Re: M1 intake for a 505 street stroker? [Re: Dabee] #1726958
01/13/15 01:35 AM
01/13/15 01:35 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thank you.........I laugh(sometimes)when I hear about guys that can`t get a single plane to work on a fairly mild combo........kinda like t-rams do`t work down low. Get the carb clean and tune right and I`ll take the single almost always.........
What makes you think I said I can't get the single plan on my 511 to work right. It works fine. All I said was "If I did it again I would go with a duel plane". My car is street driven, has AC, PS, PB, weighs 4000 lbs, a GV and a small cam that runs out of steam around 5400. It's only turning 2400 RPM at 70 MPH thus no advantage in running a single plan.
Pay attention boy, My response was to twostick so don`t be so jumpy and take a chill pill.............
Re: M1 intake for a 505 street stroker? [Re: Thumperdart] #1726959
01/13/15 12:27 PM
01/13/15 12:27 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The indy dual plane if you have a good (non core-shifted casting is an excellent 500" manifold, it needs a little lower plenum transition porting to the runners but flows VERY well.
I also like a well-ported Holley Street Dominator for that combo, easier to port than the M1 (which has tall/narrow runners) on a 500", I had one on my old 508" RB with ported Stage V heads that had an ~3.25 sq Inch port cross section which is about the ideal balance of maintaining great velocity and still giving you sufficient flow and power above 5500 rpm with the 500 inches.
The only other real drawback to the M1 single (other than it's rather "bland" to look at under the hood) is it's pretty tall for a stock hooded B or E body.
WIZE
In Car:
Re: M1 intake for a 505 street stroker? [Re: Streetwize] #1726960
01/13/15 08:56 PM
01/13/15 08:56 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Yes. I remember picking out the Indy dp and the Mopar Nationals years ago at the Indy tent. They had 3 or 4 to choose from at the show, I picked the one with the least amount core shift
