Re: Converting an AMP gauge to a VOLT gauge at home?
[Re: Mr340]
#1725935
01/11/15 09:07 PM
01/11/15 09:07 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Thanks, I might try painting the needle the proper color and changing the blue stripe to white, and leave the numbers as is.
I like this idea. I bought this SunPro voltmeter because its the only one I could find for this purpose. The other closest voltmeter I could find is a vintage Smith volmeter from an MGB. And they varied by year. Smiths voltmeter
[Re: GLR]
#1725937
01/11/15 11:26 PM
01/11/15 11:26 PM
Vert
Annapolis, MD, USA
MGB and most British sports cars used Lucas electrical components. Lucas ak The Prince of Darkness. I always carried gun *GUM* with foil wrappers to replace the popped fuses I had regularly. It would get you home, and doubled for setting timing in a pinch.
[Re: I_bleed_MOPAR]
#1725939
01/12/15 02:17 PM
01/12/15 02:17 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
How about the Dodge pickup guys. My amp gage fried years ago before I bought the truck. The previous owner cut the wires and put in an after market gage. Works OK, but I really don't like the look. Here's a pic to let you see what I mean (you can see the after market gage lower right of the Tuff wheel spoke). URL=http://s51.photobucket.com/user/duster416/media/myampgage0012_zps6a9bd5b0.jpg.html] ![](http://i51.photobucket.com/albums/f355/duster416/myampgage0012_zps6a9bd5b0.jpg) [/URL]
[Re: Cudajon]
#1725942
01/13/15 05:18 AM
01/13/15 05:18 AM
bigblock340power
Elk Grove, Calif.
Easy one. Just go get a gage and do it. Do try and use a good gage. Also while your in there check the 5volt limiter. The newer trucks used a electronic unit, it will be mounted on the pc board. I'll bet you can find everything you need at a salvage yard. Pick up a spare Instrument panel if you can and experiment away.
I do have an extra Instrument panel. Any ideas as to what gage to look for (and 5 volt limiter)? Out of what year trucks (would help me to narrow down the search)? Thanks, M
[Re: Mr340]
#1725943
01/13/15 10:06 AM
01/13/15 10:06 AM
Posts: 2,554 Maryland
wally426ci
Maryland
Did you also change the needle? usually the sunpro is red.
What Sunpro gauge is this? I need to do the rallye dash in my 71 Challenger...
Looks nice!
[Re: bigblock340power]
#1725944
01/13/15 10:10 AM
01/13/15 10:10 AM
wally426ci
Maryland
To the truck guys. I run this in my Sweptline and it is working out pretty well: http://www.ebay.com/itm/Summit-Electrica...=item5b07cc5d0cHere is my How-To text from the Sweptline site: Ok, I struck out twice trying to locate a volt gauge that I could install in place of my AMP gauge. I normally like everything to be factory but I started wondering after my electrical melt down that took place at the end of the summer. First I ordered an NOS gauge from an early Chevette (i know :joker ) but USPS lost it. Then I ordered a 95 Jeep piece but when it came I couldn't figure out how in the heck to hook it up or mount it. I found this little Gem from Summit: Here you can see where I have removed the metal face ring. AFter that I went around the glass seal (thin black metal) and pried it back with a flat screw driver (along the seam). Once I had those 2 pieces off, I un-bolted the mounting nuts from the back of the canister and slid it out. What I was left with was a bare gauge with 2 studs similar to the AMP gauge. The face is made of thin plastic. The bulb that comes with the gauge is a push in style filament. I grabbed some green LED bulbs to use in my gauges and radio. You will see that I test fitted it with a 68 style gauge face and then an earlier round gauge face but using the 68 housing. You could mount it lower in the housing in order to show the numbers better. At the moment I don't know if I will just cover the Summit logo or if I will use the gauge overlay to make it appear like an AMP gauge. The one small problem is going to be that it is round and the stock gauge is sqaured off. The problem will result in some of the sticker overhaning with nothing to stick to. Leaving it alone will result in a bit of air space between the outside of the gauge and the faceplate. At the moment (untested) I have it mounted in the housing with the 2 studs. 1 will receive ground simply by being directly bolted to the housing which grounds with mounting and via a white wire that runs to the fuse block mounting screw(s). I isolated the positive side with a firewall grommet found at NAPA. Outer diameter of that grommet is 7/16" with roughly a 1/4" opening. I drilled out one of the factory AMP gauge holes and left it centered where the original gauge was. Here is a link to the white gauge overlays (you can get any color or go black for an extra $30 ![](/ubbthreads/images/graemlins/tongue.gif) ale a little pricey for "stickers" I could get really creative and remove the plastic gauge face and replace it with the AMP gauge face but the mounting holes are slightly off so I would have to have an adapter. I thought about cutting up another gauge for the thin aluminum to use as an adapter but not thinking that I'll go that way. I need to add pictures if anyone here is interested...
[Re: wally426ci]
#1725946
01/13/15 10:14 AM
01/13/15 10:14 AM
wally426ci
Maryland
The summit gauge next to an original AMP gauge (68 dodge truck)
[Re: wally426ci]
#1725947
01/13/15 10:26 AM
01/13/15 10:26 AM
Posts: 2,506 Northern Pa
GLR
Northern Pa
Shawn it is this gauge from Autozone
Sunpro/Custom line electrical voltmeter Product Search
Sunpro/Custom line electrical voltmeter Not Vehicle Specific Part Number: CP7985
Alternate Part Number: CP7985 Pick Up In Store: Out of Stock
Features & Benefits
Sunpro Custom Line gauges feature a clean, easy-to-read look with blue line styling against the black 2 In. dial face. Monitor alternator performance and output from 8 to 18 V with the Custom Line 2 In. black dial face electric voltmeter.
Features black bezel and removable black mounting panel Includes gauge and mounting hardware, requires hook-up wire Designed for 12 Volt negative ground systems, and includes 12 Volt internal lighting 8 to 18 Volt, 60° sweep
Product Details Part Number: CP7985 Weight: 0.45 lbs Type: Voltmeter Face: 2 in. Size: Black Face Bezel Color: Black Depth (in): 3 Face Color: Black Function: Analog Height (in): 7 Liquid Filled: No Measures: Volts OEM Replacement: Yes Pointer Color: Red Range: 8 To 18 Volts Sensor Type: Electric Sweep Degree: 60 Width (in): 4.25 Writing Color: White
