Re: Average cost of trans rebuild?
[Re: WO23Coronet]
#1736686
01/29/15 04:09 PM
01/29/15 04:09 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
Thank-you! That was a good read that you linked here, I book-marked it. P.S. That would be the day I would let some Butcher pry my frame rails 3" apart to get that crossmember in. Isn't there a cab mounted to that frame you're prying on? I found a better way to do it. And, says to use Type F fluid when it is VERY clearly stated by Chrysler what to use: ATF +4 only, NO exceptions or damage will result.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1736687
01/29/15 05:12 PM
01/29/15 05:12 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I guess any modifications to anything can only be bad, no way to do it better than the factory ever 727s were awesome and lasted very well behind 440s and now basically the same trans with an OD added is pure junk behind a 318. What really changed? They tried to make them shift soft with calibrations and slippery fluid. Just FYI I get less comebacks doing it my hack ways than mopars way.
[Re: HotRodDave]
#1736688
01/29/15 06:01 PM
01/29/15 06:01 PM
Posts: 6,017 Salem
Grizzly
Salem
I've seen enough. By the corrections that have been made to your responses and "I'm better than the Factory" attitude I wouldn't let you near my Dodges with a 100 foot pole.
Mo' Farts
