Re: Big Block Oil Pan For Autocross
[Re: 72Swinger]
#1752605
02/12/15 11:52 PM
02/12/15 11:52 PM
Posts: 842 Urbana, MD
bordin34
Urbana, MD
I currently have stock stamped covers. I had stamped aluminum moroso covers with no baffles but getting them to seal started to become a pain.
[Re: RylisPro]
#1752608
02/13/15 12:47 AM
02/13/15 12:47 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I ordered my pan directly from the manufacturer, it was $380 plus shipping, it was the 31581, had the external oil line....Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: goldduster318]
#1752609
02/13/15 03:50 AM
02/13/15 03:50 AM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
I run a Kevco on my 360, stock size but baffled. I'm not sure if they make a big block one, but they are less expensive than Milodon...
And you have had no pressure drop issues? If so that makes me feel pretty good since I also have a Kevko on my 340. Haven't cornered hard enough yet to find out.
No pressure drop yet!
[Re: bordin34]
#1752610
02/13/15 04:17 AM
02/13/15 04:17 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Milodon 31580 is the road race pan. Its expensive.
Increased capacity with no compromise of ground clearance and gated to keep oil under pickup, what not to like except price?
Answer: Flimsy flange which is prone to severe dimpling when torqued to recommended 15 pounds,,,unless you are a fan of silicone sealers, which I am not,,,,will likely leak if not torqued to that number. Your results may vary depending on gasket supplier.
A bit of 1/8th steel stock and a drill press has addressed this severe design flaw very well for me. No silicone and no leaks.
[Re: Skeptic]
#1752614
02/14/15 03:03 AM
02/14/15 03:03 AM
Posts: 240 Plano, Texas
68cuda440
Plano, Texas
So are engines-pay me now or pay me MORE later. Here's one in my 68 Barracuda, it's a tight fit in the K, but doesn't hit anything.
I put one in a '68 Barracuda in 2004 w/ a '75 K-frame and had to clearance the K-frame a little. Mine has the 1/2" pick up. The bottom of the pan sits flush with the K-frame, it holds 7 quarts, and has the little trap doors to keep the oil in the pickup area during accel / decel and turns.
Attached picture is the Lokar dipstick fit tested using the 1/2" NPT port on the top of the sump.
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
[Re: 68cuda440]
#1752615
02/14/15 04:12 AM
02/14/15 04:12 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Sweet pics Micheal I have one of my BB 72 A body K member from underneath
Mopar to the bone!!!
[Re: 72Swinger]
#1752617
02/14/15 12:21 PM
02/14/15 12:21 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
The picture of the Lokar stick is similar to what I have to do for the 581 pan. The Indy aluminum block has no provision for a stick. They must figure its not neccessary to keep an eye on the oil level. HMMM! I'll drain the oil out after the unit is mounted in the rh pan bung then mark it starting at 5qts for every quart added so there is at least some refference to go by besides rod knock. I'll also mount the k-frame to it while its on the stand to clearance as needed for the pan, frame reinforcements, headers etc.
Carl Kessel
[Re: 72Swinger]
#1752618
02/14/15 02:07 PM
02/14/15 02:07 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Got one with Gen III too. Its a little more snug to the same K member.
Does the 31003 use a specific dipstick? Part number?
[Re: RylisPro]
#1752619
02/14/15 06:24 PM
02/14/15 06:24 PM
72Swinger
Nebraska
Im just using an ebay special on mine. Gonna have to make another "stick" though out of stainless tig rod because this one reads just barely.
[Re: bordin34]
#1752623
03/10/15 11:25 AM
03/10/15 11:25 AM
CKessel
Los Osos, Ca
Glad to see you are already at it on the pan! When I start working on mine, I have the luxury of the k-frame is not mounted and the engine is on the stand. Will do the clearance checking without diving under the car.
Carl Kessel
