Re: Cool video of a dart wheel stand
[Re: Dodgenu]
#1747007
02/06/15 03:54 PM
02/06/15 03:54 PM
Talking out your a$$ is what you do daily on this thread. Im not impressed with anything you have to say. Who cares how fast it is, it is a cool car that works real well and is fun to watch unlike that pos you drive. Later loser!
I think a permanent vacation would work really well here.
[Re: deaks]
#1747008
02/06/15 04:10 PM
02/06/15 04:10 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
Personally, i've found on my car the quicker the 60 ft the higher the front end lifts, most times it 60ft's 1.40-43 and lifts the wheels about 6-8", last time out, on one run it 60ft 1.36 and lifted them twice as high. I would imagine it becomes counter productive when it stands right up though. Mick
We saw the same thing on the first S/ST car we built, 1970 Duster ladder bars with a 452 C.I. M.W. bracket motor, we tried tying the stock front suspension down to get it to react quicker on the Pro Tree division 7 S/ST ran back in 1984, that slowed both the reaction times and 60 ft down That car would pick the front tires up right 4 inches untied and carry them out 20 to 40 ft and set them down real gently My current car does the same with 1.27 60 ft times, real easy to drive Other than hurting my back when I forget to push myself hard back into the seat before letting go of the transbrake button
[Re: Cab_Burge]
#1747009
02/06/15 05:19 PM
02/06/15 05:19 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
My car leaves and lands just like that dart but its a ladder bar car. The front does exactly the same thing. Currently has calvert fronts and everything in the front suspension is new including the steering box.Sometimes trys to rip the steering wheel from my hand. Trouble is i'm not a suspension guro and plopping $500 for shocks would bug me if it didn't fix it.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#1747010
02/06/15 10:36 PM
02/06/15 10:36 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Yeah but at least you've got your tyre pressures right, the car in the vid, the rims almost touch the ground the tyres are so flat. Lol Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Dodgenu]
#1747011
02/07/15 01:45 AM
02/07/15 01:45 AM
Posts: 526 NC
barracuda man
NC
Not cool at all dude.Mr p and cab are some of the most knowledgeable people on this board.
[Re: Dodgenu]
#1747013
02/07/15 06:03 AM
02/07/15 06:03 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
I think your mouth is stuck on a rev limiter. That Dart sounds and is bad ass.My dad and I were in Cali a couple years ago and while we were there we went to check out the Infineon Wed night drags, and thats the first time we saw the white dart and it pulled big wheelies ran straight as an arrow every pass and won the bracket that night. Here is another vid. http://youtu.be/t0OVIsU01mg
Perfect screen name, you'd probably dodge anyone that was prepared to confront you in person. If you are so smart why can't you figure out that wheel stands waste ET?
The stripe is ahead of younot above you, go forward not up!
[Re: SpareParts]
#1747014
02/07/15 11:17 AM
02/07/15 11:17 AM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
Wow! This thread took an ugly turn???
Back to the original video. I see the slicks are under inflated when the wheel almost touches the pavement, but what makes the front end shimmy so bad when the tires hit the ground? Looks like that would be a handful?!?
1970 Duster 340 clone
[Re: BrianT]
#1747016
02/07/15 12:30 PM
02/07/15 12:30 PM
Posts: 994 Addison,IL
OUTLAWSSAA
Addison,IL
The front end shimmy is usually caused from a bad idler arm bushing.Mine used to do that till I changed the idler arm. https://www.youtube.com/watch?v=hpM5adRweXI
[Re: Quicktree]
#1747017
02/07/15 01:10 PM
02/07/15 01:10 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
watch it guys, he's a CAR BUILDER
Funniest thing you've posted on here Toni. By car builder my guess is he works on an assembly line at Kia or some other low end foreign auto maker, or he may build quite a few Revell models... But Mr. P and Cab are always on here trying to help people by providing advice based on what they've actually encountered, to try and insult them is ridiculous. That Dodgenu name stood out to me because he told Al Aguire that he didn't know what he was talking about on another post about wheelie bars.
[Re: BuckeyeBrawler]
#1747020
02/08/15 12:51 AM
02/08/15 12:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
This goes out to to Cab & P-body I personally appreciate your posts put up here have learned several things. Currently battling huge wheelstands myself. 65 B body with Calvert monos with AJE wheelie bars stock front suspension limited to 2" of travel, with DA Afcos set full tight on extension. Getting ready to go from 470 B motor to 500 RB and have destroyed one Charlies pan and wacked a second but not destroyed. I know more power is just going to make it worse. I know the rear of the car is too high but need it to clear tires. New motor will have cast iron Indy head just hoping extra weight will help reduce wheelstand height. IMO The only thing a six foot wheelstand is good for is a picture and destroying a good car ! Getting ready to make ballast bar behind frt bumper.
Thanks... try loosening the extension on your rear shocks... let the rear come up some.. how high are your wheelie bars.. set them about 1" - 1 1/2" off the ground with the car in gear... also start adding air to the slicks.. dont let it dead hook
