Page 2 of 3 1 2 3
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175123
12/26/08 05:37 PM
12/26/08 05:37 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
According to a article in the latest Drag racing action mag there is a tester offered by Quick Fuel that will test the Ethanol content of your fuel, might be somthing to look into and it look's to be a decent article,,,guess I need to sit down and do some reading. now I need to try and find a station around these part's that sell's it.
Bill do you have any info or P/N on that tester
or the article that you can post. I might have to see
if I can get that mag
Mike I checked but the mag has no web site link to read it on line, and I have no way of getting it copied over to my computer, but I would say to get ahold of Marty at Quick Fuel and ask him about the tester as the article has no part number mentioned that I saw,and Marty is who they interviewed, for your info it is the March 2009 edition of Drag Racing Action, and it just hit the stand's here, it has a pic of Frank Manzo's alcohol funny car on the front.
Re: Converting your bracket car to E-85, dicuss or link [Re: dartman366] #175124
12/26/08 06:08 PM
12/26/08 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks for the info Bill
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175125
12/26/08 09:44 PM
12/26/08 09:44 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
Do a search for "moparmanjames". He changed to e85 on the spur of the moment....like when he stopped to fill with race gas, saw the price of e85, and filled his jugs and headed for the track at thanksgiving. I think he's sold on it.
Re: Converting your bracket car to E-85, dicuss or link [Re: J_BODY] #175126
12/26/08 10:27 PM
12/26/08 10:27 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I use e85 and really like it. I'm in Washington now and it's a little hard to find, and they do winter blending down to around E70 I think. I can't run 70 because I've got 15.9 static. 85 is about it for me, and compared to gas I use almost 80 percent more. I know the average is around 40, but if you can dump more in and burn it it'll make more power. My jetting changes with the same mix from perfect mine shaft air to hurricane depression baro dramatically. 8- 138 drill size alky jets to 8-175 drill jets in 2 1250 dominators is the range I've been in. I think the real problem is with 2 big carbs there isn't a great deal of carb signal, making it harder to jet. I haven't found a consistent A/F ratio that it makes best power at. In good air 12.8 works and in bad air 11.7 reading for gasoline. It does like a little more timing than gas. For me it was around 2 degrees more. From what I've seen with other motors on the dyno the less efficient the head the more timing it takes to see real improvements. Sometimes as much as 7 more degrees helped with lower compression average headed motors.
Re: Converting your bracket car to E-85, dicuss or link [Re: Quicktree] #175127
12/27/08 12:15 AM
12/27/08 12:15 AM
Missouri
StrokerPost Offline OP
Missouri
thanks for links Jim, there seems to be one station pretty close. I will have to go check it out. I may have to convert my carb or have it done.
Quick, I'm thinkin with no garantee of the certainty that E85 will always be here, I think in my case I'd pop for a new carb and keep my gas carb for an easy switch back. Thanks guys for the input and links. I know it can be a pain to keep repeating what you may have said a dozen times already, so I DO appreciate the info.
Another question that I have, is there an issue with oil contamination with the E85 like with alcohol? Would your gas ring gap still be "ideal" for the E85?
Re: Converting your bracket car to E-85, dicuss or link [Re: StrokerPost] #175128
12/27/08 12:26 AM
12/27/08 12:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I see just a LITTLE oil contamination but if you
get it good and warm it pretty much dry's it out.
I changed the oil one time during the summer months
with about 40 passes on it, just to check.
I did the same as your thinking, I have my spare
gas dom sitting in the trailer just in case
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175129
12/27/08 12:55 AM
12/27/08 12:55 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
My oil gets a little, but nothing like methanol. I change oil at the same rate I did with gas
Re: Converting your bracket car to E-85, dicuss or link [Re: dthemi] #175130
12/27/08 01:04 AM
12/27/08 01:04 AM
Missouri
Missouri
Ok, thanks guys. This swap is looking quite a bit like a no brainer. Definately has me thinking about it.
Re: Converting your bracket car to E-85, dicuss or link [Re: StrokerPost] #175131
12/27/08 01:19 AM
12/27/08 01:19 AM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
After asking questions here and doing the math I decided not to do it.
My motor is just 11.5:1 with good quench so I can get by mixing 3 gal. of 94 octane with 2 gal. of 110. When I figured in the 40% to 50% increased volume of E85 needed the savings were very little to non existant.
The added problems of it not being available at the track and inconsistant grades of E85 (E70 to E90 and anywhere in between)made me decide against the switch.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Converting your bracket car to E-85, dicuss or link [Re: StrokerPost] #175132
12/27/08 01:23 AM
12/27/08 01:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ken, I sent my 1050 dom into Quick Fuel for them
to change it over due to me not having the time and
they did it for under $500 BUT I had alot of stuff
that I wanted extra, like new bowls and main plate
and you can see what it looked like in the pic above.
I'm sure you can do your own with the links above,
its been well worth the change
Re: Converting your bracket car to E-85, dicuss or link [Re: fasteddie] #175133
12/27/08 02:04 AM
12/27/08 02:04 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Don't forget it's better for you to be around as well. I feel better dealing with the fumes from it than race fuel. Not to mention, you will make a little more power.
Re: Converting your bracket car to E-85, dicuss or link [Re: dthemi] #175134
12/27/08 03:25 PM
12/27/08 03:25 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
If I ran straight race gas it would probably be worth changing over to E85.
If everyone in the staging lanes would change over I could see some benefit. But my one car on E85 among many others on gasoline would probably make little difference in the air quality. JMO
Re: Converting your bracket car to E-85, dicuss or link [Re: fasteddie] #175135
12/27/08 03:53 PM
12/27/08 03:53 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I spend a fair bit of time working on mine in the garage with it running, and riding around some where I notice the air quality more. Being at the track and folks seeing it work has lead to others switching over too. If enough people switch the tracks may start having it there leading to even more folks on it. I'm no tree hugger, but it would hurt my feeling not one bit if everyone ran it. In all seriousness a full day of engine dyno work with Methanol, or race fuel leaves me feeling bad from the fumes. An all day dyno with E 85 and I feel no worse than normal. Having it all over my hands changing jets and stuff has no effect on the way I feel either, where the others make my skin burn and feel weird after a while.
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175136
12/27/08 08:41 PM
12/27/08 08:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I went out and got that mag(Drag Racing Action)
and was reading the article on E-85 and I see that
they say its as corrosive as methanol... man are they
trying to sell their corrosive protection... its
no where near as corrosive as meth, no where near
but it might let them sell a few extra carbs... LOL
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175137
12/27/08 09:16 PM
12/27/08 09:16 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I just found out today that there is finally an E85 pump within 15 minutes of my house!
It is $2.89 today. I was skeptical about running it when the original discussions mentioned not being able to run an aluminum fuel tank, needing special fuel pumps, regulators and fuel lines. Now it seems people are saying all the normal stuff is fine, just need a decent pump and an E85 carb. My car has 2 pumps, a Summit black and a Mallory Comp 250 so I'll probably use the Comp 250.
Now I need to find a good deal on an E85 Dominator.
Re: Converting your bracket car to E-85, dicuss or link [Re: ProSport] #175138
12/27/08 09:19 PM
12/27/08 09:19 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
It is $2.89 today.
I paid $1.23 here last week....
Re: Converting your bracket car to E-85, dicuss or link [Re: RyanJ] #175139
12/27/08 09:30 PM
12/27/08 09:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I seen it here today for 1.35 but I dont buy
it in the winter
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175140
12/27/08 10:41 PM
12/27/08 10:41 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Yeah,,,saying E85 is as corrosive as methanol is in my experience completely without merit. The ONLY thing that I see getting some abuse from it is the holley main bodys that must be made of smelted Chinese beer cans. The bowls and metering blocks are perfect as is the rest of the system, but the bodys get this chalky pitting where fuel sits on them. Still nothing like methanol. I may go to a King deomon, or QF for better main body material.
Re: Converting your bracket car to E-85, dicuss or link [Re: dthemi] #175141
12/28/08 12:54 PM
12/28/08 12:54 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Has anybody used the barry grant 280 pump? I got that and 8an line and mallory filter. It's a paper filter, I take it that the filter would need to be changed?
Re: Converting your bracket car to E-85, dicuss or link [Re: dthemi] #175142
12/28/08 08:29 PM
12/28/08 08:29 PM
NC
440Jim Offline
440Jim  Offline
NC
I am only guessing, but my 2-cents:
1) The Holley anodizing on the main body isn't protecting.
2) The aluminum may have a bunch of zinc in it for easy casting.
Zinc is very prone to corrosion, and maybe it does the same when alloyed into the casting aluminum.
I am using an Aeromotive pump, rated for methanol and gasoline, so I can't help there. I was running a Barry Grant regulator, rated for gasoline only, and the elastomer seat deteriorated on E85. I don't know if it just gave out due to old age (7 yrs), or if it was the E85. Now I run a RobbMc regulator rated for alcohol and gasoline. My Fram HPG-1 filter is holding up just fine after 1-year on E85 (7 on gas before that).
Page 2 of 3 1 2 3
