Page 2 of 5 1 2 3 4 5
Re: The great oil pan gasket question for big block mopar [Re: hemi-itis] #2033625
03/18/16 08:26 AM
03/18/16 08:26 AM
IN
ahy Offline
ahy  Offline
IN
Last one I did was with a pair of Felpro cork gaskets with spray adhesive on one side and dry on the other + a small amount of silicone on the rear seal and timing cover areas per directions. No leaks. It does require a flat pan.
If you are worried about flatness and do use silicone, it is important to install and tighten finger tight only, let it set up for several hours then tighten gently. Wet silicone can soften the gasket and acts as a lube making it split and squeeze out.
Re: The great oil pan gasket question for big block mopar [Re: ahy] #2033654
03/18/16 09:52 AM
03/18/16 09:52 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I notice that after a couple of heat cycles on a new engeine, the pan bolts tend to loosen and need to be retorqued.
I use regular old Felpro gaskets but applied black silicone to the pan rail of the block and then put my gasket on. Despite all the bolts being loose, I didn't have a single leak. I retorqued for good measure. The valve covers and transmission pan are the same way.
I do make sure all the surfaces are cleaned with brake parts cleaner first. I took great pains with the rear main seal cap and even ran a bead of black silicone on the inside of both edges where it meets the block.
My 505 is the first engine I've built that doesn't leak a drop!
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2033866
03/18/16 02:49 PM
03/18/16 02:49 PM
AndyF Offline
AndyF  Offline
Summit now has a silicone covered steel gasket like the 727 pan gaskets. It is 0.200 thick so that might cause problems or help with clearance depending on the situation.
I've tried all of the gaskets over the years and I think the best gasket depends on the pan. If you have a good solid pan rail then the Superformance gasket is a good bet.
I do have oil pan reinforcement rails available now as a product. I'll post a picture of them shortly.
Re: The great oil pan gasket question for big block mopar [Re: bee1971] #2034062
03/18/16 08:11 PM
03/18/16 08:11 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Originally Posted By bee1971
When ordering #2585 is that for a pair or one gasket ?
They are packaged 1 gasket per package. You need 2 with a windage tray
Also do they sell a rear main seal ?
Yes, Part #9383 includes 2 crank seal halves and 2 retainer side seals and instructions.
And some say to put #2585 on dry , while road hazard says put a bead of silicone on the oil pan rail ?
Instructions are included but in short, 1/8" "bead" of Permaex Ultra Black on the pan rail of stamped steel pans, noting usually required for fabricated pans with rigid rails, nothing on the block sides, nothing between the windage tray and gaskets either. Maybe a thin bead across the stock seal retainer.
Bought a new reproduction stamped 402 oil pan and windage tray , want to do it right while motor sits in car
I have the same pan on my Charger Test Mule. Be sure to check flatness of the timing cover to block rails.
Thanx Scott
Hope this helps you out thumbs
Greg
Re: The great oil pan gasket question for big block mopar [Re: GY3] #2034073
03/18/16 08:25 PM
03/18/16 08:25 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
That is the result of a soft gasket used to compensate for very irregular surfaces and is generally inexpensive. It will not retain bolt torque. Also tends to "wick" oil through the gasket causing external dampness that dust and dirt likes to cling to.
Put the #2585 pan gasket on my Charger Mule about 5 years ago. Bolts are still tight and no weeping through the gasket.
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2034107
03/18/16 09:28 PM
03/18/16 09:28 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thanx Greg
All Questions Answered
Peace
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2100972
06/30/16 06:35 AM
06/30/16 06:35 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Everything is apart , cleaned up and ready to install
Bought the billet rear main seal retainer kit from Mancini racing
Should I use the supplied rear main seal from Mancini racing or I also bought the Superformance rear main seal when I purchased there oil pan gaskets , thinking of using there rear main seal with the Mancini billet retainer
Then obviously using the double side black rubber o rings supplied with Mancini kit
Anyways , any other tricks used installing this Mancini racing billet retainer before I button everything up today
Superformance rear main seal work with the Mancini racing billet retainer ?
Siberian Huskies
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2101108
06/30/16 12:52 PM
06/30/16 12:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Use the superperformance rear main seal, offset about 1/8" from the parting line.
I use the ultra gray between the block and girdle.
Sounds like the superperormance pan gaskets are the way to go.
I used the Fel-pros with steel core, but not really impressed with them.
I have the Jegs windage tray/gasket on a different engine and it sealed up great.
I think the girdle kit uses studs and has the bolts with serrated surface to hold the pan on? My girdle kit was the older one from BCR.
Anyhow, a bit of blue loc-tite will help the oil pan bolts / nuts from loosening.
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2101200
06/30/16 03:34 PM
06/30/16 03:34 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
ZERO leaks with this windage tray / gasket.....
Re: The great oil pan gasket question for big block mopar [Re: 451Mopar] #2101305
06/30/16 07:24 PM
06/30/16 07:24 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thanx
Many have reported that the Jegs wind age tray rubber o ring oil pan gasket will not work with the factory 402 oil pan , or any factory oil pan for that matter because the mating surface on the factory pans is not completely smooth flat , factory pans have those recessed areas
Siberian Huskies
Re: The great oil pan gasket question for big block mopar [Re: bee1971] #2101485
06/30/16 11:42 PM
06/30/16 11:42 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I'm running a stamped hemi pan with the plastic steel O ringed windage tray/ gasket with no leaks at all... Make sure the oil pan rail is flat and bolt It down ......... Easy
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2101537
07/01/16 12:26 AM
07/01/16 12:26 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
One picture says a thousand words,,,,,,,,
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2101553
07/01/16 12:47 AM
07/01/16 12:47 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The Jegs windage tray/gasket works with the reproduction Hemi 6-quart oil pan.
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2101577
07/01/16 01:14 AM
07/01/16 01:14 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Actually Jegs gets them from Magnum Automotive Group. Former Fel Pro guys that started there own gasket business
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2102868
07/03/16 08:22 AM
07/03/16 08:22 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Rear main seal leaks 100 times worse now then the one it replaced
New 402 oil pan and superformance gaskets are awesome
Put black rtv on the ends where it contacts the block , side o rings go into holes in the retainer on the ends then swing around the sides
Used the superformance rear main seal ,seal lip on both halves facing inward towards the crank
Only thing I didn't do was silicone the sides of billet retainer because I thought that was the purpose of the double o rings , you know to keep oil from leaking by the o rings
But after some more research ???
Anyways I am beyond pissed
Any better o ring material for those side seals that I can pick up locally ??? They fit in the tiny holes on the end of retainer nicely to hold in place , but coming down the sides you have to keep them in place in the grooves while sliding down the retainer inward on the block , wish the rubber was a little wider
Black rtv or Copper on the sides of retainer , yes or no ???
Should I offset the rear seal more then a 1/8" so it's not flush with the parting line of block
Also the superformance rear main seal versus the Mancini rear seal supplied with kit , any differences ???
Sorry guys for all the questions , not a happy camper right now , missing out on a car show today
Siberian Huskies
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2102886
07/03/16 09:15 AM
07/03/16 09:15 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
This is how I do it, no leaks always dry. In the car you will need a helper for the first test. Push the retainer up against the crank with the seal in the retainer, don't off set the seal. Measure the sides of the retainer to the block. Most likely the right and left sides will be different. Now install the bolts and remeasure. Did it change? If so open the bolt holes as they are off and pulling the seal off center. With this repaired (and it may take a different retainer). Personally I've found the stock retainer to work with no issues. Then follow this procedure. RTV along the the sides only. A small bead of anaerobic sealer between the cap and block. Fill the 45 channel at the back of the cap with RTV using a putty knife. This will be easier if the cut out in the crank flange is rotated to the side you're working on. Very important when using RTV on any surface to make sure it sticks. If you apply a thin film to both side with your finger it should stick to the surface. If it doesn't, just rolls off the surface is not clean enough. If you're careful and use a putty knife you may be able to remove the Super-Formance gasket with out ripping it. I service my race car motor by checking bearings every 100 passes and remove the pan and intake for inspection. As it uses a vacuum pump it needs to be sealed with absolutely no leaks. Hope this helps.
Doug
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2103080
07/03/16 02:41 PM
07/03/16 02:41 PM
AndyF Offline
AndyF  Offline
I started making oil pan rail reinforcements just because I saw a lot of guys having problems with stacked gaskets and the new rubber type gaskets. The steel pan will bend between the bolts and open up leaks. So now we're starting to put the rails on a lot of steel pan motors.
Re: The great oil pan gasket question for big block mopar [Re: bee1971] #2103641
07/04/16 02:04 PM
07/04/16 02:04 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Sorry to hear that.
Thanks for noticing the quality difference and your support!
IMO any seal worth it's salt should not need the aid of sealers.
Can't blame ya
I'm personally not a fan of the double o-ring cord, very difficult to work with
Offsetting more than 1/8" is not going to gain you anything. The purpose of offsetting is to be assured of seal half alignment.
I have no idea but can say that the Superformance Products rear main seal is a factory O.E.M Chrysler part.
Only suggestion I have is to tear back into it being mindful upon disassembly to watch for clues to what may have gone wrong. My best guess from miles away is the o-ring cord is possibly folded under the retainer, not allowing it to sit flush on the block. Find a retainer that uses the factory style grooves and install the Superformance retainer seals, they work.
Re: The great oil pan gasket question for big block mopar [Re: roadhazard] #2103946
07/04/16 09:29 PM
07/04/16 09:29 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thanx guys
Took it apart early this morning
Looked like oil getting past side retainer o rings , and I didn't clock the two piece seal like I thought . It was seated flush or parrellell with block lines
Not happy with my factory retainer ,, looks pretty beat up
Does Mopar or someone reproduce factory retainers ??? Hopefully i don't need to head in that direction
So found some other threads , research
I made sure this time I clocked the rear main seal itself , then did a dry fit with the billet retainer using the alignment rods
Did this dry fit a few times
However upon suggestion , I used black rtv on the sides of the billet retainer , and a little on the bottom ends
The superformance gaskets , I was able to use a putty knife on the four small spots of rtv to separate the gasket from the block . Sweet , came apart perfect , very very nice
Will fire it up tomorrow or in a few days
If this doesn't work
There will Bee a 71 Bee at the local dump
Siberian Huskies
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2104058
07/05/16 01:17 AM
07/05/16 01:17 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Sounds like your on top of it
