Re: 416 INDY 245RP Head Dyno #'s..... [Re: a408swinger] #173058
12/23/08 05:20 PM
12/23/08 05:20 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Why such high timing? What was the difference with say 33-34* vs. 39*
Here was 33 degrees....on E85
INDY CNC heads always seem to like timing.
Re: 416 INDY 245RP Head Dyno #'s..... [Re: RyanJ] #173059
12/23/08 07:15 PM
12/23/08 07:15 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Nice write up. I bet that guy is gonna be happy now.
Re: 416 INDY 245RP Head Dyno #'s..... [Re: 69Cuda340S] #173060
12/23/08 09:41 PM
12/23/08 09:41 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
I hope so, he was there watching it run & took it home with him
Re: 416 INDY 245RP Head Dyno #'s..... [Re: RyanJ] #173061
12/24/08 10:39 AM
12/24/08 10:39 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Nice Job Ryan......... I bet that dude thinks your a gwad
A 100HP is not easy to come by
Re: 416 INDY 245RP Head Dyno #'s..... [Re: 340RICK] #173062
12/24/08 10:48 AM
12/24/08 10:48 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Not hard when your rings don't seal.
Barton told him you can't put a roller cam in 59* R3.... this must be about the 20th one I've done.
These Advanced Profile Stainless Total Seal rings were new to me.... He wanted to do a small N20 shot, we could'nt get Hellfires in this bore size, so Total Seal talked me into these stainless AP's. They seemed to seal up quicker than the normal moly stuff. Usually it takes about 4 pulls to fully seat the traditional Moly stuff, these seem to be set after 2 pulls.
Re: 416 INDY 245RP Head Dyno #'s..... [Re: RyanJ] #173063
12/24/08 12:21 PM
12/24/08 12:21 PM
Canada
lenweiler Offline
lenweiler  Offline
Canada
I guess if it's not a hemi...
Damn! I dropped my change.............
Re: 416 INDY 245RP Head Dyno #'s..... [Re: RyanJ] #173064
12/24/08 05:43 PM
12/24/08 05:43 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Do you mind sharing any pics of how you clearanced the block for the roller lifters?
Re: 416 INDY 245RP Head Dyno #'s..... [Re: Forest] #173065
12/24/08 05:46 PM
12/24/08 05:46 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Same way I do them all on the CNC....
Re: 416 INDY 245RP Head Dyno #'s..... [Re: RyanJ] #173066
12/24/08 05:48 PM
12/24/08 05:48 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
X
Re: 416 INDY 245RP Head Dyno #'s..... [Re: RyanJ] #173067
12/24/08 06:04 PM
12/24/08 06:04 PM
Renton Washington
Triple Threat Offline
Renton Washington
Very nice work Ryan.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 416 INDY 245RP Head Dyno #'s..... [Re: RyanJ] #173068
12/24/08 11:38 PM
12/24/08 11:38 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Ryan, just wondering what your take on what the bore finnish shoud be. My engine builder was of opinion that there should be an almost a polished finnish. He said he is open to other approaches but that this has worked for him in the past.
I know you mentioned that the bore was overly cross-hatched. So, what is the "right" way to finnish the bore for best ring seating? Thanks!
Re: 416 INDY 245RP Head Dyno #'s..... [Re: B1Fish540] #173069
12/24/08 11:48 PM
12/24/08 11:48 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
A keeper post.Thanks
Re: 416 INDY 245RP Head Dyno #'s..... [Re: DavidDean] #173070
12/25/08 06:39 AM
12/25/08 06:39 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Soo.. you guys don't have a wide-band on that dyno? Looks like you're using airflow and fuel flow data to arrive at your A/Fs?
Re: 416 INDY 245RP Head Dyno #'s..... [Re: B1Fish540] #173071
12/25/08 10:21 AM
12/25/08 10:21 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
We use a Sunnen SV10 Diamond hone.... obviously we use a TQ plate & we finish with 500 grit diamonds. Then plateau brush the cylinders......my machinist does not own a profilometer, but he has access to one & has borrowed it a few times to check the RA of various projects we have worked on like deck finish & bore finish etc. Normally the 500 grit diamonds & a plateau finish is in the 18 RA range. The computerized diamond hone is able to measure taper & OOR as it is honing unlike a traditional stone hone that just moves up & down at a set rate & removes set amt of material everywhere. The diamond honing head "senses" pressure changes on it.. The Diamond hone has computer graph showing real time cyl wall taper as it is honing, it shows where the high & low spots are in the cyl, & it will dwell in certain areas to straighten the cyl.
Most performance rings today want the cyl wall finish almost as smooth as you can get it. Anywhere form 10-24 RA normally.
I dunno what the cyl wall finish was on this R3 when it came to me but it was second worst one I've ever seen. It had seven dyno pulls on it & you could take your fingernail & drag it across the cross hatching & it would "catch" your fingernail. My machinist looked at it & said it almost appeared that they never changed from their roughing stones to their finishing stones when it was honed, but the size was on, so it was like they did the whole job with a roughing stone. The moly rings did'nt like that at all.....
& No the dyno shop I use does not have a wideband, they read EGT's on their methanol Sprint car engines they build daily. I am getting a set of superflow EGT bungs for my new dyno headers here now that I finally got them operational.
Re: 416 INDY 245RP Head Dyno #'s..... [Re: B1Fish540] #173072
12/25/08 10:24 AM
12/25/08 10:24 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I would think it depends on what type of rings your are using, but that is the limit of my knowledge on this subject. Matt
Re: 416 INDY 245RP Head Dyno #'s..... [Re: MattW] #173073
12/25/08 10:32 AM
12/25/08 10:32 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
& yeah I should have prefaced by saying 90% of motors I do uses about the same rings. Speed Pro/Mahle/Total seal .043" or 1/16" plasma molys. The other 9.9% get Total Seal TNT's or Speed Pro Hellfires. & this motor just happened to get a set of Stainless. If I built Winston cup or Pro stock or Comp eliminator motors I'd taper the cyl wall finish more to each individual ring type. But for the traditional moly & hellfire type stuff I've had exceptional results with the 500 grit & plateau finish.
Re: 416 INDY 245RP Head Dyno #'s..... [Re: RyanJ] #173074
12/25/08 03:19 PM
12/25/08 03:19 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Thanks for the great info Ryan! Sounds like my engine builder had the right idea on this. Your attention to detail is amazing, enough to make me wanna go small block. I have been thinking i'd like to do one with Commando heads for an upcoming project. I know who i want to build it..
