Question about CalTracks...
#1740705
01/27/15 09:41 PM
01/27/15 09:41 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
![](/ubbthreads/images/graemlins/beer.gif) Have a 70 Charger.. when going CalTracks, does the front spring hanger need to be the short original one or should the front hanger be the longer SS spring hanger??? I have the longer front hangers and SS springs under the car right now.... Thanks! /Tom
Re: Question about CalTracks...
[Re: TomsCharger70]
#1740706
01/27/15 09:48 PM
01/27/15 09:48 PM
Posts: 289 Lowes
steve660
Lowes
Either one will work. Just tell Calvert which ones you are gonna use.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: steve660]
#1740707
01/27/15 09:52 PM
01/27/15 09:52 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I would use the longer one. Should work better.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1740708
01/27/15 10:38 PM
01/27/15 10:38 PM
TomsCharger70
Stockholm, Sweden
Thanks for your posts! Calvert should take some time and update the order info on their homepage. Like just a few written lines would go along way.. this you need to think about before placing your order, ex. if you have stock or SS spring hangers, then these are the part numbers... that way youll get the correct part/s and wont get all ![](/ubbthreads/images/graemlins/rant.gif) off..
[Re: TomsCharger70]
#1740710
01/28/15 11:23 AM
01/28/15 11:23 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Why use the longer front hanger for the shorter SS springs? The shorter stock hanger and stock springs should work better...same reason the fast cars are going to the longer chevy leaf springs.
FWIW...I use stock length springs and stock hangers on my cuda. Been 1.320 sixty foot footbraking at 3800 lbs. on a 295-65 drag radial.
[Re: Thumperdart]
#1740713
01/28/15 04:41 PM
01/28/15 04:41 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I am going a little different route on my project. I am going to use a front segment from this kit (if they will sell it to me)...I don't want to have to take the springs out of the truck http://www.srdparts.com/index.php?page=s...t&Itemid=1. and I have to modify the existing truck spring plates to accept some mounts I took off a ladder bar kit, because their spring plates don't have the shock mounts I want and I am going to swap the spring plates from left to right so that I can mount the shocks in front of the axle rather than stock behind it. Then I will use the roller kit that I got to anchor the rear of the leafs. It will all make sense when I put it together ![](/ubbthreads/images/graemlins/confused.gif)
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 1967dartgt]
#1740714
01/28/15 08:59 PM
01/28/15 08:59 PM
TomsCharger70
Stockholm, Sweden
How and what is the difference, if the spring length and spring preloadbar is shorter vs. longer?
Thanks ![](/ubbthreads/images/graemlins/beer.gif)
[Re: TomsCharger70]
#1740715
01/28/15 09:40 PM
01/28/15 09:40 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I'm pretty sure my calvert springs came with new spring eye mounting boxes.
Mine did also !
[Re: TomsCharger70]
#1740716
01/28/15 11:54 PM
01/28/15 11:54 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
When going to a longer front spring segment, in almost all cases, you move the Instant Center closer to the 100% anti-squat line, which, in almost all cases, is a good thing... ![](/ubbthreads/images/graemlins/beer.gif)
If you can't handle the truth, you're living a lie.......
[Re: TomsCharger70]
#1740720
01/29/15 11:09 AM
01/29/15 11:09 AM
an8sec70cuda
Ok, så 22" front segment and short front spring hangers ![](/ubbthreads/images/graemlins/punkrocka.gif)
Thanks!
Yes. The longer the front segment of the spring is, the better.
[Re: an8sec70cuda]
#1740721
01/29/15 12:12 PM
01/29/15 12:12 PM
Posts: 20,703 in a cattle trailer down by th...
Guitar Jones
You should just call Calvert and talk to them. Their guys are very helpful and will help you pick what would work best for you and what you want to do.
[Re: Guitar Jones]
#1740722
01/29/15 06:56 PM
01/29/15 06:56 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
He's in SWEDEN , might be a little cost prohibitive to CALL???
