Re: Slide in Camper & Enclosed Trailer
[Re: Dragula]
#1738514
01/26/15 12:54 AM
01/26/15 12:54 AM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Nope, not sarcasm.
The 1 1/2' that the tailgate gives you really doesn't do much when the 6 1/2' is supporting the rest. It's not going to overbalance and fall out without the tailgate is it? The far corners are just out there doing nothing but getting in the way.
As long at the camper is secured in there, drop the tailgate and go.
If not, I don't see any other option than change trucks and go with a full 8' box or go to the other way and have a 6.5 camper with the tailgate up.
If your really, really feel like you need that section in there to hold the camper, you can have a metal shop build you a tailgate with only a center-section and the corners cut out of it. Been done before on those "air" gates for fifth wheels except you want it the other way around.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1738516
01/26/15 01:03 AM
01/26/15 01:03 AM
Posts: 6,018 Salem
Grizzly
Salem
By the way that trailer toad thing is $3300.00, a metal shop can beat that by a significant amount. Or, no tailgate: Free. ![](/ubbthreads/images/graemlins/Twocents.gif)
Mo' Farts
[Re: Grizzly]
#1738517
01/26/15 02:44 PM
01/26/15 02:44 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
Nope, not sarcasm.
Pretty sure that slide in camper is going to hang out also? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Dragula]
#1738521
01/27/15 12:24 AM
01/27/15 12:24 AM
Posts: 419 NY
F1Scamp
NY
I have a 06 dually with an 8' bed with a 11'6" camper. I tow a 24' enclosed all over. Since it overhangs 3'6" I had to put a 4' extension bar on. To get one rated for the load I had to put a class 5 hitch with a 2 1/2" receiver. The camper is around 4400lb loaded. THat with the load equalizer bars it does it fine. I think a 2500 you would want airbags.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: F1Scamp]
#1738522
01/27/15 02:13 AM
01/27/15 02:13 AM
Posts: 6,018 Salem
Grizzly
Salem
From here it looks like all that is in the way is the jack, so, cut that jack out of there and weld on a swivel jack outside of the A-Frame:
Mo' Farts
[Re: Grizzly]
#1738524
01/27/15 10:41 AM
01/27/15 10:41 AM
Posts: 419 NY
F1Scamp
NY
The campers usually are lower than the bed of the truck in the back. Mine is about 3" lower. It would be some serious magic to get the trailer hooked up to the ball, requiring the camper to be lifted. If you get a decent size camper, there is no way to do it without an extended hitch. Even you extended the tounge of the trailer, it still would hit the camper on bumps. I'll see if i can find a pic of my setup.
