Re: rocker shaft shims, what are they good for? #173707
12/24/08 11:02 AM
12/24/08 11:02 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
i've made rocker stands before for other heads. the only thing that comes into question on these heads is if there's enough material thickness to drill and tap for a longer stud after milling the old stand off.
Bob, i always put a dowel pin in to locate the stands also.
Can't speak for the Zeekers,but it workes ok for stock heads as well as Indys.
Re: rocker shaft shims, what are they good for? #173708
12/24/08 11:46 AM
12/24/08 11:46 AM
Anonymous OP
Anonymous OP
ok fellows. the shims were made out of soft copper so that it would conform to the pedestal. now these heads needed the rocker shaft raised up .120" the get the roller tip to travel in the correct arc, without them the tip was at the inside of the valve tip and wouldn't even ride close to the center during it's travel. this happened only on the center pedestal which is the tall one, about 3 times taller than the others. when dan did the valve job on the heads he did find the middle pedestal cracked on the other head and repaired it, sharp eye i must say. the pedestal in the pic is the middle one on the unrepaired head , ther was no visable sign of of crack and it broke when i started to torque them and that happened at a mere 20ft.lbs. the other head where dan repaired the pedestal made it to full torque fine. the owner does have a stud kit for the heads and will use it now that the rocker arms are all shimed side to side correctly, even using the studs i have to assume it would have broke anyway. so with due respect to everyone did the heads have the wrong valves in them from the gitgo because the previous owner had ground the underside of the rockers for clearance on the top of the retainers. something was wrong for sure for the pedestals to be .120" too low. the valves seats do not appear to have been sunk excessively, especially somewhere in the .080" range. to correct all this the pedestal will need repaired and the others all raised up .120" to get everything happy. i have full faith in dan's abilities to accomplish this repair.
Re: rocker shaft shims, what are they good for? #173709
12/24/08 11:54 AM
12/24/08 11:54 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Bob,as old as these heads are,who knows what they have been subjected to in their past history.I don't think anyone questioned Dan's ability here.
Re: rocker shaft shims, what are they good for? [Re: B G Racing] #173710
12/24/08 12:08 PM
12/24/08 12:08 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Yeah the thicker shims pry the pedestal apart with the combination of heat cycling, bolt clamping force and the constant stresses of the valvetrain. If you think about it the pedestals themselves are relatively fragile to begin with and ironically the weakest pedestals (the ones that are hollowed for the oil passage) are the ones that are right between the heavier intake valves.... even though they are a lot wider they're not really that much stronger at the cup when you put a thick shim on them. I remember racers in the early 70's were already starting to mill them down for blocks because they didn't want to risk a ton of hours in ported iron heads and expensive valvetrain for a cast pedestal. There was a reason the Race W2's had blocks.
WIZE
In Car:
Re: rocker shaft shims, what are they good for? [Re: B G Racing] #173711
12/24/08 01:43 PM
12/24/08 01:43 PM
Anonymous OP
Anonymous OP
this statment is a non-issue here because no one is questioning it and i truely feel dan is the man to fix this problem.
Re: rocker shaft shims, what are they good for? #173712
12/24/08 01:48 PM
12/24/08 01:48 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Those would be a good candidate for the Jesel system.
Re: rocker shaft shims, what are they good for? #173713
12/24/08 02:49 PM
12/24/08 02:49 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, I've run the TAPERED shaft shims on a couple different sets of heads w/o any such issues.
Re: rocker shaft shims, what are they good for? [Re: tjmarcus1] #173714
12/24/08 03:06 PM
12/24/08 03:06 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
The shims I used some years back were thick on the bottom
.015 or .030 and thin on the walls, almost 0
ditto! divorak has the correct ones that seem to work.
i would not doubt dan's skill level, and am not into bashing him. if my post was interpreted as such, then i humbly apologize. dan is the man
Re: rocker shaft shims, what are they good for? [Re: BradH] #173715
12/24/08 03:08 PM
12/24/08 03:08 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Just a question for Dram,
How good are Zeeker heads? Like flow and stuff.
Edelbrock RPM's or Indy SR's ? Is this Dan Zeeker
were talking about?
Snap your neck, mega G-force launch, is all I want!
Re: rocker shaft shims, what are they good for? [Re: tjmarcus1] #173716
12/24/08 03:30 PM
12/24/08 03:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think anyone was. I have never seen anyone
go as much as .120 but I dont see a ton of heads,
the most I have gone was .045 with the shims mentioned
above
Re: rocker shaft shims, what are they good for? [Re: MR_P_BODY] #173717
12/24/08 03:36 PM
12/24/08 03:36 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Let me ask the machinist/builders this
If the rocker stands are off that much .125 doesn't this get multiplied times the rocker ratio etc? case in point would equal to .1875 and as much as .200+ with higher rocker ratio's.
I was thinking so, this would be a mile off in reality...
Re: rocker shaft shims, what are they good for? [Re: BDS871Cuda] #173718
12/24/08 04:20 PM
12/24/08 04:20 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
BDS871Cuda, the Zeekers are the predecessor to the Indy 440-1, they take the same rockers, valves, etc. Indy bought the mold from Zeeker to make the -1s they can flow about the same as a fully ported set of -1s. That's what I ran all last year and they made good power and I didn't have any issues with them. If you ever order HS rockers for -1s you'll notice the part number has a Z in it, it's because they were designed for the Zeeker heads. Mine didn't have the porosity issues that some sets had, didn't have to use shims or anything special.
Mine already had the rocker shaft pads cut down and use square blocks that mount flat to the Head shaft pedestals. Here is a pic of the HS rockers and the blocks.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: rocker shaft shims, what are they good for? [Re: WadeMetzinger] #173719
12/24/08 04:22 PM
12/24/08 04:22 PM
Tulsa, Ok
Tulsa, Ok
Here is a pic of the Indy -1s and the Zeekers next to each other.
Re: rocker shaft shims, what are they good for? [Re: WadeMetzinger] #173720
12/24/08 04:25 PM
12/24/08 04:25 PM
Tulsa, Ok
Tulsa, Ok
Here's a pic from the exhaust side and you can see the rocker shaft pedestals better. (Zeekers are in the back, -1s in the front)
Re: rocker shaft shims, what are they good for? [Re: WadeMetzinger] #173721
12/24/08 05:08 PM
12/24/08 05:08 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Wade,
Looks like the Zeeker pedestals between the intake ports aren't any wider than the others as with other heads? I know the big offset in the rocker but the intakes see a bit more stress due to the heavier valve mass even if they don't have the oil pass through like most production style heads.
WIZE
In Car:
Re: rocker shaft shims, what are they good for? #173722
12/24/08 07:33 PM
12/24/08 07:33 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Ouchy!!!
Wouldnt studs help that problem?? And also I have never heard of using any shimms thicker than a few thou. It also puts extra side to side stresses on the bolts the farther away the threads are from the head. In this case it was nasty bad.
I am going to stud my rocker shafts. I have done that in the past on Higher RPM circle engines, and it has always worked fine.
Re: rocker shaft shims, what are they good for? [Re: MR_P_BODY] #173723
12/25/08 03:54 PM
12/25/08 03:54 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I have that same type of "tapered" shim on my Charger's 440. Bought them 20yrs. ago from Mancini I believe? I have never been able to find them since?
Re: rocker shaft shims, what are they good for? #173724
12/25/08 09:31 PM
12/25/08 09:31 PM
Eastern Shore of Md.
BigRay Offline
BigRay  Offline
I ruined a great pair of 906's with shims cracked every stand.
