Page 2 of 3 1 2 3
Re: Which Hemi Head? [Re: gsmopar] #1725480
01/12/15 03:56 PM
01/12/15 03:56 PM
From what I've seen so far, the Stage V is about 2k more than Edelbrock and flows about the same?
You can't compare two different flow benches in two different locations on two different days The results are not the same Been there, done that Even have two different techs setting up and flowing the same heads on the same bench the same day can affect the results
Re: Which Hemi Head? [Re: 1320Dart] #1725481
01/12/15 04:08 PM
01/12/15 04:08 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The trick is to get Stage V to answer their phone.
Eric is busy so answering the phone is not a high priority, but he will respond to emails.
Head flow - I hesitate to make a comment here but... (there's always a but), Mid 400s is correct for a good CNC'd street, 16 bolt, head. It's the bolts next to the intake runner that limit opening the ports so a tennis ball will drop through. I'll just throw this in but the 10 bolt Millenium head can flow over 500 CFM without too much effort and FHO has got the high performance version of that head, with their special CNC program, to flow high 500s.
Re: Which Hemi Head? [Re: Mopar_Rich] #1725482
01/12/15 04:14 PM
01/12/15 04:14 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Question for you Rich: On the 10 bolt millennium heads, I have heard that there is some type of adapter avaialable to put a 16 bolt intake manifold on it, instead using a custom sheet metal intake. (I am thinking a bout a class that requires cast intakes) Is that so, and what would be lost by using the adapters and a cast tunnel ram?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Which Hemi Head? [Re: Hemi_Joel] #1725483
01/12/15 04:59 PM
01/12/15 04:59 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Yes. There are 1/4" and 3/8" spacer plates that allow a stock style manifold to bolt to the Millennium head (see pic). I used these on a 1800 HP blown alcohol HEMI that ran pretty well but ultimately was flow limited. Stage-V has these.
BTW: I feel I should make a comment about "shooting for high flow numbers". Most people want streetability and that requires velocity! High flow numbers have poor velocity at lower RPMs. When I was building HEMIs everybody wanted high flow numbers but it was the lower flow/higher velocity heads that people liked better. Unless you are building strictly a race motor that will never see less than 5000 RPM, stay with the smaller head. Heck - on a dyno pro-stock builders don't even start the pulls until 7000.
Re: Which Hemi Head? [Re: Hemi_Joel] #1725484
01/12/15 05:06 PM
01/12/15 05:06 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Indy hemi tunnel rams come in 10 bolt as well as 16 bolt. I think I remember reading somewhere that there's no standard for where the holes go when manufacturers go to 10 bolt so Indy 10 bolts may not line up with Stage V 10 bolts.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Which Hemi Head? [Re: d7cook] #1725485
01/12/15 05:13 PM
01/12/15 05:13 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Flange spacing on Millennium heads is different. A 10 bolt INDY will not just bolt on. Spacers are required.
Re: Which Hemi Head? [Re: Mopar_Rich] #1725486
01/12/15 05:23 PM
01/12/15 05:23 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Rich,
Not to highjack this thread but, if a guy were to go to an all out bracket effort, 2 carbs, 588-604 CI, big roller, and 15+ compression, what head would you pick, and what HP level could be realized?
Re: Which Hemi Head? [Re: Mopar_Rich] #1725487
01/12/15 05:26 PM
01/12/15 05:26 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I agree with Cab_Burge, flow numbers vary a lot from machine to machine and who's doing it. Nevertheless, here were the flow numbers I had with a 16 bolt Millennium head using spacers and a single 4500 INDY manifold. This 572" HEMI made 962 HP on pump gas.
Re: Which Hemi Head? [Re: camastomcat] #1725488
01/12/15 05:33 PM
01/12/15 05:33 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Rich,
I'd use the high flow Millennium 10-bolt head, CNC ported by FHO, and a sheet metal intake. Hogan has done several for me and FHO so they know what to do. I'm doing a motor right now that sounds just like the same motor. There are a lot of other variables as you know, and you have to build it to support the RPMs required, but 1200 HP is very achievable.
Re: Which Hemi Head? [Re: Mopar_Rich] #1725489
01/12/15 06:35 PM
01/12/15 06:35 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Rich,
Last question and I'll go away, what would you expect a ported Millenium head package, less short block and accessories to cost? I will be very interested in how your project goes. Also, the RPM's you expect to run.
Re: Which Hemi Head? [Re: Mopar_Rich] #1725490
01/12/15 06:48 PM
01/12/15 06:48 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Is that a KB aluminum hemi block and if so, what do you do for the big gap where the step is in the valley area? My Indy valley cover doesn't work.
Re: Which Hemi Head? [Re: Sammy] #1725491
01/12/15 06:57 PM
01/12/15 06:57 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I had that gap with my B1's and the Indy valley plate too. I just filled it with silicone, and smoothed it out, let it dry overnight, and it worked fine. It pulled 12" of vacuum that way.
Re: Which Hemi Head? [Re: camastomcat] #1725492
01/12/15 07:50 PM
01/12/15 07:50 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Not that small gap, With a Hemi KB block there is a huge step opening that won't allow the intake valley pan to cover completely to the head area.
Re: Which Hemi Head? [Re: Sammy] #1725493
01/12/15 07:57 PM
01/12/15 07:57 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Is it more than a 1/8-1/4 inch? That's what I had.
Re: Which Hemi Head? [Re: camastomcat] #1725494
01/12/15 08:18 PM
01/12/15 08:18 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Cost? Not to be sarcastic, but you'll spend as much for the head prep and machining work as you spend for the heads. Call Tim at FHO and see what he'll do. He has some new bronze alloy seats that are just beautiful.
For the bracket HEMI I'm building, I'm struggling with the compromises of reliability and low maintenance, vs power. To really use that flow we should be at least 8000 RPM but as I have said many times, "It's RPM that kills engines", so I'd like to keep the RPM down. I'm known for long lasting bracket engines, which is inconsistent with maximizing power. I'll probably drop the power down to 950 - 1000 HP because you don't really need the extra power for bracket racing.
Re: Which Hemi Head? [Re: Sammy] #1725495
01/12/15 08:24 PM
01/12/15 08:24 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
That was a World block. Yes, the gap (from the bottom of the spacer to the deck) can get quite large and with the Millennium heads it's even worse. So I made my own spacers and machined for the fit. That brought the gap down to a manageable level.
Re: Which Hemi Head? [Re: Mopar_Rich] #1725496
01/12/15 09:05 PM
01/12/15 09:05 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
And pictures of the spacers you made? I think mine might be leaking a little oil killing my vacuum.
Re: Which Hemi Head? [Re: Sammy] #1725497
01/28/15 12:41 AM
01/28/15 12:41 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I got my first quote for Stage V that flow ~450 and they're running about 2x the Hughes prepped Edelbrocks (also claiming about 450).
How's Hughes? Do they do good work, any personal experience, etc... I'm going to bug them this week and see if I can dig a little deeper than what's on their website.
Re: Which Hemi Head? [Re: Mopar_Rich] #1725498
01/28/15 08:46 AM
01/28/15 08:46 AM
Down under
O
OUTLAW565 Offline
OUTLAW565  Offline
O
Down under
As for flow numbers i think the NRE X1 H2O Hemi heads exceed the Millenium heads dont they?
Re: Which Hemi Head? [Re: OUTLAW565] #1725499
01/28/15 01:49 PM
01/28/15 01:49 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
As for flow numbers i think the NRE X1 H2O Hemi heads exceed the Millenium heads don't they?
Yes they do and so do the BAE fat heads. But these are both billet alcohol heads not made for street use.
Page 2 of 3 1 2 3
