Page 2 of 3 1 2 3
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742720
02/03/15 12:47 AM
02/03/15 12:47 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Mine is a 99% street motor with a few trips to the strip to break and bend the chassis.
MP block 4.50x4.75, Callies crank, 7.1 Hbeam rods 2.2 big ends .990 small ends. Diamond pistons which work out to 10.4-1. Milodon dual line with a 12 qt pan with windage tray and crank scrapper. Bullet solid roller with gentle ramps, .767/.676, 288/292@.050 113 center. FHO rebuilt old SS stock rockers. Indy (Canfield) 426-1 heads, 386cm@.700, Weiand tunnelram with 2 850 thermoquads, 2-1/8x36x3-1/2 headers. 852.8hp@5782rpm and 818.4ftlbs@4818rpm.Dave
Re: Post your Hemi stroker Build [Re: quickd100] #1742721
02/03/15 01:25 AM
02/03/15 01:25 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
My combo is built for street and pump gas as well. A bit milder than some here. I like building my own.
4.5 X 4.5 K1 crank and rods, CP 10.5 pistons, Stage V heads (CNC by MCH) comp solid roller by Dwayne Porter, about .670" lift and 270* 112 LSA mild lobe cam, Stage V rockers Indy intake. Just changed to Gen III 1050 Dominator from 1050 Race Demon 4150. No test results on the new carb swap. Milodon dual line pick up. Will be trying a cross ram RR intake eventually. HP is unknown.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Post your Hemi stroker Build [Re: Hemi Allstate] #1742722
02/03/15 11:29 AM
02/03/15 11:29 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Here's mine.....made 845HP/770TQ. Going into a 3500lb, street/strip A body, hope to go mid 9s
Hemi Mega block 4.5" bore x 4.5" Bryant crank
Saenz H beam 7.1" rods
11:1 CR
Diamond pistons - coated tops/skirts
Sealed Power rings
ARP rod, crank, head studs, oil pan studs, flywheel bolts
Bullet roller, 752/684" lift 270/280 @ .050" 112
Isky Red Zone Xtreme EZ roller lifters
Indy 426-1 heads ported
Stage V rollers
MSD dist/box/crank trigger
Indy 426-4 4500 intake (have a 4500 Barton intake as well)
Pro systems 1150 Dom
Electric water pump
Charlies 8.5 qt pan, Barton pump, Milodon ext dual line w/ swinging pickup
727 with all the good gear
Ultimate Convertor
Dana 60, 4.10s
Re: Post your Hemi stroker Build [Re: LAD 524] #1742723
02/03/15 08:34 PM
02/03/15 08:34 PM
Armada MICH.
DUSTER_340 Offline OP
Armada MICH.
Thanks guys, I really appreciate the comments. I really want to build my own engine as well, and these posts are definitely helping me be a much more educated shopper.
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742724
02/03/15 09:04 PM
02/03/15 09:04 PM
California
mickm Offline
mickm  Offline
California
i built mine, but the last thing i wanted to do was end up with an engine of mismatched components. there may be another time coming, but i figured i was only going to do this once. i spent time on the phone with tim banning at FHO, and we talked about exactly what i wanted from this engine. he then assembled the list of parts, including a cam that he designed, (herb (scatpk) also used this cam), and sent everything off to me.
i then shopped around for everything else, and it all came together nicely!
Re: Post your Hemi stroker Build [Re: mickm] #1742725
02/03/15 11:38 PM
02/03/15 11:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Have'nt seen any builds with the factory steel heads. Would there be that much loss over the other heads. Mine's not together yet but 4.31x4.5, older s/s roller, 13-1 comp, a little port work on the heads, hogan crossram 2- 3310s. Hope it will move my 64.
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742726
02/04/15 11:32 AM
02/04/15 11:32 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
572" Hemi (4.5" bore x 4.5" stroke). Built it myself.
KB block, Callies crank, Oliver billet steel rods, 11:1 Diamond pistons.
Custom solid roller by Dwayne Porter...276°/284° at .050", .672"/.651" lift. Really mild lobes for street durability.
CNC ported MP aluminum heads by MCH. DLI roller rockers.
Ray Barton single 4500 intake w/ a Pro Systems 1200 cfm dominator.
2.25" primary, 4" collector TTI headers. 4" exhaust.
727 w/ 9" 5k stall, 4.10 Dana, Caltracs, 295-65 drag radials.
Pushed my 3850 lb. cuda to 9.54 at 140.4 mph, 1.320 sixty foot (footbraking). On pump 93 octane.
Should be somewhere in the neighborhood of 825 hp.
Now at over 3900 lbs., but w/ nitrous, I'm hoping to get an 8 sec timeslip this year. Went some 9.30s last year spinning the tires.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Post your Hemi stroker Build [Re: an8sec70cuda] #1742727
02/04/15 11:45 AM
02/04/15 11:45 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
636 cu. in. Hemi
KB block, raised deck, raised cam
Millenium heads
billet run fabricated MCH Intake
billet bryant crank 5 inch stroke
aluminum rods
CP pistons 12:1
custom ground small roller .800 lift
Stage V rocker gear
1060 hp, 830 lbs/ tourqe
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742728
02/04/15 11:48 AM
02/04/15 11:48 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Tim Banning built 484 cuin. Moper block and heads. Original intake and exhaust manifolds. Very mild cam in the 500" range with full roller valve train. Edelbrock carbs .
I saw the build sheet on it a few years back and if I remember right, it makes just over 500hp and I think just under 600 ft lbs of torque.
In a 1970 Cuda, John Cope built 727, 3200 stall conv, 3.54 Dana. Running 295-50-15 tires. It will haze the tires at will at anything under about 50 mph without a whole lot of effort by your right foot.
Car is a blast to drive,,especially with the Vintage Air a/c system.
Re: Post your Hemi stroker Build [Re: gtx6970] #1742729
02/04/15 11:50 AM
02/04/15 11:50 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Business room
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742730
02/04/15 07:37 PM
02/04/15 07:37 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
670 hp at 6200 rpm and 660 tq at 4500 rpm,on a really hard true dyno..did this my all alum 528 and the book hemi rich nebal efi camshaft which has baby baby duration and on a 114 efi centerline...out of box mopar/edelbrock assembled heads and out of box mopar/barton 4150 intake with 10.1.
really happy...
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Post your Hemi stroker Build [Re: gtx6970] #1742731
02/04/15 09:42 PM
02/04/15 09:42 PM
Armada MICH.
Armada MICH.
Very nice!
Re: Post your Hemi stroker Build [Re: sublimehemi] #1742732
02/04/15 09:44 PM
02/04/15 09:44 PM
Armada MICH.
Armada MICH.
Just received my book today , nice to see a such a fine example from the book.
Re: Post your Hemi stroker Build [Re: DUSTER_340] #1742733
02/04/15 10:38 PM
02/04/15 10:38 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Here's mine...........
The big box under the bench is a new World block. The 2 white boxes are MP/Edelbrock heads ported and assembled by MCH. And I have a Barton intake, DLI rockers, Direct Connection valve covers and assorted other goodies.
Just need to put the coins together for the reciprocating assembly and cam, lifters, etc. Probably something like 540" with a 250*ish solid roller cam for street/strip. Didn't get it done last year, maybe 2015 is the year?
Master, again and still
Re: Post your Hemi stroker Build [Re: DaveRS23] #1742734
02/04/15 11:21 PM
02/04/15 11:21 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
If you are looking for advice on a hemi stoker nick at compu-flow is the guy to talk to.
he set me up with 2 500 in kit one went in a 68 super bee the other go in my 65 plymouth awb.
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Post your Hemi stroker Build [Re: sublimehemi] #1742735
02/05/15 01:54 AM
02/05/15 01:54 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
really happy...
If I'm not mistaken you're the first to post about the Edelbrock heads. What do you think of them?
Re: Post your Hemi stroker Build [Re: gsmopar] #1742736
02/05/15 05:48 AM
02/05/15 05:48 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
i dont have the cnc victor jr...would of love to try but were not out when i built...always curious to think what it would could of done...and jeez racemart has cnc victor jr for 821.00$ per head..one day:) but i cant complain...my head port alignment was so unbelievably perfect. i took a imaging camera to each one and every port cause i was so amazed that everything was so money on..what i think made my motor shine was the valvetrain...i have barton rollers rockers along those new ultra lightweight elite solid roller lifters with pushrod oiling....but overall its a very gentle true street combo being ultra light weight..475lbs i just fired it off last week..so need this snow to melt cause im dying to play
Re: Post your Hemi stroker Build [Re: sublimehemi] #1742737
02/05/15 11:53 PM
02/05/15 11:53 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Racemart?
Re: Post your Hemi stroker Build [Re: gsmopar] #1742738
02/06/15 12:02 AM
02/06/15 12:02 AM
Mt. Eden Ky.
Mt. Eden Ky.
Racemart?
Googled it : http://www.race-mart.com/
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Post your Hemi stroker Build [Re: Hemi Allstate] #1742739
02/06/15 01:47 AM
02/06/15 01:47 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
http://www.race-mart.com/Edelbrock-EDE-61169.html
821 you cannot beat this head for money and or quality and out the box flow....im sure summit or jegs will beat too...lol...its funny cause the mopar/edelbrock heads are way more money cause they are sold through mopar...not direct like the edelbrock cnc....to bad we dont have blocks available..
Page 2 of 3 1 2 3
