Re: What do you guys think is a decent bobweight for a BB?
[Re: 451Mopar]
#1741044
01/31/15 11:49 AM
01/31/15 11:49 AM
Posts: 1,051 The Great White North
RAMM
My 2014 440 EMC combo with a Scat 4" lightweight crank, Scat I-Beam 6.2" and custom Diamond pistons came in at 1850g bobweight. Small 4.185" bore though. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: StealthWedge67]
#1741045
01/31/15 12:08 PM
01/31/15 12:08 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I did nothing exotic, in fact my motor is a flat out budget effort. Re-worked 413 crank, Scat Rods, Iconn pistons. I believe it weighed out at 2380. (low-deck RB-rod, 451) I have no idea if thats good or not, but everything I read in preparation said these motors typically check in at around 2400, so I figured I had the right parts stuffed in there.
Well, I stand corrected. Dug out my balance sheet, and my budget 451 bobweight is actually 2314! Don't know why I was thinking 2380 before....??
You and me both...................mine`s closer to 2240.........
[Re: Thumperdart]
#1741046
01/31/15 12:37 PM
01/31/15 12:37 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Here's mine. GRP 7.100" rod, GM .990 pin and Journal size. Both are old and new are the same with a reduction of 14 grams for the my new low compression pistons. Old pistons were Ross with a good size dome, new are diamond with a reverse dome.
[Re: Bigcube]
#1741048
01/31/15 01:38 PM
01/31/15 01:38 PM
Posts: 9,835 MI, usa
dvw
MI, usa
A lot of room for interpretation here. Bore size from 4.250-4.560, Low or high deck, stroke, dome, no dome, pin thickness and length, rod length, rod material, ring pack. I'm sure a low deck, long stroke, small bore, thin ring, light pin, aluminum rod will be the lowest. What do you need to get the job done? Depends on the power level, nitrous, boost, Etc. The best would be something that's strong enough not to fail over the intended life span. Those parts will determine your bobweight. Doug
