Bellhousing #1754555
02/14/15 07:37 PM
02/14/15 07:37 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
How can a bellhousing be off centre by 1/16" or more ? Have get one of those dials meters, and get this figured out. , pain
Re: Bellhousing [Re: 300_dup5] #1754556
02/14/15 07:46 PM
02/14/15 07:46 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Have you checked w dial indicator or are you guessing?
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Bellhousing [Re: Dan Brewer] #1754557
02/14/15 07:56 PM
02/14/15 07:56 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
I have to get a dial indicator, just a measurement with measure
Had new clutch in, new bell on
Tried to fit 833 in, no way. Stopped about 1/4" from going in
It did start into new pilot bushing
Took it all apart ( after using one of those plastic tools
Got a steel input shaft, and this is where I'm at
Re: Bellhousing [Re: 300_dup5] #1754558
02/14/15 08:13 PM
02/14/15 08:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Wonder why you think the bellhousing is off.
More likely you do not have the clutch disc centered up.
I usually install the clutch, PP and bellhousing with the clutch fork and whatnot all set up, slide the trans in as far as it will go and if it will not completely go in have someone step on the clutch pedal and it'll release the pressure plate allowing the disc to center up.
Don't be the exception.
Re: Bellhousing [Re: 300_dup5] #1754559
02/14/15 08:33 PM
02/14/15 08:33 PM
The final 1/4 inch of travel is usually the front bearing retainer lip not entering into the bellhousing correctly Let us know what you find out, maybe you have the large bearing retainer and the small hole bellhousing Good luck BTW, one of the easest fixes on that deal is to have the bearing retainer O.D. turn down to the proper size, unless you have a 18 spline NP 833 instead of the 23 spline tranny
Re: Bellhousing [Re: 300_dup5] #1754560
02/14/15 08:39 PM
02/14/15 08:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
So the this particular engine always has a 4-speed bolted to it right? Is this bellhousing the only new part in the equation? Does the input bearing retainer fit the bellhousing?
I have a special tool that another member here made from my drawings and it works much better than a magnetic base on the crank. I have a pic of it on my laptop I can post later
Gus
64 Plymouth Savoy
Dana 60
Re: Bellhousing [Re: fourgearsavoy] #1754561
02/14/15 09:43 PM
02/14/15 09:43 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
New bell, new clutch new everything, Engine was not 4 speed before
I had everything bolted up, went to slide trans in and input shaft retainer on new trans actually was hitting side of bell hole, not allowing it to go any further.
Took bell off, clutch out, got a steel input shaft off another 833 , slide in perfect into crank and pilot sleeve
Put bell back on ( no clutch) and tried again , goes in fine ( the steel 833 input shaft does not have retainer on end)
Just doing some rough measurments from shaft to bell on both sides , shows its off about 1/16". Whatever that maybe in thousandths
If I hold shaft over to one side it's much better, but you can feel the resistance when turned
Got to get a dial indicator
I slide my finger down left side, down right side a little resistance
??? Maybe a good shot on right side of pinion shaft would straighten it ( just kidding
Re: Bellhousing [Re: 300_dup5] #1754562
02/14/15 09:56 PM
02/14/15 09:56 PM
IN
ahy Offline
ahy  Offline
IN
Sounds like it would be a good idea to get the dial indicator set up to indicate on the transmission mounting bore on the bell housing.
The factory dialed in the bell with the particular block... mixing and matching parts later can get you off quite a bit. Worst are some steel bells.
I do it by mounting strip steel on the flywheel or crank flange and bend cold to get the dial indicator in the right spot. Offset dowels as needed to get it dialed in. <.003" preferred, .005" max runnout.
Re: Bellhousing [Re: 300_dup5] #1754563
02/14/15 10:01 PM
02/14/15 10:01 PM
Rittman Ohio
Rittman Ohio
So the transmission bolts right in without the clutch Well you should check it anyway so if it's off that far it won't be easy to fix.
Here's a pic of my alignment tool.
What kind of bellhousing is it?
Gus
64 Plymouth Savoy
Dana 60
Re: Bellhousing [Re: fourgearsavoy] #1754564
02/14/15 10:09 PM
02/14/15 10:09 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Trans doesn't bolt up, spare trans spline ( without retainer on it) does
Got it from Mancini. Aluminum, No clutch in it at this time
Re: Bellhousing [Re: 300_dup5] #1754565
02/14/15 10:16 PM
02/14/15 10:16 PM
Rittman Ohio
Rittman Ohio
If it won't even bolt up without the clutch then something is off further than I've ever seen before. So the tranny bolts up to the bell when it's not attached to the engine right? And the crank is drilled deep enough to accept the input pilot.
Gus
64 Plymouth Savoy
Dana 60
Re: Bellhousing [Re: fourgearsavoy] #1754566
02/14/15 10:51 PM
02/14/15 10:51 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Yes Trans bolts up to bell when off motor
Crank is deep enough. Checked those
Pilot bushing is good. ?
Re: Bellhousing [Re: 300_dup5] #1754567
02/14/15 11:03 PM
02/14/15 11:03 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Have you bolted bell and trans to engine w no clutch?
Re: Bellhousing [Re: 300_dup5] #1754568
02/14/15 11:04 PM
02/14/15 11:04 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
if it fits in without the clutch--then i would look at the clutch---does it slide easily onto the input?
Re: Bellhousing [Re: savoy64] #1754569
02/15/15 12:07 AM
02/15/15 12:07 AM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Have not tried trans to bell with no clutch yet ?
Re: Bellhousing [Re: 300_dup5] #1754570
02/15/15 12:11 AM
02/15/15 12:11 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
And even if it fits you need to check bellhousing allignment w an indicator.
Re: Bellhousing [Re: Dan Brewer] #1754571
02/15/15 12:29 AM
02/15/15 12:29 AM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Thanks, I got one ( have not tried it yet). Got to figure out how to use it.
It's got the dial attached to a flex line/ hose , with a set of vies grips in the case,
Got it from a friend, he had it awhile, but doesn't know a thing about it
I'll goggle it
Re: Bellhousing [Re: 300_dup5] #1754572
02/15/15 01:35 AM
02/15/15 01:35 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
You say that the engine was not a 4 speed before, was the crank drilled for a stick input shaft? You say it slides into the pilot sleeve , is that a standard replacement bushing and installed all the way in? What do you mean { the steel 833 does not have a retainer on the end] ? There are offset dowels available to dial in the bell housing if you need to. Robbmc performance sells what you need.
Re: Bellhousing [Re: rowin4] #1754573
02/15/15 02:13 AM
02/15/15 02:13 AM
rowin4 Offline
rowin4  Offline
With the bell housing back on with no pressure plate installed, I use a magnetic based dial indicator to zero in the bell housing. The magnetic base is stuck on between the [ clean ] flywheel bolts , the indicator is setup to run on the large surface hole of the bell housing that the transmission bearing retainer fits in. I mark the harmonic balancer every 45 degrees . Turn the crankshaft from the front crank bolt. Take a reading , write it down at each 45 degrees till you complete a full rotation. This will tell you whether your bell housing is good to go or not. I think .010 total indicator run out is acceptable. Google that for proper info. If it is out contact Robbmc for the proper Mopar offset dowels.
Re: Bellhousing [Re: rowin4] #1754574
02/15/15 08:42 AM
02/15/15 08:42 AM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Yes, crank was drilled, brass sleeve is in, the input shaft that I'm using does not have the 4".3 retainer on the end, so it hard to tell how far off it is
The brass sleeve is flush with face of crank, shaft does slide into and to end of crank
So that's all good
Will try the trans again, without clutch, but by looking at it, retainer on input shaft will hit the one side again on bell
Will get it sorted out when I dial it in
