Re: Methods for stripping an engine bay down [Re: dart4forte] #1749408
02/09/15 09:38 PM
02/09/15 09:38 PM
KY
Telvis Offline
Telvis  Offline
KY
Do it right
Remove all the hardware out of the engine compartment.
Steam clean if possible or pressure wash. Use a putty knive for those thick greasey areas
Wash with hot soapy water and rinse.
Once dry wipe down with grease and wax remover.
Weld all unnecessary holes, DA sand, fill were necessary and prep for paint
Agree 100%
That's King Weenie to you!
Re: Methods for stripping an engine bay down [Re: Telvis] #1749409
02/10/15 12:24 AM
02/10/15 12:24 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Do it right
Agree 100%
Ajax or Comet and a Scotch-brite pad do a good job of scuffing and cleaning at the same time. I've used that method twice to prep engine bays for paint with good results.
Re: Methods for stripping an engine bay down [Re: G_bob] #1749410
02/10/15 10:39 AM
02/10/15 10:39 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Well...I'm right in the middle of the same thing on my 74 Duster...what a pita...I pulled the k member so at least I can stand in the engine compartment. So far I have used Dawn dish soap and a stiff bristled brush, easy off oven cleaner, scotch brite, a DA and an angle grinder with a scotch brute pad. I am still not done...maybe today...
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Methods for stripping an engine bay down [Re: RapidusMaximus] #1749411
02/10/15 07:18 PM
02/10/15 07:18 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
My preferred method is chemical stripper followed by sandblasting. Cover the painted surfaces. Use the thick solvent based "aircraft" stripper found at some of the big box stores. Its good stuff! A gallon should do the engine compartment. Paint it on a small area with a cheap paint brush. Let it sit for a half hour or so, then scrape the surface with a razor blade scraper, changing the blade as needed. Wire bristle "tooth brushes" also work well. I use a large shallow cardboard box and allow the scrapings to fall into the box to minimize cleanup. Plastic sheets on the ground will also work.
I then sandblast the areas that are rusty or still show paint. I use a cheap suction feed unit. My air compressor isn't all that big. Blasting it all would take too much time and leave me with a beach afterward. The majority of the surface comes clean with the stripper, the blaster cleans up the other areas.
Prime with what you like afterward.
Making a mess is part of the fun. A little planing upfront will minimize the cleanup. Best of all its super low buck but you will have some time invested.
1972 Dodge Challenger
Re: Methods for stripping an engine bay down [Re: GoodysGotaCuda] #1749412
02/10/15 09:58 PM
02/10/15 09:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Spill a few bottles of brake fluid on it.. that will strip it real quick.
Coming soon!!!!
Re: Methods for stripping an engine bay down [Re: GoodysGotaCuda] #1749413
02/10/15 10:11 PM
02/10/15 10:11 PM
Georgia
Steve Bryant Offline
Georgia
On my 70 Cuda, I have stripped the interior and underneath the car with an electric angle grinder and wire discs. A cheap wire disc (about $4 each) will very quickly strip about 10 square feet of car down to the metal. Last weekend I completely stripped the interior (roof, floor, firewall, rear) in less than 3-4 hours. I then wipe everything down with acetone and usually use etching primer. Corners may require chemicals or a dremil tool with wire brushes or some selective minimal sandblasting.
The photo here shows about 20 minutes of work in a wheel well. You can see the wire wheel went through dirt, undercoating, paint and primer like butter.
I prefer this method because its cheap and fairly quiet. HOWEVER, you must protect yourself because those cheap wire discs will fling metal spikes as they wear and they will penetrate skin so cover your eyes with good goggles and protect all other skin with thick clothes. Also, if you are in a confined space, keep a fan on you or wear a respirator since you don't want to inhale any of that crap.
Here is a link to the knotted wire discs I was talking about. I also have plenty of photos of my interior all stripped down from last weekend.
http://www.amazon.com/gp/product/B00B21CH7A/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Re: Methods for stripping an engine bay down [Re: Steve Bryant] #1749414
02/10/15 10:15 PM
02/10/15 10:15 PM
Georgia
Georgia
Here is a photo of the interior work I did this weekend. The wheel also does a number on rust.
Re: Methods for stripping an engine bay down [Re: Steve Bryant] #1749415
02/10/15 10:32 PM
02/10/15 10:32 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
You will find some of them a month or so down the line when the small pieces happen to end up in your socks and shoes. DAMHIK
Outside of a significant investment in someone who uses the dustless blasting this is still the best way I've found.
...FAFO...
Re: Methods for stripping an engine bay down [Re: skicker] #1749416
02/10/15 11:07 PM
02/10/15 11:07 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i keep coming back to this thread and I am amazed at how much work you guys do to strip paint. 1 hour of blasting and your ready to epoxy. the amount of time spent plus discs / caustic strippers / sandpaper ect is about the same cost as a guy like me coming and blasting. no warpage, damage or trapped media. its clean and the rust is gone
crazy amount of effort for such a easy job.
Re: Methods for stripping an engine bay down [Re: chrisf] #1749417
02/10/15 11:17 PM
02/10/15 11:17 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I like the idea of blasting I've seen excellent results from it.
I can't speak for the rest but my time is FREE when it comes to my cars...
It's countless hours I'm in the garage and the kitchen witch is in the house...
...FAFO...
Re: Methods for stripping an engine bay down [Re: chrisf] #1749418
02/10/15 11:19 PM
02/10/15 11:19 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Cheap = the roloc discs and/or the 3M wheels. I've done the wire wheel and it's good for 10 minutes, then the wires lay over, slowing the process and they start shedding. This is how I've done the last 2 compartments.
Faster = blasting, but you gotta really work to get all the stuff out before prime/paint. This is what I just had done to my entire van body.
Stripper is something I don't have a problem with on large surfaces, but an engine compartment has too many crevices and pinch welds. They will hold the nasty in and can bleed it out after paint. I did this on a car many years back, but did not use it in the jambs and other seamed/welded areas.
