Re: How do I fix this?
[Re: D149]
#1724158
01/08/15 10:37 AM
01/08/15 10:37 AM
Posts: 5,337 the house on the left.
cogen80
I want to avoid pulling the K-frame if possible so I don't have to get an alignment after the work is done.
just take the ride height measurement so you know where to set it when done.. should be able to pull the k-member without messing with any alignment adjustments.
[Re: D149]
#1724160
01/08/15 06:57 PM
01/08/15 06:57 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
I decided to cut the steering box mount while keeping the K-frame on the car. The following pics are the repair. Sorry for the multiple posts, but I don't know how to post more than 1 pic per post.
1st. Cleaned up.
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
[Re: D149]
#1724162
01/08/15 06:59 PM
01/08/15 06:59 PM
D149
Ontario, Canada
The remnants of the original bolt.
[Re: D149]
#1724163
01/08/15 07:00 PM
01/08/15 07:00 PM
D149
Ontario, Canada
Cleaned up, ready to weld a new nut on.
[Re: D149]
#1724164
01/08/15 07:01 PM
01/08/15 07:01 PM
D149
Ontario, Canada
New nut held in place. It would have been nice to use the steering box to ensure the nut was in the right place, but then it would have been in the way for welding.
[Re: D149]
#1724165
01/08/15 07:02 PM
01/08/15 07:02 PM
D149
Ontario, Canada
Tacked in place so I could test fit the box.
[Re: D149]
#1724167
01/08/15 07:04 PM
01/08/15 07:04 PM
D149
Ontario, Canada
Finished welding the nut. I couldn't weld all the way around the nut, but almost. I think it should be strong enough.
[Re: D149]
#1724168
01/08/15 07:05 PM
01/08/15 07:05 PM
D149
Ontario, Canada
Original piece of metal ready to be welded back on.
[Re: D149]
#1724171
01/08/15 07:13 PM
01/08/15 07:13 PM
Posts: 4,814 Castlegar, BC, Canada
That AMC Guy
Great work! Just coat your new bolts in some heavy anti-seize or even dip 'em in gear oil. Never have that happen again!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
