Re: 4 speed drivers...what's your favorite clutch?
#175444
12/27/08 07:20 PM
12/27/08 07:20 PM
Posts: 4,285 Ohio
64dodge572
Ohio
We stock Centerforce, Mcleod & Hays,give us a call!
Thanks, Wayne
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: ThermoQuad]
#175450
12/28/08 11:18 AM
12/28/08 11:18 AM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
You still can't beat this set up for the money and performance. Handles 400 rwhp with ease Rochester Clutch and Brake 585-232-3717
That looks a lot like Ram's sintered bronze 6000 series disc.
[Re: Duster426]
#175452
12/28/08 02:20 PM
12/28/08 02:20 PM
Posts: 15,377 Omaha Ne
TJP
Omaha Ne
CENTERFORCE dual friction for my Duster
We have installed a butt load of centerforce dual frictions with ZERO issues.
[Re: fourgearsavoy]
#175454
12/29/08 01:50 AM
12/29/08 01:50 AM
Posts: 5,444 So Cal
Sinitro
So Cal
I think a Mcleod B&B plate with a street/strip rag disc should do the trick. Jamie Passon will set you up with a good Mcleod clutch at a fair price. Gus
Just a couple of comments.. a. Make sure you have the proper Z-bar so the fork push rod runs parallel to the bellhousing b. Add a torque strap, a big help for keeping the Z-bar and nylon bearings together
[Re: 340727dart]
#175456
12/29/08 12:03 PM
12/29/08 12:03 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I use a McLeod B&B style pressure plate and a 12 inch 800 series disc behind the stroker. Brewer's Performance have them in stock, good company to deal with too.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
