Re: (72-93) 1st gen dodge truck weigh & suspension
[Re: boostedwarlock]
#1736700
01/23/15 03:14 PM
01/23/15 03:14 PM
Posts: 6,021 Salem
Grizzly
Moparts Proctologist
Salem
Hey, welcome to the site! ![](/ubbthreads/images/graemlins/thumbs.gif) Wow, got any pictures of this Beast you can show us? Sounds right up my alley anyway. A couple of suggestions for your brakes: 1. Expensive, but see if you can locate a wrecked SRT Ram and grab the whole braking system and anything else you can from it and adapt it to your truck. 2. Much cheaper, look into adapting a set of brakes off of a 3/4 ton truck. As I'm sure you've noticed, the entire front-end on these is big, empty box. I've seen a couple of these trucks involved in front collisions and they fold like a carboard box, and so does the cab. I mean, from what I saw, they have horrible protection for the occupants. ![](/ubbthreads/images/graemlins/nervous.gif) My opinion, You really take your life into your own hands if you start removing the inner fenders and going fiberglass hood.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1736701
01/23/15 03:46 PM
01/23/15 03:46 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Didn't the Texas Monkeys use a newer Ford Crown Vic front stub on one? Plenty of brake, sprung about right, R&P steering and just right width IIRC.
Mopar to the bone!!!
[Re: Grizzly]
#1736702
01/23/15 09:44 PM
01/23/15 09:44 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Hp383 can tell you how badly these trucks fold up. He had a bad collision in one and now has a wheelchair in his signature.
I've had a few minor to mild collisions in mine and I can tell you it hurts.
#1736706
01/24/15 04:41 AM
01/24/15 04:41 AM
Posts: 17 Jefferson City, Mo
boostedwarlock
Jefferson City, Mo
Last one of my truck cause no one wants to see my old work truck
1979 "boostedwarlock", 1931 Dodge, 1974 w100, 1974 w200, 1979 w200, 1981 Ramcharger, 1984 Ramcharger, 1985 w150. I have tons and tons of other Mopars but I don't have the time to list.
#1736707
01/24/15 06:06 AM
01/24/15 06:06 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
IIRC, the C-body and 1/2-ton trucks used the same size upper balljoint, so if you're thinking car knuckle, that's your likeliest bet I'm guessing.
2 Demons...no, not my kids!
[Re: 4speeds4me]
#1736708
01/24/15 01:34 PM
01/24/15 01:34 PM
boostedwarlock
Jefferson City, Mo
That might be true some had said that as well. Now I just need to fine an old one someone has laying around with all the goodies so that I can do a little bit of measuring.
#1736709
01/24/15 04:01 PM
01/24/15 04:01 PM
Posts: 52 CO
Twisted
CO
The '73 C body rotor was shared with the early trucks. AndyF made a big brake kit for this rotor so you might want to see if you can scrounge one up. If I remember correctly it was a 13x1.25 inch rotor and viper calipers.
Thank you Aaron
69 Dodge Polara 4DHT 70 Plymouth Duster 03 Dodge Neon R/T 05 Dodge Grand Caravan SXT
#1736710
01/24/15 05:17 PM
01/24/15 05:17 PM
feets
Senior Management
Senior Management
Irving, TX
1) cut the braking surface off your rotors and convert them into hubs. 2) open the center register of 2005 Mercedes S500 brake rotors to fit the truck center registers. Redrill the bolt pattern to match. 3) make a bracket to mount the proper caliper in the best position. 4) if using a multi piston caliper be sure the wheels have the spokes far enough away from the mounting surface to clear big fat calipers.
Another option is to send me the truck spindles and enough cash to build the setup you want.
#1736714
01/24/15 09:40 PM
01/24/15 09:40 PM
feets
Senior Management
Senior Management
Irving, TX
If you want to use a single sided caliper with larger brakes you can grab more common off the shelf rotors like the 2007 Charger RT. You will need to turn your rotors into hubs and install slightly longer studs.
The Charger center register and bolt pattern are the same as your truck. The shallow offset of the rotor means a floating caliper will be required. You will need to adapt the siding caliper mount to the spindle. It's possible to do that but, again, I'd need the spindle, caliper, hub, and rotor to build it.
That would give you $30 rotors (13.5") and $20 pads. All parts would be off the shelf except for the hubs you make out of your stock rotors.
17" wheels would be required, possibly 18" depending on the caliper chosen.
#1736717
01/25/15 06:01 PM
01/25/15 06:01 PM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
Building 1 1/4 front sway bar and a 1 3/4 rear sway bar.
That sounds dangerously backwards. Have you driven this combo yet?
