Re: Feedback on Viking double adjust shock ?
[Re: slammedR/T]
#1724752
01/30/15 10:07 PM
01/30/15 10:07 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Wow......... talk about going down a rabbit hole! The OP asked opinions about a fair priced seemingly decent shock and it's made it's way to pro stockers. I don't know anyone on here who runs one or qualified to comment on them other than their own opinion as far as that goes.
No point in me asking about Strange shocks now, as I now know unless they are Santuffs or custom valved they are junk, no matter how slow your car.
Come on warm weather!!!
Monte actually said the strange shocks are a good shock.
Talk to Mike Roth @ MR2 Performance..
I got Strange shocks through him. Very knowledgeable about shocks.
He told me for what I was doing, (S/ST) Strange was fine. BUT..
If I wanted the BEST Shock... "Santuff"
mr2performance@sbcglobal.net
-------------------- MR2PERFORMANCE RACE CARS 765 483 9371
Chris.. ![](/ubbthreads/images/graemlins/tonguue.gif)
[Re: Chris'sBarracuda]
#1724753
01/30/15 10:48 PM
01/30/15 10:48 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Right now I need shocks, santhuff's aren't in the budget so I'm going to get strange shocks to match the strange coilovers out back. But when i get new coilovers and struts I will save up for the santhuffs.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#1724754
01/30/15 11:21 PM
01/30/15 11:21 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Been watching all this shock talk for several months,,,I thought I needed new shocks to get my car to work right. I had a CE coilover setup on my car. I got Afco d/a for the rear. I put them on and saw NO measurable improvements even after a few weekends of adjustments. By NO measurable improvements, I mean what improvements in 60' I saw were probably not worth the $500.00 I spent. ![](/ubbthreads/images/graemlins/Twocents.gif) I guess I should have spent MORE money to get the results like others here say you have to spend. Probably, my old junk don't make enough HP to need any $$$$ shocks. ![](/ubbthreads/images/graemlins/shruggy.gif)
If you like drag racing, support your local track.
[Re: 1967dartgt]
#1724755
01/31/15 12:03 AM
01/31/15 12:03 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Some miss the point of what shocks DO. If your car works OK, you put better shocks on and don't change a thing on the car, you shouldn't expect results, because you haven't done anything. You have to maximize the combination.
On our car for instance, even on flypaper tracks, if we tried to push it much past a 1.14 or so 60ft, it would knock the tires off. Then we put the Santhuffs on and were able to push the car harder, with a best 60ft of 1.07 and doing that consistently. We now have the Menscer shocks and are pushing harder, with a best so far of 1.05, after one race of testing. Our goal now is to go a 1.00 flat on a radial. I think these shocks will allow us to do that.
So to summarize here...........if you car is dead hooking now, printing identical 60fts every pass and you do NOT have the ability to hit it harder, nor are you planning anything to hit it harder, you likely don't need shocks. But MANY guys do have consistency problems that many times can be related to shocks. Meaning on similar track and weather conditions, the 60fts vary a lot. If this is the case, you likely need shocks
Monte
[Re: Monte_Smith]
#1724756
01/31/15 12:25 AM
01/31/15 12:25 AM
slammedR/T
Monte
Think I'm gonna get with Menscer instead 7in cn rear and 4 inch front stock mt
Excellent control and user friendly adjustment. world record setting performance in an affordable package. Can be configured to mount in most stock mount applications. Packages starting at $949.00
that is a really good price and tuned to your car/truck
[Re: slammedR/T]
#1724757
01/31/15 02:06 AM
01/31/15 02:06 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Monte
He also does strange shocks, so he could revalve your existing shocks.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1724758
01/31/15 04:07 AM
01/31/15 04:07 AM
slammedR/T
Monte
I got single adjustables on rear, I want to go double on rear and front.
[Re: Thumperdart]
#1724763
02/14/15 05:08 PM
02/14/15 05:08 PM
BradH
That right there really pisses me off....................STILL makin em too short..............
My QA1 Rs have the same problem; I had to change the top mount bushings around in order to allow the suspension to extend fully w/o actually topping out the damper itself, yet still get the 5"+ travel from the static ride height Calvert told me I needed.
[Re: tboomer]
#1724766
02/14/15 07:20 PM
02/14/15 07:20 PM
Monte_Smith
North Alabama
Monte..For an off the shelf shock are all of the extended lengths standard? Just asking. Thanks!
No idea. But you have to realize that NO shock company is going to build an "off the shelf" specific shock, for every car out there. There may be some shaft and bottom mounting options, but for the most part the shock will be generic........Plus, what IS full droop for a given car?.....is every one the same?.........So these two simple questions tells you that the perfect fit shock for every car, is next to impossible. You want perfect, you need "custom"
Monte
[Re: Monte_Smith]
#1724768
02/14/15 09:06 PM
02/14/15 09:06 PM
Posts: 485 Central California
MoParFish
Central California
.......3/8 of an inch......really?...........we are complaining about 3/8 of an inch less travel. For one, you need to check and see if the shock even keeps the suspension from full droop and secondly, very few cars NEED that much travel anyway.
Monte
I think I was complaining more about the direction these threads turn sometimes, not about 3/8 of an inch. Was just reporting my findings between two shocks. I thought guys replacing Calvert with Vikings may find the info helpful. My Calvert front shocks DID slightly keep the suspension from full droop to which I added washers to compensate. With the Vikings I had to add more washers to the stud so the suspension was not hanging from shock at full droop on a '64 B Body. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: MoParFish]
#1724769
02/14/15 09:15 PM
02/14/15 09:15 PM
CHAPPER
Belpre,Ohio
Monte
If the washers cost $1000.00,,,you should be OK. Gotta' spend money to go fast. ![](/ubbthreads/images/graemlins/stirthepot.gif)
[Re: CHAPPER]
#1724770
02/14/15 11:09 PM
02/14/15 11:09 PM
Posts: 1,532 off the grid
340B5
off the grid
^^^^^^ ![](/ubbthreads/images/graemlins/laugh2.gif) Does Santhuff make washers?
Yeah, it's got a smallblock.
