Re: POWER STEERING VERY STIFF
[Re: Kern Dog]
#1741078
02/02/15 12:33 PM
02/02/15 12:33 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Thanks,i will bear that in mind. The bearing is solid on the shaft, what could have caused this ? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1741079
02/02/15 05:32 PM
02/02/15 05:32 PM
deaks
robin hood country
I've got the casing off and in front of the locking mech for the ign switch is a tin cup which covers it, then the rear spring clip and in front of that is a small collar before the bearing and it covers the front receiver groove, Should the small collar go on the other side of the bearing to space the press on horn ring away from the ind switch ? See pic
[Re: deaks]
#1741080
02/08/15 12:59 PM
02/08/15 12:59 PM
deaks
robin hood country
I have rebuilt the coupler but there is only a very small gap between the coupler and the outer part of the column, it's about 1/2". Does this seem right ? Bear in mind it's got power steering. I'm also cursing because i put the top section together first and it's difficult to get the cover clipped on, is there a knack to it. Mick
