Re: Converting your bracket car to E-85, dicuss or link
[Re: MR_P_BODY]
#175143
12/28/08 11:16 PM
12/28/08 11:16 PM
Posts: 16,929 NC
440Jim
NC
According to a article in the latest Drag racing action mag there is a tester offered by Quick Fuel that will test the Ethanol content of your fuel, might be somthing to look into and it look's to be a decent article,,,guess I need to sit down and do some reading. now I need to try and find a station around these part's that sell's it.
Bill do you have any info or P/N on that tester or the article that you can post. I might have to see if I can get that mag
I have been happy with this method from the E85 handbook on the National Ethanol Vehicle Coalition website: http://www.e85fuel.com/pdf/storing-handling-e85.pdf Quote:
Procedure for Testing Hydrocarbon Percent of Ethanol Fuel Samples Based on SAE International Paper 912421 (Prepared by NEVC) Equipment for E85 testing VWR Scientific phone # 800-932-5000 50 mL pipettes; Cat. # 52966-217 pack of 12/$212.18 Safety Bulb; Cat. # 53497-202 pack of 3/$18.45 100 mL cylinders; Cat. # 24762-117 pack of 4/$120 Procedure • Using the suction bulb, pipette exactly 50 mL of fuel sample into the graduated cylinder. • Add about 48 mL of water to make the total liquid volume just less than 100 mL. • Place the stopper in the cylinder and shake vigorously for about 15 seconds. • Carefully loosen the stopper to release any accumulated pressure; do not remove the stopper. • Close the stopper again and place the cylinder upright on a level surface. Allow the mixture to sit for about 15 minutes. • Record the total volume of liquid by reading the lowest part of the upper meniscus (the curved interface between the liquid and air). • Record the total volume of the alcohol/water layer by reading the lowest part of the lower meniscus (the curved interface between the two liquid layers). Calculation • The hydrocarbon percent is calculated by: 2.1 + 1.94 * (total volume - alcohol/water volume) • Assuming the sample was an ethanol/hydrocarbon mixture, the ethanol percent is 100 minus the hydrocarbon percent.
Example:
Upper 98 ml, lower 91 ml 2.1 + 1.94 x (98 - 91) = 15.68 ethanol = 100 - 15.68 = 84.3%
DOE Handbook 2008, Appexdix D, page 45.
[Re: 440Jim]
#175144
12/28/08 11:23 PM
12/28/08 11:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Example:
Jim, thats the same as I use to do when I was working, same procedure. I was wondering if they came out with some thing new
[Re: 493_Scamp]
#175146
12/28/08 11:44 PM
12/28/08 11:44 PM
MR_P_BODY
My Mallory pump locked up after E85 use,but I bought it used about 4 years ago,and it didnt act right when I pumped the cell dry for the switch over. I assumed my Battery was low, after runnung the last race and sitting a few weeks It wont even turn. Mallory has alcohol gasket rebuild kits for the pumps and regulators and offers a rebuild service.I think the paper filters may be prone to failures as well so I deliberately left it fueled as a test.
I'm running a pair of Holley black 150's and so far they've been fine
[Re: RyanJ]
#175147
12/30/08 09:06 PM
12/30/08 09:06 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
I just found out today that there is finally an E85 pump within 15 minutes of my house!
It is $2.89 today.
I paid $1.23 here last week....
Its amazing and confusing why there is such a difference in price around the country. I checked on it while I was out today, its $2.49 gal here. I thought it had kinda been keeping pace with gas, but I guess not. For those paying $1.23 what is reg unleaded, and those paying $2.89, whats reg there? Reg here is $1.34.
[Re: StrokerPost]
#175148
12/30/08 11:13 PM
12/30/08 11:13 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Anyway you look at it, it still beats the snot out of paying $7.50 a gallon for Cam2.
It's just the initial hurdle of buying a new E85 carb, fuel pump and regulator. Or having these pieces modified.
[Re: StrokerPost]
#175149
12/30/08 11:28 PM
12/30/08 11:28 PM
MR_P_BODY
It is $2.89 today.
At 2.89 thats real pricey, around here its about 1.65 for E-85 and about 1.50 for regular. If your pump can handle the increase in volume by 30% all you would need to do is the carb. I have a spare 1050 that if I ran out of E-85 I can switch the carb and be running on race gas(buy it at the track) and be running in 5 minutes by just changing the carb and backing the timing down a few degrees and be running the same times(what I've seen so far)
[Re: dthemi]
#175151
12/31/08 12:09 AM
12/31/08 12:09 AM
MR_P_BODY
hey P body, I can't remember did you pick up some when you switched?
Actually I stayed the same BUT I didnt touch the timing yet, I was going to start bumping it up but I put the car away early this year. I do mean it stayed the same within .01, best before was 9.08 and with the E-85 it was 9.09 3 passes in a row
[Re: MR_P_BODY]
#175152
12/31/08 01:15 PM
12/31/08 01:15 PM
ProSport
Akron, Ohio
Here's another question, there's alot of deals out there right now on alcohol carbs. What's it take to run E85 with an alcohol carb?
[Re: ProSport]
#175153
12/31/08 01:20 PM
12/31/08 01:20 PM
MR_P_BODY
Well its starting out with the good parts but I would think you would still be working it over just the same as going from gas to E-85 when it comes to the passages and jetting but that MIGHT be a good way to start if it isnt all corroded
[Re: MR_P_BODY]
#175154
12/31/08 04:58 PM
12/31/08 04:58 PM
ProSport
Akron, Ohio
Maybe I'll call Quickfuel and see what the difference is between their E85 and alcohol carbs. They have a 1050cfm 4150 alcohol carb for a half way decent price. Quickfuel
[Re: ProSport]
#175155
12/31/08 11:05 PM
12/31/08 11:05 PM
Posts: 16,929 NC
440Jim
NC
I am no expert on carb design, but the gas carb should be closer to start with than a methanol (alky) carb. Remember if gas is 100%, E85 is about 135%, and methanol is around 200%. So the boosters and passages in the metering blocks will be too large and slow the fuel down in an alky carb running E85 (if you can choke down the total fuel flow).
Things like the main well dia, cross channel passage dia, booster fuel flow channel dia, etc.
I have been talking with guys on e85forum about my 950 carb boosters. On gas they are 0.156", an alky setup might be around 0.190", I am having a shop put 0.170" boosters in for 2009.
[Re: 440Jim]
#175156
01/01/09 03:34 PM
01/01/09 03:34 PM
ProSport
Akron, Ohio
Oh ok, I thought I'd read here several times that alcohol carbs were pretty close to an E85 carb. I think the best bet is an E85 carb from someone like Quickfuel. I'm just worried about getting a batch of E70 instead of E85 from the pump.
[Re: ProSport]
#175157
01/01/09 03:47 PM
01/01/09 03:47 PM
MR_P_BODY
This is something that we all look at, but if you check the drop sheets before you buy your fuel you would have a pretty decent idea what your getting. Of course you check it and if its what you want then buy it in quanity(drums) instead of just a tank at a time. Check with Quick Fuel like you said about the differences between the 2 style carbs
[Re: rt66jim]
#175159
01/01/09 04:14 PM
01/01/09 04:14 PM
MR_P_BODY
Jim, I have been following the discussion on the E85 forum. It seems to me that Drag Chevette has a pretty firm grasp of what needs to be modified to make a carb work on E85. Would that be your opinion as well? I'm considering having him modify my 950 is the reason I ask. Jim
Yes I believe he has about as much info as anyone and he did a fair amount of testing to get where he is. I would let him or just use his info and do it yourself
[Re: rt66jim]
#175161
01/01/09 10:13 PM
01/01/09 10:13 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Ive been talking to Drag Chevette also. He sure seems to know what he is talking about. I think I'll have him convert my carb, especially if the new station being built carries E-85.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
