What is a good Handheld Auto Diagnostic "auto scanner"? #172595
12/21/08 08:34 PM
12/21/08 08:34 PM
ohio
70shaker6pk Offline OP
super gas
super gas
ohio
Re: What is a good Handheld Auto Diagnostic "auto scanner"? [Re: 70shaker6pk] #172596
12/22/08 12:47 AM
12/22/08 12:47 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I have one of these..
http://www.amazon.com/Equus-3030-Diagnos...1166&sr=1-3
No complaints, works simply and as advertised. For a few dollars more is an Actron that can be upgraded.. not sure why I didn't opt for that one, probably something to do with the Amazon customer reviews of each though..
Re: What is a good Handheld Auto Diagnostic "auto scanner"? [Re: Exit1965] #172597
12/23/08 09:13 AM
12/23/08 09:13 AM
ohio
super gas
super gas
ohio
Thanks for your help.
Re: What is a good Handheld Auto Diagnostic "auto scanner"? [Re: 70shaker6pk] #172598
12/23/08 10:34 AM
12/23/08 10:34 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
really depends on usage. If this is for a pre-OBDII vehicle of your own, you don't need the same power a guy that is doing warranty work on new stuff needs.
There are used/new scanners, software you can load into a laptop, and all-in-one smart boxes that also are powerful O-scopes. Just like any tool, budget and use determine what you need.
Re: What is a good Handheld Auto Diagnostic "auto scanner"? [Re: RodStRace] #172599
12/23/08 12:01 PM
12/23/08 12:01 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It really depends on the car you need it for. I still don't know what Chrysler did differently on the intercooled cars, but I have not found an inexpensive (about $200 or less) scanner that will fully work with my 89 LeBaron GTC. I have one now that will only read the stored codes, but it the same info that I can read out of the dash. By contrast this same scanner will give me live readout from my wife's 95 LeBaron (3.0).
After dealing with Actron and autoxray, I would look elsewhere.
Re: What is a good Handheld Auto Diagnostic "auto scanner"? [Re: Jim_Lusk] #172600
12/23/08 11:09 PM
12/23/08 11:09 PM
ohio
super gas
super gas
ohio
I work out of my home garage on all different makes so i didn't really know what i would need. I have been looking around but they do make alot of different ones.
Thanks again for everyone's help.
