Re: Vacume pump users, do you see water vapor?
[Re: MR_P_BODY]
#1724406
01/08/15 07:43 PM
01/08/15 07:43 PM
Posts: 916 SE Washington
Forest
SE Washington
It IS PRETTY... one thing... that vac line sure is small... we are playing with a FAIR bit of volume
That is the vaccum line to the racepak sensor...the suction line to the pump is a -12 in the valve cover.
[Re: Forest]
#1724407
01/08/15 07:47 PM
01/08/15 07:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok.. got ya... thats much better
[Re: Forest]
#1724408
01/11/15 07:45 PM
01/11/15 07:45 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Moisture is normal for me too...you can see my vacuum line fitting in the valley plate.
Forrest what size is that push lock fitting you use for vaccum? Where did you get it? Thanks, Don
[Re: MR_P_BODY]
#1724409
01/17/15 05:47 PM
01/17/15 05:47 PM
Posts: 43,204 Bend,OR USA
Cab_Burge
I finally remember to take a picture of it, the system, after getting it mounted and working Forgive the Okie way of trying to temporalily hook a vacume gauge up to the bypass valve to set it:o I will buy a vacume gauge and hook it up the proper way
[Re: Cab_Burge]
#1724410
01/17/15 06:08 PM
01/17/15 06:08 PM
MR_P_BODY
For testing purposes if you have a dip stick I just pull the stick and clamp a hose to the tube and to the gauge.. later I mount the point permanently, usually in the back of the valve cover so its out of the way
[Re: MR_P_BODY]
#1724411
01/18/15 01:33 AM
01/18/15 01:33 AM
Cab_Burge
Thanks for the help, Mike
