Re: Looking for some Dart pics and info...
[Re: Mtn Thunder]
#1726215
01/13/15 01:21 AM
01/13/15 01:21 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
345/40/17 on an 11" wheel with 7" backspace. Slightly narrowed Dana.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#1726217
01/13/15 02:38 AM
01/13/15 02:38 AM
Posts: 1,292 Tucson AZ,
MadMopars
Tucson AZ,
That's more than a mini tub, correct? Looks like alot of tire and with the 11" rim I'd think it would have to be.
[Re: MadMopars]
#1726219
01/13/15 03:48 AM
01/13/15 03:48 AM
topfueldart
Renton Wa
Just a standard mini tub, springs centered on the rail, factory tubs. It is a tight fit though, couldn't go any bigger.
