Re: Sliders,,,,,,,,,,,,,,,,,,again
[Re: hemi-itis]
#1755022
02/16/15 09:49 PM
02/16/15 09:49 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I'd bet the speedway part is a reboxed afco
I would bet your wrong as the salesman at speedway that I bought my Afco's from said the speedway were China manufactured. I would bet they reversed engineered the part from a quality American piece. Sorry I try to support American manufactures when I can, they are getting scarce nowadays.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: TurboMike]
#1755023
02/16/15 09:52 PM
02/16/15 09:52 PM
1967dartgt
Hilltown Pa
Question, are these considered race only, or do they work for a street car? I heard they are noisy.
Can't hear them over my exhaust on the street in my car.
[Re: 1967dartgt]
#1755024
02/17/15 01:56 AM
02/17/15 01:56 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Are you sure about that?????I would buy the Afco's if the speedway part was Chinese
[Re: hemi-itis]
#1755025
02/17/15 09:32 PM
02/17/15 09:32 PM
Posts: 9,873 MI, usa
dvw
MI, usa
Here's a pic of what we did on Dizusters 62 Savoy. Depending on which rate spring was on it made a difference in how far the eye bolt traveled in the slider slot. The best advise is to make sure the eye bolt will not contact the front off the slot. With the axle hanging loose allow at least 1/2" forward for additional spring flex. Doug
[Re: dvw]
#1755026
02/17/15 09:33 PM
02/17/15 09:33 PM
dvw
MI, usa
Slider mounted on the plate
[Re: dvw]
#1755027
02/18/15 02:49 AM
02/18/15 02:49 AM
hemi-itis
Can any one say for certain the sreedway part is a reboxed Afaco??
[Re: hemi-itis]
#1755028
02/18/15 12:11 PM
02/18/15 12:11 PM
hemi-itis
Sounds like no one is a jobber for them So just buy from speedway,or can I support a vender here on MOPARTS??
[Re: hemi-itis]
#1755029
02/18/15 01:05 PM
02/18/15 01:05 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
1st one's I seen where 20+ years ago and were an AFCO part. They were used on dirt cars for better lateral stability than shackles. Some were installed on the bottom of a threaded rod similar to a weight jack which made them also adjustable in height like a shackle. Dunno who copied who...
...FAFO...
[Re: hemi-itis]
#1755030
02/18/15 01:13 PM
02/18/15 01:13 PM
Posts: 179 Norfolk, NE
Racer33
Norfolk, NE
A few years ago Speedway bought Afco.
[Re: Racer33]
#1755031
02/19/15 01:45 AM
02/19/15 01:45 AM
hemi-itis
I found that out today when I called speedway today.I was told the Afco was better quality,which leads me to believe that we have an off shore knockouff.
[Re: hemi-itis]
#1755032
02/19/15 06:40 PM
02/19/15 06:40 PM
hemi-itis
Speedway version is Chinese at half the price.Just ordered them from Jegs
[Re: hemi-itis]
#1755033
03/04/15 11:09 AM
03/04/15 11:09 AM
hemi-itis
I received the Afco sliders at twice the price as the speedways.The fit in the spring eye is NOT very tight What am I missing????
[Re: hemi-itis]
#1755034
03/04/15 11:56 AM
03/04/15 11:56 AM
Posts: 369 Indy
496 A-body
Indy
Are they Calvert springs? I had the same problem, both of the supplied aluminum bushings were very sloppy in the spring eye so I made new bushings.
[Re: 496 A-body]
#1755035
03/04/15 01:48 PM
03/04/15 01:48 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Same issue here, new Calvert springs but cheaper Speedway sliders. Bushing measures .950 not the 1 inch it should be. This confirms that the Afco and Speedway are probably the same piece. Dont bash, just a guess. I plan on making new bushings as well that are a true 1 inch to fit nice in the spring eye.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: hemi-itis]
#1755036
03/04/15 01:49 PM
03/04/15 01:49 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Mock it up on the spring,tight.
[Re: Clanton]
#1755037
03/04/15 02:42 PM
03/04/15 02:42 PM
1967dartgt
Hilltown Pa
Calvert has the right bushings for your springs, call them. If I was thinking I would have said order sliders from them as they have them with the right bushings for mopars.
[Re: 1967dartgt]
#1755038
03/04/15 04:23 PM
03/04/15 04:23 PM
Posts: 861 lancaster,california
johnnycuda
We (Calvert) also have a set of sliders, that are made to fit our Split Mono springs, they are slightly different than the AFCO's/Speedways, the slot in ours is pointed downward towards the front to help the suspension even moreso. They are priced at $189 a set plus shipping.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: hemi-itis]
#1755039
03/04/15 09:11 PM
03/04/15 09:11 PM
dvw
MI, usa
Exactly like the speedway parts. Though we didn't make new spring bushings they seem to work well. New bushings are on the list. Doug
[Re: dvw]
#1755040
03/04/15 11:47 PM
03/04/15 11:47 PM
1967dartgt
Hilltown Pa
So we have come to the conclusion that when they reverse engineered the Afco slider in China they copied the size of the bushing too.
[Re: 1967dartgt]
#1755041
03/05/15 12:19 AM
03/05/15 12:19 AM
hemi-itis
How did you guys know out his and say anything
