Page 3 of 13 1 2 3 4 5 12 13
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: ProStDodge] #1733062
01/19/15 12:23 AM
01/19/15 12:23 AM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
The rule was not brought about because "it sounded good". It was found in testing by SFI that the belts and/or the thread used deteriorated with age and no longer passed the stress loads required to pass the SFI certification at some point in time.
So unless the seat belt manufacturers can develop a seat belt which will pass the tests for 5 years, and submit them to SFI, you can sign all the petitions you want and it will not change the rule.
Sorry i have a real hard time believing this. My safety harness in the steel mill went thru some crazy testing every year. These were exposed to chemicals, lime, acids, grease, water, heat, and about everything else you can think of. 2 years is crazy dumb.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: ProStDodge] #1733063
01/19/15 01:00 AM
01/19/15 01:00 AM
The real reason NHRA doesn't use the same specs and dates NASCAR uses is the way I was told was that when Lee Shepard got killed testing a long time ago was that NHRA and the local track official thought he had slipped out of the shoulder belts due to there age and amount of time they had been exposed to U.V rays from daylight racing. I heard second hand from the racers grapevine by some of the people who claimed to be there that day that he and his partners had been doing a lot of 60 ft. testing at a close by local track in OK on there way to the Gatornationals the year he died. He had made one full run in the morning and then they did a bunch of 60 ft. only testing until the last run of the day. The wind had been blowing across the track pretty bad all day and it was said that he may have forgotten to put on or tighten the shoulder harnesses before making that last run Bottom line is he was killed in that accident and NHRA went to the two year rule right after that.
BTW, isn't our belts three inches wide Maybe I should go measure mine I remember when they outlawed two inch belts and added the crotch strap after Bob Lambeck crashed his old Pro Stocker at OCIR and slid out of the four point harnesses require back then, he slid up under the dash and broke his pelvis and other bones Bill Bagshaw crash his Pro tock Arrow at Irwindale with the crotch strap several years after that, he was very sore and walking bowlegged for several weeks but nothing got broken I never want to test the safety gear or any other crash related hardware at the track, never ever
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: ProStDodge] #1733064
01/19/15 01:03 AM
01/19/15 01:03 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This is funny.............Are the 5 year NASCAR belts threaded differently? IIRC the local NASCAR series go 5+ years........
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: Thumperdart] #1733065
01/19/15 01:43 AM
01/19/15 01:43 AM
PA.
"Little"John
"Little"John
PA.
I hereby give seat belts producers permission to use "the good thread" for now on and charge me 10 dollars more.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: pittsburghracer] #1733066
01/19/15 02:03 AM
01/19/15 02:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did some testing on 2" wide belts at work... even
a 2" belt WILL hold more pressure than a human body
can withstand before the belt fails... the testing
Captain Nemo did should have been good enough to
prove even some NASTY looking old belts wouldnt fail
the 3" material... EVERY failure he had in his testing
failed the hardware...(BIG NOTE) we dont have to replace
hardware until after the 5th re-cert... just the belt
material gets replaced... NHRA OR SFI should try
testing once in a while
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: Thumperdart] #1733067
01/19/15 12:10 PM
01/19/15 12:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW Nascar belts that are 5 year are NOT SFI approved. They are FIA approved. Also ALL SFI belts in ANY sanctioning body are good for two years, not just drag racing. Maybe your local dirt track guys can use them forever but most every sanctioning body out there has the same belt rule. Not unlike outlaw(non sactioned)drag tracks could care less about safety for the most part.
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: Al_Alguire] #1733068
01/19/15 12:51 PM
01/19/15 12:51 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I signed,it may take us refusing to run at NHRA tracks for a year or two to make them listen.I have yet to have any of my cars checked at the track much less the seat belt date checked!If I buy a set of belts and after 6 months they looked worn,I have enough Daymn sense to know they need changing and will change them rather the date is out are not.
NHRA seat belt rules =BS!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: MRMOPAR622] #1733069
01/19/15 01:00 PM
01/19/15 01:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Basically 2 things get checked each time I hit the
tech.... seat belt date and helmet... beyond that
they really dont check much if anything... US131
checks that and they make SURE the engine dies when
they hit the master
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: MR_P_BODY] #1733070
01/19/15 01:03 PM
01/19/15 01:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Some of us have no choice but to run NHRA tracks as there are no others. Like out west here, it is NHRA or find a new hobby.
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: Al_Alguire] #1733071
01/19/15 01:25 PM
01/19/15 01:25 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
Al, try Tucson. It is IHRA.
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: mopacltd] #1733072
01/19/15 01:42 PM
01/19/15 01:42 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
My worst fear came true.. I signed the petition and now I'm getting bombarded with (spam) email for other causes..
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: Jeepmon] #1733073
01/19/15 01:59 PM
01/19/15 01:59 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
you missed unchecking the little box
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: sixpackgut] #1733074
01/19/15 02:03 PM
01/19/15 02:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not me... it just brought up another page that you
had to hit submit so your name didnt show
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: MR_P_BODY] #1733075
01/19/15 02:35 PM
01/19/15 02:35 PM
PA.
"Little"John
"Little"John
PA.
3459 signed so far. At least that's to many for NHRA to totally ignore. May not help but it sure as heck can't hurt.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: pittsburghracer] #1733076
01/19/15 03:19 PM
01/19/15 03:19 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Signed.
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: pittsburghracer] #1733077
01/19/15 03:44 PM
01/19/15 03:44 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
Signed... and hoping
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: Dart Racer] #1733078
01/19/15 04:23 PM
01/19/15 04:23 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Signed as well. BTW Sweet Dart, Dart_racer
-Kenny
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: Dart Racer] #1733079
01/19/15 04:36 PM
01/19/15 04:36 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Good luck and all that, but in reality you have 3 choices. Put belts in every 2 years, run at outlaw tracks or stay home. It's their playground, their rules.
I'm not a big cheerleader for NHRA, but I've raced at tracks with zero tech and I've done tech at an NHRA track. Both experiences were often times very scary. With everything else that it takes to go racing, a lousy set of belts is way down the list of crap for me to lose sleep over. They're a consumable, like tires, gaskets, fuel, oil.
Without safety being a priority, there is no insurance. Without insurance, there is no racing. Why do you think your new street car has all the safety devices and designs built in? Lawyers and insurance companies.
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: pittsburghracer] #1733080
01/19/15 05:34 PM
01/19/15 05:34 PM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
Done, I doubt that they listen but we need to try. Brawler
Re: Petition to change seat-belt rule from 2 to 5 years. [Re: CMcAllister] #1733081
01/19/15 07:21 PM
01/19/15 07:21 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
This right here. This rule has been this way for years and is not going to be changed. Guys have class cars that cost up to 100k and complaining about a $150 set of belts every two years...........ok then. You want to start a petition, how about something that you MIGHT actually have a chance with.........like maybe lower entry fees for sportsman classes.
I have NEVER understood the uproar over this deal
Monte
