Who knows fiberglass repair/mods? ==> Scoop #1740967
01/28/15 01:17 PM
01/28/15 01:17 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I need more clearance above the air cleaner. How involved would it be for someone who knows how to work fiberglass to modify the scoop on my replica T/A hood shown here...
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740968
01/28/15 01:21 PM
01/28/15 01:21 PM
BradH Offline OP
BradH  Offline OP
to increase the above-the-carb clearance like Dick Landy did on this particular version of his Pro Stock Challenger's hood scoop?
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740969
01/28/15 01:23 PM
01/28/15 01:23 PM
BradH Offline OP
BradH  Offline OP
Here's another view of the Landy-modified T/A style scoop.
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740970
01/28/15 01:44 PM
01/28/15 01:44 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I would say that job will take some time to get right. $350 to get it paint ready...if you could find somebody to do it. I tried to get somebody to fix the glass hood on the black charger and like everything else am going to end up doing it myself.
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: Jeremiah] #1740971
01/28/15 01:51 PM
01/28/15 01:51 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
any good boat fiberglass shop could do that easily..talk to your local boat shop ,they no doubt have a fiberglass connection,if they don't do their own 'glass work..
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: dynamite] #1740972
01/28/15 02:01 PM
01/28/15 02:01 PM
P
Porter67 Offline
Porter67  Offline
P
They make a nice fiberglass T/A scoop if you wanted to build up and put one on a steel hood.
The Scoop is like $275 and its a pretty good project to get the big thing on a steel hood, since the vents in the rear on the steel hood are long I had to cut to fit.
I think no matter how you do it, weather a steel hood or cut your current scoop off and build it up its a project non the less.
I dont know if you cut your scoop off if you could reuse it after you built but maybe a good glass guy could.
Sharp car, good luck!
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: Porter67] #1740973
01/28/15 03:21 PM
01/28/15 03:21 PM
Az
Crizila Offline
Crizila  Offline
Az
I never had much luck trying to graft fiberglass on to steel, especially on a hood. Just too much flex going on ( not to mention expansion / contraction differences). Always cracked eventually.
Fastest 300
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: Crizila] #1740974
01/28/15 05:10 PM
01/28/15 05:10 PM
BradH Offline OP
BradH  Offline OP
Won't mess w/ a steel hood + 'glass scoop combination; either want my current hood modified, or maybe I'll consider another hood outright.
What I had in mind originally was like 340Rick's (shown below), but decided that's too freakin' crazy for my way more stock looking (and slower) car.
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740975
01/29/15 02:38 AM
01/29/15 02:38 AM
Texas
mprhound Offline
mprhound  Offline
Texas
I am in the same boat, would love to have the Landy ta scoop. to run the dominator carb I had to pull my ta hood off, for dragweek last year and put a cowl hood on, I hated it. I put a 4150 back on the car just so I could get the ta hood back on, but still looking for options. that other monster ta scoop just looks to disproportioned with the air inlets to tall. with the dominator being taller, just not enough air cleaner options, that 5/16th of an inch made all the difference of not being able to run the ta hood. If I could find the Landy ta scoop I would buy a flat glass hood to put it on. If you find someone to take yours apart and make it taller let me know, I would be interested.
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: mprhound] #1740976
01/29/15 09:11 AM
01/29/15 09:11 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Shim the K-frame down 1/2".
Doug
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: dvw] #1740977
01/29/15 12:32 PM
01/29/15 12:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Doug
Now ya got me thinking.............
Or not............guess that would only work if you used factory motor mounts not elephant ears...........
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: Thumperdart] #1740978
01/29/15 12:55 PM
01/29/15 12:55 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Or a mid plate won't work.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: 1967dartgt] #1740979
01/29/15 12:58 PM
01/29/15 12:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The fun never stops.................
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: Crizila] #1740980
01/29/15 01:05 PM
01/29/15 01:05 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I used evercoat fibertech fiberglass putty on my glass to steel ta hood and had no problems with it. It's not cheap, but beats redoing it down the road.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740981
01/29/15 01:15 PM
01/29/15 01:15 PM
BradH Offline OP
BradH  Offline OP
I found a local restoration shop that looks like it does a lot of old 'Vettes, so they should have a lot of 'glass work experience. I'd like to stop by there with the same pics that I posted above and see what they say.
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740982
01/30/15 10:32 PM
01/30/15 10:32 PM
BradH Offline OP
BradH  Offline OP
So, I did stop by on the way home today. I show the guy the same pics as above and he says (basically) "No problem." and then gives me a quick tour of the shop and shows me a couple of the cars he's working on currently.
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740983
01/30/15 11:37 PM
01/30/15 11:37 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Pm sent
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740984
01/30/15 11:40 PM
01/30/15 11:40 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I hope it works out. I know form follows function but I really prefer the way the Landy scoop looked.
Sheldon
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740985
02/01/15 04:12 PM
02/01/15 04:12 PM
BradH Offline OP
BradH  Offline OP
For anyone who wants to know how much it'll cost for me to do this, I don't know at this time. I know the shop's hourly rate for fiberglass work, but didn't get an estimate for how much time to do the job.
My gut feeling is... not cheap.
Re: Who knows fiberglass repair/mods? ==> Scoop [Re: BradH] #1740986
02/01/15 05:04 PM
02/01/15 05:04 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
Brad AAR has a hood that looks to have a raised center and stock scoop.
https://www.aarqualityfiberglass.com/products/hood-challenger-1970-1974-ta-bolt
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
