Re: Seats, Steering Wheel, and Seat Belt Options...
[Re: Supercuda]
#1802486
04/13/15 04:32 PM
04/13/15 04:32 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I guess I am old school, but I hate today's fat steering wheels, I like the thin ones. with my big mits i hate the thin ones no one makes a aftermarket hub for bbody to run momo wheels - so I bought a cuda aftermarket hub, had it milled down at a machine shop and now I run a momo proto steering wheel
[Re: Lefty]
#1802586
04/13/15 07:13 PM
04/13/15 07:13 PM
Posts: 321 Massachusetts
Sneke_Eyez
Massachusetts
I've used this Momo om a couple of builds. Very nice feel when driving and goes well with your board name. Oh man, how did you get it to fit? That's the wheel I wanted to use in my Satellite, but between it being just over twice what I wanted to spend and not being able to determine if I could get a mounting kit for it for my Satellite, I gave up. I found mounts for everything from Chebbies to Ferraris, but nothing for B-Body Mopar.
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe. 2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast? Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com!
[Re: MuuMuu101]
#1802855
04/13/15 11:32 PM
04/13/15 11:32 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Are you mounting the wheel on the stock column? Do they have a kit?
A new iron curtain drawn across the 49th parallel
[Re: MuuMuu101]
#1802868
04/13/15 11:38 PM
04/13/15 11:38 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
So, I ended up pulling the trigger with a wide Corbeau LG1 in black Microsuede and a Momo Mod.07 steering wheel. The car will be getting a 5-point belt, but I'm unsure of what brand at the moment. The Dart is also getting an 8-point cage with a swing-out door. Going all out it sounds like !
[Re: 67autocross]
#1802881
04/13/15 11:44 PM
04/13/15 11:44 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Are you mounting the wheel on the stock column? Do they have a kit? That's up in the air right now. My column was a little messed up due to the last time I rebuilt it. I forgot to install something or installed it correctly and it caused radial play within the column and my turn signal lever to travel anywhere between 7 and 11 o'clock. If they can salvage my column, I believe they're going to try to make it removable. If not, they may try installing a tilt column.
[Re: OzHemi]
#1802883
04/13/15 11:46 PM
04/13/15 11:46 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
So, I ended up pulling the trigger with a wide Corbeau LG1 in black Microsuede and a Momo Mod.07 steering wheel. The car will be getting a 5-point belt, but I'm unsure of what brand at the moment. The Dart is also getting an 8-point cage with a swing-out door. Going all out it sounds like ! Definitely... Those seats are the only one that fit, the shop gets a discount on Momo products, and the cage is because I don't want to get seriously injured or die. Let's face it, these old cars are tin cans. If I crash at a high speed, or even on the streets, I'd like to be able to walk away from it.
[Re: MuuMuu101]
#1802884
04/13/15 11:46 PM
04/13/15 11:46 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Im going to adapt a 6 bolt adapter to a Grant adapter. They make 3 bolt to 6 bolt adapters. Mine is only 1/2" thick too, going with a 2.5-3" deep wheel.
Mopar to the bone!!!
[Re: MuuMuu101]
#1802949
04/14/15 12:37 AM
04/14/15 12:37 AM
OzHemi
Garden Grove, CA
So, I ended up pulling the trigger with a wide Corbeau LG1 in black Microsuede and a Momo Mod.07 steering wheel. The car will be getting a 5-point belt, but I'm unsure of what brand at the moment. The Dart is also getting an 8-point cage with a swing-out door. Going all out it sounds like ! Definitely... Those seats are the only one that fit, the shop gets a discount on Momo products, and the cage is because I don't want to get seriously injured or die. Let's face it, these old cars are tin cans. If I crash at a high speed, or even on the streets, I'd like to be able to walk away from it. I am going to feel left behind in the Torana
[Re: OzHemi]
#1802969
04/14/15 12:58 AM
04/14/15 12:58 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
So, I ended up pulling the trigger with a wide Corbeau LG1 in black Microsuede and a Momo Mod.07 steering wheel. The car will be getting a 5-point belt, but I'm unsure of what brand at the moment. The Dart is also getting an 8-point cage with a swing-out door. Going all out it sounds like ! Definitely... Those seats are the only one that fit, the shop gets a discount on Momo products, and the cage is because I don't want to get seriously injured or die. Let's face it, these old cars are tin cans. If I crash at a high speed, or even on the streets, I'd like to be able to walk away from it. I am going to feel left behind in the Torana No no no... You still have the superior LS engine.
[Re: 72Swinger]
#1803217
04/14/15 01:47 PM
04/14/15 01:47 PM
Sneke_Eyez
Massachusetts
Im going to adapt a 6 bolt adapter to a Grant adapter. They make 3 bolt to 6 bolt adapters. Mine is only 1/2" thick too, going with a 2.5-3" deep wheel. Post some pictures when you do it. I want a Momo wheel in the worst way.
[Re: Sneke_Eyez]
#1803488
04/14/15 07:13 PM
04/14/15 07:13 PM
Posts: 6,516 Santa Cruz, California
Lefty
I've used this Momo om a couple of builds. Very nice feel when driving and goes well with your board name. Oh man, how did you get it to fit? That's the wheel I wanted to use in my Satellite, but between it being just over twice what I wanted to spend and not being able to determine if I could get a mounting kit for it for my Satellite, I gave up. I found mounts for everything from Chebbies to Ferraris, but nothing for B-Body Mopar. I had to combine a Momo adaptor and a Grant adapter. It's been a few years, so I don't have the part numbers - Sorry... As I recall, the Grant adapts the Mopar column, then from the Grant to the Momo steering wheel adaptor to the Momo wheel.
[Re: MuuMuu101]
#1902857
08/31/15 12:22 AM
08/31/15 12:22 AM
Posts: 4,323 NY NY
340duster340
NY NY
any suggestions for aftermarket seats that have a vintage look to them?
i am building my 66 dart and would like it to look period-esque.
the low back kirkey's i kind of like, but want to see what other folks are running,
OP - what did you settle on here,
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#1902883
08/31/15 12:51 AM
08/31/15 12:51 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I got these because they're the only race seats that are wide enough for my hips and my shoulders that would accommodate a 5-point belt. http://corbeau.com/reclining-seats/lg1.htmlIf you want a kind of period-ish low back look, you may want to try these. http://procarbyscat.com/seats/Rally-LowbackBut they have other seats. http://procarbyscat.com/SeatsThey even sell adapters for our old mopars. Plus, you can get them from Summit.
[Re: Hooligan]
#1904319
09/01/15 07:14 PM
09/01/15 07:14 PM
Sneke_Eyez
Massachusetts
Welp, my 3-point conversions from Seatbelt Solutions arrived today, and they are excellent! BTW... made in the USA! Mine have the chrome hinge release instead of the button, and they look great! The only thing that is different from the OEM replacements is... the belts are 7 panel webbing instead of 4, like the factory belts. And the slider loop where the shoulder attachment bolt is located, does not drop down about 7"-8''. This causes the shoulder strap to ride up on my neck, so I will fabricate a drop down segment myself. It's well worth saving a 160 bucks!
Additionally, I don't see any 5-point harnesses on their website. I'd like to see some pictures!
