Re: Lash Caps or Longer Valves?
[Re: Monte_Smith]
#1736113
01/22/15 03:17 AM
01/22/15 03:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
What is it you are trying to achieve. Do you "need" lash caps for rocker geometry............because just using a retainer and lock to increase installed height, doesn't mean you must use lash caps. I am sure you are also aware, that if you DO use a longer valve, it will alter rocker geometry and you might have to raise shafts and get a longer pushrod to correct it. If you have proper geometry now and pushrods, the obvious choice is +.050 locks and +.050 retainers.
Monte
What Monte said about the locks and retainers... if your trying to just increase the install height.. of course if the geometry is fine now with the valve length you have ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Monte_Smith]
#1736115
01/22/15 03:59 AM
01/22/15 03:59 AM
Posts: 9,106 Rogue River, OR
Jeremiah
Rogue River, OR
Monte
Geometry-wise I am pretty happy with what I have but could add another .030 of shims if I went longer. I am already using a +.050 lock. If I could find a +.050 retainer in Super 7 that would be cool but so far no dice. I think it would have to be tool steel to not cause clearance issues with the rocker arm. I built a "test" cap to add .110 to the valve tip and added .030 to the .060 worth of shims I already had and the pattern was more than acceptable. I have been reading every catalog from Ferrea to Del West and my eyes are starting to cross. It gives you a new respect for guys that are making this stuff work with large-ish lift cams. I think the designer at Edelbrock forgot to account for the thickness of the spring seat/locator/cup and now it's haunting me. I wish I would have bought some -1's or MW EZ's at this point. Who designs a head with big flow potential and does not plan a 2" installed height for it? ![](/ubbthreads/images/graemlins/no.gif)
[Re: boatracer572]
#1736116
01/22/15 04:04 AM
01/22/15 04:04 AM
Jeremiah
Rogue River, OR
Manley offers +.100" retainers and a +.050" keeper , for a total of .150" more installed height if you need that much.....
And I do need that much. With a .045 spring seat I am only seeing 1.920-30. Gaining .100 would be a blessing. From my measurements I would be lucky to get away with a +.050 retainer let alone a +.100. Thanks for the insight I might order some up anyway and have a look.
[Re: rickseeman]
#1736118
01/22/15 01:00 PM
01/22/15 01:00 PM
Posts: 8,917 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
What about cutting the seat ??
[Re: rickseeman]
#1736119
01/22/15 01:24 PM
01/22/15 01:24 PM
Jeremiah
Rogue River, OR
Be advised that Manley +.100" retainers may not give you .100" more installed height.
Good to know. I have a couple hundred dollars of retainers and locks to throw at this to figure it out. I'll make sure to report back with how it all measures up.
[Re: Stanton]
#1736120
01/22/15 01:24 PM
01/22/15 01:24 PM
Jeremiah
Rogue River, OR
Unfortunately there isn't enough meat due to the CNC porting done on the head.
[Re: Cab_Burge]
#1736123
01/24/15 03:03 AM
01/24/15 03:03 AM
MR_P_BODY
I'm not a fan of lash caps on a engine.. I tend to run high revs and never found it to be any help UNLESS I was trying to correct a geometry issue of short valves.. yes the caps can help with a mushrooming issue... but I have never had that.. thats with roller rockers on a solid roller cam ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Jeremiah]
#1736124
01/24/15 07:36 AM
01/24/15 07:36 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I hear you. Nice ports and can't fit a decent valve spring ![](/ubbthreads/images/graemlins/hammer.gif) My old heads, I cut the seat pockets, but they were stock ports. The CNC ported heads are ported about as tall as you can go before breaking into the valve spring seats. Anyone using a shim and no spring seat cup/locator? My old B-1 B/S heads were setup with just a shim between the spring and head so I'm not sure how important the spring cup/locator is?
[Re: B3RE]
#1736127
01/24/15 05:06 PM
01/24/15 05:06 PM
Jeremiah
Rogue River, OR
Monte
I'll give you 500 bucks for them and you can apply that to a set of -1s. You'll have the heads you want, and I'll set up the Victors for a 540 I have with a .800" lift solid roller. Hey, I'm just trying to help you out.
Not just yet...I'm thinking some .060 and .090 rocker shaft spacers are going to be in order.
That said I'm going to do up a set of -1's with a paired rocker setup for my "good" motor.
Do you happen to be a Manley dealer? I'm going to start a database for installed height measurements of retainers and locks to get this stuff on paper for future builds. Apparently 451 and myself are the first guys around to try and use these heads to their potential.
[Re: Thumperdart]
#1736128
01/24/15 05:10 PM
01/24/15 05:10 PM
Jeremiah
Rogue River, OR
After reading all of these hastles on these heads, I`ll probably go Indy through someone on here UNLESS those suck too then I`ll just stick w/my RPM`s and still have a solid 9-second car w/zero hastles and crazy cost.
MW EZ's all the way. Between the center rocker stand issue, installed height SNAFU, rocker to valve cover issues, headers hitting the valve cover, etc. it's not really worth the headache. Although some of those can be avoided by the user these problems should have been solved by an engineer.
[Re: Jeremiah]
#1736130
01/24/15 07:26 PM
01/24/15 07:26 PM
Posts: 561 USA
B3RE
USA
No, I'm not a Manley dealer. I can get their whole line through one of my wholesale suppliers though.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
