Re: Aftermarket Valve Covers on an RB [Re: 70Duster440] #1743746
02/17/15 03:41 AM
02/17/15 03:41 AM
Iowa
76dodgeboy Offline OP
Iowa
He has more time in prep than paint and dipping lol. In the end this was cheaper than buying used valve aluminum Valve covers just to have to modify them. Ill be getting more parts for the truck dipped to match
Re: Aftermarket Valve Covers on an RB [Re: Robbins] #1743747
02/18/15 11:42 AM
02/18/15 11:42 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
shot of it raised
what did you use to raise the booster?
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Aftermarket Valve Covers on an RB [Re: shanker] #1743748
02/20/15 10:30 AM
02/20/15 10:30 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
That's a trip....I post and then my post is gone...anyways I used an A-body scissor(not sure if this is the correct term or not)bracket that raises it up. The piece I'm refering too.
Of course mine was aftermarket....but you get the idea, but when I put the power brakes on my 64 I used a factory set up of a 74 A-body which doing this is what gave me the idea....
Moparlee
Re: Aftermarket Valve Covers on an RB [Re: Robbins] #1743749
02/20/15 07:31 PM
02/20/15 07:31 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
that's what I assumed you used, I just wanted to confirm it....my 74 RC is a factory 440 truck, and I'm GOING to use the MP cast aluminum valve covers and rather than trim the valve covers, I'd rather raise the brake booster....I've got a spare one of those sitting around too.
Re: Aftermarket Valve Covers on an RB [Re: shanker] #1743750
02/20/15 11:55 PM
02/20/15 11:55 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I am guessing that the factory booster/mc for a bb will work with the a body piece? What about pedal to adapter length?
I am going tomorrow to look at the pick and pull for one.
I have a set of Mopar performance covers for the new 440.
Clearance is tight enough with stamped covers on the current 440. I have the parts to go non power.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
