Re: Does this sound like an ignition switch? 99 Dakota [Re: mopar346] #1733625
01/20/15 09:52 PM
01/20/15 09:52 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
easy way to check the switch.
open up access for the ignition switch (steering column trim covers) use a test light and check for input and output power of the ignition switch. 2 fused input wires pk/bk and red wire.
The outputs are yellow=crank
black/white power in run an accessory position
bk/or =power in run /key on.
db= power in run position/key on.
Re: Does this sound like an ignition switch? 99 Dakota [Re: moretoys] #1733626
01/20/15 10:19 PM
01/20/15 10:19 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
That is awesome information, thank you! You mentioned FUSED input power, are the fuses in the fuse box on the side of the dash or in the power distribution box under the hood?
Careful, your character's showing!
