Re: Average cost of trans rebuild?
[Re: WO23Coronet]
#1736686
01/29/15 04:09 PM
01/29/15 04:09 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Thank-you! ![](/ubbthreads/images/graemlins/thumbs.gif) That was a good read that you linked here, I book-marked it. ![](/ubbthreads/images/graemlins/beer.gif) P.S. That would be the day I would let some Butcher pry my frame rails 3" apart to get that crossmember in. Isn't there a cab mounted to that frame you're prying on? I found a better way to do it. And, says to use Type F fluid when it is VERY clearly stated by Chrysler what to use: ATF +4 only, NO exceptions or damage will result. ![](/ubbthreads/images/graemlins/Twocents.gif)
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1736687
01/29/15 05:12 PM
01/29/15 05:12 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I guess any modifications to anything can only be bad, no way to do it better than the factory ever ![](/ubbthreads/images/graemlins/eyes.gif) 727s were awesome and lasted very well behind 440s and now basically the same trans with an OD added is pure junk behind a 318. What really changed? They tried to make them shift soft with calibrations and slippery fluid. Just FYI I get less comebacks doing it my hack ways than mopars way.
[Re: HotRodDave]
#1736688
01/29/15 06:01 PM
01/29/15 06:01 PM
Posts: 6,018 Salem
Grizzly
Salem
I've seen enough. By the corrections that have been made to your responses and "I'm better than the Factory" attitude I wouldn't let you near my Dodges with a 100 foot pole. ![](/ubbthreads/images/graemlins/Twocents.gif)
Mo' Farts
