
My add to this problem is that I had a bad wire in the ignition harness where it plugged in to the the switch.
Another possible problem is a bad connector in the firewall bulkhead connector for the ignition run switch.
Also the ignition switch itself could be bad.
Re: need help asap please.car olny sparks when turn key off [Re: sthemi] #175582
12/27/08 10:04 AM
12/27/08 10:04 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
i agree- the orginal problem- as you turn off the ing. key there is enough connection to give spark!
Re: need help asap please.car olny sparks when turn key off [Re: 71_deputy] #175583
12/27/08 11:42 AM
12/27/08 11:42 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Get your test light or VOM out and start doing some diagnosing. Check to see if you have power to the +coil terminal with the key in the runpostion. if you do then jump the starter relay on the fender to crank the engine and see if it starts. If it does then you need to see if you have power to the coil while holding the key in the start position. If you have power there then it's not an ignition or bulkhead wiring problem.
