my old set up was
.040 340 block
eagle 4340 crank and h beems
11.5:1 wisecos flat tops
compuflow stage 2 edl.s comp 999 springs
265cfm@600victor intake
.673 lift 269/273@.050 dur. comp cam
1000 cfm hp 4150 holly carb tti headers full exhuast 3inch with x pipe drive to and from track
3.91 gears 28 inch tire
made 420 to the wheels ran a best of
11.112@122mphon motor
10.37@135 on spray
on 255/60 drag radial with flat steel hood hood
new old compo was same short block but with a full port 360-1 head flowed
325cfm@700 and a 3.55 gear
best motor
10.94@124 no traction
best spray
10.40@135 with less spray no traction
new new compo simease 48* r3 block with a 88 mil turbo and same heads in the works
lots of small block stuff for sale
now
