Re: Vacume pump users, do you see water vapor? [Re: MR_P_BODY] #1724406
01/08/15 07:43 PM
01/08/15 07:43 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
It IS PRETTY... one thing... that vac line sure is
small... we are playing with a FAIR bit of volume
That is the vaccum line to the racepak sensor...the suction line to the pump is a -12 in the valve cover.
Re: Vacume pump users, do you see water vapor? [Re: Forest] #1724407
01/08/15 07:47 PM
01/08/15 07:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok.. got ya... thats much better
Re: Vacume pump users, do you see water vapor? [Re: Forest] #1724408
01/11/15 07:45 PM
01/11/15 07:45 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Moisture is normal for me too...you can see my vacuum line fitting in the valley plate.
Forrest what size is that push lock fitting you use for vaccum? Where did you get it?
Thanks, Don
Re: Vacume pump users, do you see water vapor? [Re: MR_P_BODY] #1724409
01/17/15 05:47 PM
01/17/15 05:47 PM
Cab_Burge Offline OP
I finally remember to take a picture of it, the system, after getting it mounted and working Forgive the Okie way of trying to temporalily hook a vacume gauge up to the bypass valve to set it:o I will buy a vacume gauge and hook it up the proper way
Re: Vacume pump users, do you see water vapor? [Re: Cab_Burge] #1724410
01/17/15 06:08 PM
01/17/15 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For testing purposes if you have a dip stick I just
pull the stick and clamp a hose to the tube and to the
gauge.. later I mount the point permanently, usually
in the back of the valve cover so its out of the way
Re: Vacume pump users, do you see water vapor? [Re: MR_P_BODY] #1724411
01/18/15 01:33 AM
01/18/15 01:33 AM
Thanks for the help, Mike
Re: Vacume pump users, do you see water vapor? [Re: cudadon] #1724412
01/18/15 01:49 AM
01/18/15 01:49 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Thanks, Don
Sorry just saw the post...its 1/8 npt to around 1/4 hose. Like the co2 or air brake style. It was leftover from my PPP air shifter. You can buy this stuff at any local hose supplier.
