4 speed drivers...what's your favorite clutch?
#175421
12/26/08 05:30 PM
12/26/08 05:30 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
I'm doing a four speed conversion on my 340 Dart Sport. The last thing I need for the swap is the clutch assembly. I'm trying to decide between a Zoom and a Ram set up. Both are priced about the same ($345+-). What are some opinions about each make?
Thanks.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
Re: 4 speed drivers...what's your favorite clutch?
[Re: 340727dart]
#175422
12/26/08 05:55 PM
12/26/08 05:55 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
I had a zoom,,, the same one you had just listed a minute ago,,, and genaded it the first time out within the first mile. Absolute nightmare. I went to a centerforce dual friction.. so far so good but only 160 miles on it.
Chris from New Jersey
[Re: 68CoronetRT]
#175424
12/26/08 06:30 PM
12/26/08 06:30 PM
340727dart
Arkansas
It's a street car only, but I put only about 1500 miles a year on it. I've never had it on a dyno but, Desktop Dyno says my combination should have about 415 horsepower and 430 ft lbs of torque. It's got 3.91 rear gears. The clutch set up will be bolted to the RAM steel billet flywheel I got for Christmas.
[Re: dart440]
#175428
12/26/08 09:14 PM
12/26/08 09:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Ran a Sachs clutch in my Diplomat for about 50k miles.
Never an issue, even taught my daughter to drive in that car.
[Re: 340727dart]
#175429
12/26/08 10:14 PM
12/26/08 10:14 PM
Posts: 5,270 Missouri
MY340
Missouri
Nobody likes Hays anymore? I had one in my Duster for 8+ years with no problems. I believe it was the street/strip version.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: 5spdcuda]
#175433
12/27/08 10:47 AM
12/27/08 10:47 AM
Posts: 2,172 Ohio
theclutcher
Ohio
had good luck as others did with your std B&B clutch with an organic disc. Hays worked for me, run one of thier slippers now modded by Tim Hyatt go to umtrdragrace.com
[Re: Clair_Davis]
#175436
12/27/08 11:38 AM
12/27/08 11:38 AM
MY340
Missouri
Ted, Due to your advanced years you might want to inquire about the amount of pedal pressure/force to engage the clutch on each brand. My Hays clutch setup was fairly stiff when compared to a standard clutch. Just looking after the well being of your left leg and knee here.
[Re: 340727dart]
#175437
12/27/08 12:28 PM
12/27/08 12:28 PM
Posts: 197 SB
Duster426
SB
[Re: Rhinodart]
#175438
12/27/08 01:42 PM
12/27/08 01:42 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Use anything BUT a diaphram (Chivvy) type clutch, go with the original borg and beck style. I have used Ram, Zoom, and Hayes for the last 30 years and I usually go back to Hays. I have a friend who rebuilds the pressure plates for me so I don't have to buy them anymore.
Is there any reason to go with the Borg and Beck style over the diaphram type or is that just personal preference? I dont know which is best for what reasons so I am just asking.
I am building a 512 RB engine that will hopefully put out 550 to 600HP and alot of torque. Which style would be better?
[Re: Blakcharger440]
#175439
12/27/08 03:18 PM
12/27/08 03:18 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
The diaphram clutches were notorius for sticking to the floor when shifting at high RPM, causing a missed shift and possible engine damage. They have improved since the old days but, why take a chance. I bought a Ram set up for my road Runner. They had good tech support and average prices.
[Re: sthemi]
#175440
12/27/08 03:52 PM
12/27/08 03:52 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I think a Mcleod B&B plate with a street/strip rag disc should do the trick. Jamie Passon will set you up with a good Mcleod clutch at a fair price. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#175444
12/27/08 07:20 PM
12/27/08 07:20 PM
Posts: 4,285 Ohio
64dodge572
Ohio
We stock Centerforce, Mcleod & Hays,give us a call!
Thanks, Wayne
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: ThermoQuad]
#175450
12/28/08 11:18 AM
12/28/08 11:18 AM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
You still can't beat this set up for the money and performance. Handles 400 rwhp with ease Rochester Clutch and Brake 585-232-3717
That looks a lot like Ram's sintered bronze 6000 series disc.
[Re: Duster426]
#175452
12/28/08 02:20 PM
12/28/08 02:20 PM
Posts: 15,315 Omaha Ne
TJP
Omaha Ne
CENTERFORCE dual friction for my Duster
We have installed a butt load of centerforce dual frictions with ZERO issues.
[Re: fourgearsavoy]
#175454
12/29/08 01:50 AM
12/29/08 01:50 AM
Posts: 5,439 So Cal
Sinitro
So Cal
Just a couple of comments.. a. Make sure you have the proper Z-bar so the fork push rod runs parallel to the bellhousing b. Add a torque strap, a big help for keeping the Z-bar and nylon bearings together
[Re: 340727dart]
#175456
12/29/08 12:03 PM
12/29/08 12:03 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I use a McLeod B&B style pressure plate and a 12 inch 800 series disc behind the stroker. Brewer's Performance have them in stock, good company to deal with too.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
