Page 2 of 3 1 2 3
Re: Hesitation ?? [Re: BIGS] #1736746
01/26/15 09:48 PM
01/26/15 09:48 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Hey Stroker, what is your base/initial timing at idle and how quick are you getting your total in......this is the first place to start.....Jesse
If you like drag racing, support your local track.
Re: Hesitation ?? [Re: CHAPPER] #1736747
02/01/15 02:58 AM
02/01/15 02:58 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
initial is right about 10 and total of right about 35/36.
did wind up putting a A/F meter on it and WOT is at 12.5/13
Cruise is at 12.5, so I will work on jetting
Still has the miss that I think is a ignition issue
Got a dampner that has 2 marks on it
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Hesitation ?? [Re: Stroker Scamp] #1736748
02/01/15 09:43 AM
02/01/15 09:43 AM
Q
Quicktree Offline
Quicktree  Offline
Q
you need to jack that initial up to around 18-22* 10 is not enough imo
Re: Hesitation ?? [Re: Stroker Scamp] #1736749
02/01/15 12:22 PM
02/01/15 12:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Jetting ISN`T tuning only controlling the VOLUME of fuel............you need to TUNE the emultion well, t-slot jet(u need 1)idle bl, hi etc. You will not be happy until someone who knows what`s up TUNES it for ya or learn how yourself...........you can do it!
Re: Hesitation ?? [Re: Thumperdart] #1736750
02/01/15 12:24 PM
02/01/15 12:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
carb tuning doesn't even start until all the basics are taken care of. with 10* initial it has not.
Re: Hesitation ?? [Re: Quicktree] #1736751
02/01/15 12:28 PM
02/01/15 12:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I agree about more initial so let`s see how that solves the crappy tunes of carbs today cos I`m sure when he brings it up to where you think it should be, it will be perfect..............
Re: Hesitation ?? [Re: Quicktree] #1736752
02/01/15 12:43 PM
02/01/15 12:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
you have to get the base timing up.. but
your gonna have to curve the dist so you reduce the
total timing to get what you need for max... this was
said earlier on the timing
Re: Hesitation ?? [Re: Thumperdart] #1736753
02/01/15 02:05 PM
02/01/15 02:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
maybe not, but im not trying to sell carb tunes either...
Re: Hesitation ?? [Re: Quicktree] #1736754
02/01/15 03:20 PM
02/01/15 03:20 PM
pacific northwest
pacific northwest
couple of other things
put a vacuum gauge on it and its at 20 at idle and 50 at about 2500.
I agree on getting the timing down first, I have 3 different timing lights and all 3 give slightly different readings, plus the junk dampner marks
This motor is in the Duster, more of a street car
Re: Hesitation ?? [Re: Stroker Scamp] #1736755
02/01/15 03:23 PM
02/01/15 03:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
check the vac at idle in gear? are you running PV's?
Re: Hesitation ?? [Re: Quicktree] #1736756
02/01/15 04:22 PM
02/01/15 04:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
IF you knew how you definitely would but talkin and banterin and chest pounding seem to be easier than actually doin something................
By the way, I`m not sellng tune ups I`m selling RESULTS..............
Re: Hesitation ?? [Re: Stroker Scamp] #1736757
02/01/15 05:20 PM
02/01/15 05:20 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Your picture shows your timing at 10* AFTER tdc not before. That's 20* from where you think it is.
Re: Hesitation ?? [Re: Thumperdart] #1736758
02/01/15 05:43 PM
02/01/15 05:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I am not pounding anything, when I see a direct side by side comparison I will be the first to congratulate you. what puzzles me is all these years you never talked about being a carb guy then all of a sudden you can get .2 form a few tweaks. and maybe so not putting you down in any way. I just want some proof, is that to much to ask? I am not talking about some guys project or one way off. one that runs somewhat well and a thumper tweak back to back results. then I will
Re: Hesitation ?? [Re: Quicktree] #1736759
02/01/15 06:11 PM
02/01/15 06:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t NEED to prove anything to you and no longer care if I ever build one for you or not cos it`s those "open minded" people that get it and THOSE are the customers I need and appreciate and funny enuff, they appreciate me back...........
Re: Hesitation ?? [Re: Thumperdart] #1736760
02/01/15 06:23 PM
02/01/15 06:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
ok ok to be honest I wouldn't let just anybody go drilling and messing with my carbs. I hope the best for you. you have a great running car and I always pull for you. I am glad it works for you but I can't help wondering and I am not the only one so good luck don't be mad...
Re: Hesitation ?? [Re: mrrandyj] #1736761
02/01/15 07:04 PM
02/01/15 07:04 PM
pacific northwest
pacific northwest
That was just a pic to show the 2 marker lines
Re: Hesitation ?? [Re: Stroker Scamp] #1736762
02/01/15 07:13 PM
02/01/15 07:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So which one is zero... you should have marked the
zero when you degreed your cam
Re: Hesitation ?? [Re: MR_P_BODY] #1736763
02/01/15 08:02 PM
02/01/15 08:02 PM
pacific northwest
pacific northwest
Car was bought as is, so I am just getting to know all of its quirks. Who knows if the cam was degreed or not, hopefully so
and GO HAWKS
Re: Hesitation ?? [Re: Stroker Scamp] #1736764
02/01/15 08:10 PM
02/01/15 08:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
and GO HAWKS
got $20 on the Hawks
Re: Hesitation ?? [Re: Quicktree] #1736765
02/03/15 01:16 AM
02/03/15 01:16 AM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
umm you say you have how much vacuum? how big is the cam? and are you sure the breaking up is not a mechanical issue?
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Page 2 of 3 1 2 3
