Page 1 of 3 1 2 3
Converting an AMP gauge to a VOLT gauge at home? #1725910
01/09/15 05:45 PM
01/09/15 05:45 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
With the help of Moparts members ,I tested all my gauges and they all work!...Thank you!
My next question is; I know I can send my AMP gauge out to have it converted to a VOLT Gauge, but wanted to know if anyone has done this at home? If so.. can someone walk me through the process?
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725911
01/09/15 06:02 PM
01/09/15 06:02 PM
Andrewh Offline
Andrewh  Offline
not exactly convert but swap.
https://board.moparts.org/ubbthreads/show...amp;Search=true
they make various ones that point up or down.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Andrewh] #1725912
01/09/15 07:23 PM
01/09/15 07:23 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I've been wanting to do the same thing, I just wish someone would make those vinyl sticker kits w/ one to convert a sunpro volt meter in place of the ampmeter but have the same colors & font's as the OEM gauges...that way it would look truly OEM.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: shanker] #1725913
01/09/15 07:42 PM
01/09/15 07:42 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: CSK] #1725914
01/09/15 08:49 PM
01/09/15 08:49 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Stand by... I am working on my volt gauge conversion for 71-74 B-body..I will take a picture when completed if anyone is interested..message me or e-mail me; glr7069@ptd.net
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: CSK] #1725915
01/10/15 02:17 PM
01/10/15 02:17 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
web page
I'm trying to do it to a 74 Ramcharger I'm doing an OEM restoration of the dash on....so those are no go for me
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: shanker] #1725916
01/10/15 06:51 PM
01/10/15 06:51 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
As I showed in the article you can probably use the original face plate. It will not be reading amps but volts. You want be able to tell how much voltage though.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Cudajon] #1725917
01/10/15 08:43 PM
01/10/15 08:43 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Well, I worked on my conversion from my original AMP gauge to an aftermarket VOLT gauge. I am posting pictures of the gauge installed into the original housing <-that I had to modify.
I removed the "aftermarket gauge Face" and drilled the "original gauge Face" so that I could use the original screws that held on the aftermarket face to the aftermarket volt gauge.
Tested after I installed and works great!... It took me about 10 hours to do this conversion.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725918
01/10/15 08:43 PM
01/10/15 08:43 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
2ND PIC
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725919
01/10/15 08:44 PM
01/10/15 08:44 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
3RD PIC
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725920
01/10/15 08:45 PM
01/10/15 08:45 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
4th picture
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725921
01/10/15 09:54 PM
01/10/15 09:54 PM
Looks good to me & in fact I'd speculate that to the untrained (non Mopar) eye they would not even suspect that it ain't OE
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: RapidRobert] #1725922
01/10/15 10:11 PM
01/10/15 10:11 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thanks Robert!...
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725923
01/10/15 11:02 PM
01/10/15 11:02 PM
Europe
rory73 Offline
rory73  Offline
Europe
That's quite cool, thanks for sharing!
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725924
01/11/15 12:16 AM
01/11/15 12:16 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Well done! Looks really good & you'll be at ease with not having to worry about a faulty or corroded ammeter. I've done the voltmeter conversion twice & glad I did.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Triggerfish] #1725925
01/11/15 12:26 AM
01/11/15 12:26 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thank you Tim and Buzz...
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725926
01/11/15 11:00 AM
01/11/15 11:00 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Very nice work, Gary. What brand gauge did you use?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: I_bleed_MOPAR] #1725927
01/11/15 11:18 AM
01/11/15 11:18 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Tim, I used a Sunpro gauge part number CP7985
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725928
01/11/15 04:11 PM
01/11/15 04:11 PM
Buford, GA
Buford, GA
'71 Charger 383/727
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: I_bleed_MOPAR] #1725929
01/11/15 04:42 PM
01/11/15 04:42 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thank you!...
Page 1 of 3 1 2 3
