Re: Post your Hemi stroker Build
[Re: DUSTER_340]
#1742720
02/03/15 12:47 AM
02/03/15 12:47 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Mine is a 99% street motor with a few trips to the strip to break and bend the chassis. MP block 4.50x4.75, Callies crank, 7.1 Hbeam rods 2.2 big ends .990 small ends. Diamond pistons which work out to 10.4-1. Milodon dual line with a 12 qt pan with windage tray and crank scrapper. Bullet solid roller with gentle ramps, .767/.676, 288/292@.050 113 center. FHO rebuilt old SS stock rockers. Indy (Canfield) 426-1 heads, 386cm@.700, Weiand tunnelram with 2 850 thermoquads, 2-1/8x36x3-1/2 headers. 852.8hp@5782rpm and 818.4ftlbs@4818rpm.Dave
[Re: quickd100]
#1742721
02/03/15 01:25 AM
02/03/15 01:25 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
My combo is built for street and pump gas as well. A bit milder than some here. I like building my own. 4.5 X 4.5 K1 crank and rods, CP 10.5 pistons, Stage V heads (CNC by MCH) comp solid roller by Dwayne Porter, about .670" lift and 270* 112 LSA mild lobe cam, Stage V rockers Indy intake. Just changed to Gen III 1050 Dominator from 1050 Race Demon 4150. No test results on the new carb swap. Milodon dual line pick up. Will be trying a cross ram RR intake eventually. HP is unknown. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1742722
02/03/15 11:29 AM
02/03/15 11:29 AM
Posts: 621 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Here's mine.....made 845HP/770TQ. Going into a 3500lb, street/strip A body, hope to go mid 9s Hemi Mega block 4.5" bore x 4.5" Bryant crank Saenz H beam 7.1" rods 11:1 CR Diamond pistons - coated tops/skirts Sealed Power rings ARP rod, crank, head studs, oil pan studs, flywheel bolts Bullet roller, 752/684" lift 270/280 @ .050" 112 Isky Red Zone Xtreme EZ roller lifters Indy 426-1 heads ported Stage V rollers MSD dist/box/crank trigger Indy 426-4 4500 intake (have a 4500 Barton intake as well) Pro systems 1150 Dom Electric water pump Charlies 8.5 qt pan, Barton pump, Milodon ext dual line w/ swinging pickup 727 with all the good gear Ultimate Convertor Dana 60, 4.10s
[Re: DUSTER_340]
#1742724
02/03/15 09:04 PM
02/03/15 09:04 PM
Posts: 4,179 California
mickm
California
Thanks guys, I really appreciate the comments. I really want to build my own engine as well, and these posts are definitely helping me be a much more educated shopper.
i built mine, but the last thing i wanted to do was end up with an engine of mismatched components. there may be another time coming, but i figured i was only going to do this once. i spent time on the phone with tim banning at FHO, and we talked about exactly what i wanted from this engine. he then assembled the list of parts, including a cam that he designed, (herb (scatpk) also used this cam), and sent everything off to me.
i then shopped around for everything else, and it all came together nicely!
[Re: DUSTER_340]
#1742726
02/04/15 11:32 AM
02/04/15 11:32 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
572" Hemi (4.5" bore x 4.5" stroke). Built it myself. KB block, Callies crank, Oliver billet steel rods, 11:1 Diamond pistons. Custom solid roller by Dwayne Porter...276°/284° at .050", .672"/.651" lift. Really mild lobes for street durability. CNC ported MP aluminum heads by MCH. DLI roller rockers. Ray Barton single 4500 intake w/ a Pro Systems 1200 cfm dominator. 2.25" primary, 4" collector TTI headers. 4" exhaust. 727 w/ 9" 5k stall, 4.10 Dana, Caltracs, 295-65 drag radials. Pushed my 3850 lb. cuda to 9.54 at 140.4 mph, 1.320 sixty foot (footbraking). On pump 93 octane. Should be somewhere in the neighborhood of 825 hp.
Now at over 3900 lbs., but w/ nitrous, I'm hoping to get an 8 sec timeslip this year. Went some 9.30s last year spinning the tires.
[Re: an8sec70cuda]
#1742727
02/04/15 11:45 AM
02/04/15 11:45 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
636 cu. in. Hemi KB block, raised deck, raised cam Millenium heads billet run fabricated MCH Intake billet bryant crank 5 inch stroke aluminum rods CP pistons 12:1 custom ground small roller .800 lift Stage V rocker gear
1060 hp, 830 lbs/ tourqe
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: DUSTER_340]
#1742730
02/04/15 07:37 PM
02/04/15 07:37 PM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
670 hp at 6200 rpm and 660 tq at 4500 rpm,on a really hard true dyno..did this my all alum 528 and the book hemi rich nebal efi camshaft which has baby baby duration and on a 114 efi centerline...out of box mopar/edelbrock assembled heads and out of box mopar/barton 4150 intake with 10.1. really happy...
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
[Re: DUSTER_340]
#1742733
02/04/15 10:38 PM
02/04/15 10:38 PM
Posts: 12,154 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Here's mine........... The big box under the bench is a new World block. The 2 white boxes are MP/Edelbrock heads ported and assembled by MCH. And I have a Barton intake, DLI rockers, Direct Connection valve covers and assorted other goodies. Just need to put the coins together for the reciprocating assembly and cam, lifters, etc. Probably something like 540" with a 250*ish solid roller cam for street/strip. Didn't get it done last year, maybe 2015 is the year?
Master, again and still
[Re: DaveRS23]
#1742734
02/04/15 11:21 PM
02/04/15 11:21 PM
Posts: 643 southern conn
1969gtx
southern conn
If you are looking for advice on a hemi stoker nick at compu-flow is the guy to talk to. he set me up with 2 500 in kit one went in a 68 super bee the other go in my 65 plymouth awb.
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: sublimehemi]
#1742735
02/05/15 01:54 AM
02/05/15 01:54 AM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
If I'm not mistaken you're the first to post about the Edelbrock heads. What do you think of them?
[Re: gsmopar]
#1742736
02/05/15 05:48 AM
02/05/15 05:48 AM
sublimehemi
sandwich IL
i dont have the cnc victor jr...would of love to try but were not out when i built...always curious to think what it would could of done...and jeez racemart has cnc victor jr for 821.00$ per head..one day:) but i cant complain...my head port alignment was so unbelievably perfect. i took a imaging camera to each one and every port cause i was so amazed that everything was so money on..what i think made my motor shine was the valvetrain...i have barton rollers rockers along those new ultra lightweight elite solid roller lifters with pushrod oiling....but overall its a very gentle true street combo being ultra light weight..475lbs i just fired it off last week..so need this snow to melt cause im dying to play
[Re: sublimehemi]
#1742737
02/05/15 11:53 PM
02/05/15 11:53 PM
gsmopar
Arizona, USA
Racemart?
