Re: Rack& Pinion Fab/Install [Re: JERICOGTX] #1721756
01/19/15 03:28 PM
01/19/15 03:28 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
2:
Re: Rack& Pinion Fab/Install [Re: JERICOGTX] #1721757
01/19/15 03:30 PM
01/19/15 03:30 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
K member:
Re: Rack& Pinion Fab/Install [Re: JERICOGTX] #1721758
01/20/15 09:40 AM
01/20/15 09:40 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Nicely done Jeff.
Your K member is similar to the one I made for the Cuda.
Used the original ends and tube between.
For street use the fabbed steering arms may need to be stronger?
I have been busy and have a few more pictures of the nearly finished assembly coming up. ....
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721759
02/14/15 12:11 PM
02/14/15 12:11 PM
N.E. Ohio
N.E. Ohio
Pretty much finished.
Prep and paint.
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721760
02/14/15 12:12 PM
02/14/15 12:12 PM
N.E. Ohio
N.E. Ohio
19
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721761
02/14/15 12:14 PM
02/14/15 12:14 PM
N.E. Ohio
N.E. Ohio
18
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721762
02/14/15 12:14 PM
02/14/15 12:14 PM
N.E. Ohio
N.E. Ohio
17
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721763
02/14/15 12:17 PM
02/14/15 12:17 PM
N.E. Ohio
N.E. Ohio
15
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721764
02/14/15 12:18 PM
02/14/15 12:18 PM
N.E. Ohio
N.E. Ohio
14
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721765
02/14/15 12:22 PM
02/14/15 12:22 PM
N.E. Ohio
N.E. Ohio
12
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721766
02/14/15 12:23 PM
02/14/15 12:23 PM
N.E. Ohio
N.E. Ohio
11
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721767
02/15/15 01:45 AM
02/15/15 01:45 AM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
Very nice work!
Can't wait to see all painted and complete!
Mike
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721768
02/22/15 03:47 PM
02/22/15 03:47 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Looks nice Dennis. Will you have it out this summer.
Ok
Re: Rack& Pinion Fab/Install UPDATED [Re: cudatom] #1721769
02/23/15 09:24 AM
02/23/15 09:24 AM
N.E. Ohio
N.E. Ohio
Thanks Tom.
I hope so. Have a lot to do yet.
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721770
03/01/15 10:07 PM
03/01/15 10:07 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
STOP NOW. The stock ball joint steering arms will not work when reversed. It has to do with Ackermann. Ackermann causes the inside tire to turn a tighter radius than the outer tire. When the arms are reversed inner tire now toes in (toward the outer tire). Serious scrubbing will result in poor handling while turning and extreme tire wear. The outer tie rod location must also form a parallelogram when viewed from the front. The 4 corners being the lower control arm pivot, inner tie rod, outer tie rod, and lower ball joint C/L.
Read about ackermann here.
http://en.wikipedia.org/wiki/Ackermann_steering_geometry.
Any questions,please ask.
Doug
Re: Rack& Pinion Fab/Install UPDATED [Re: dvw] #1721771
03/02/15 09:04 PM
03/02/15 09:04 PM
N.E. Ohio
N.E. Ohio
Yes Doug I see what you are talking about.
To get Ackerman with front steer the tie-rod outer pivot needs to be outside the lower balljoint pivot.
On rear-steer its inside.
So I will probably end-up making custom steering arms like Jeff did. They are going to be kinda short compared to stock in order to get them outside the lower b-joint.
Thanks for the heads-up.
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721772
03/03/15 01:45 AM
03/03/15 01:45 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I met a guy who did a Cavalier like this once. It killed the tires. I'm sure there are few threads around about fabricating steering arms. You might want to contact Bondo Bob.Good it's caught now instead of latter. Good luck
Doug
Re: Rack& Pinion Fab/Install UPDATED [Re: dvw] #1721773
03/03/15 08:02 AM
03/03/15 08:02 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
To get proper Ackerman you need to string the car from the rear end centerline, through the lower ball joints, and then make the steering arm/Rack hiems mounting location to hit on that line.
69 GTX 68 Road Runner
Re: Rack& Pinion Fab/Install UPDATED [Re: JERICOGTX] #1721774
03/03/15 09:12 AM
03/03/15 09:12 AM
N.E. Ohio
N.E. Ohio
Yes.
Re: Rack& Pinion Fab/Install UPDATED [Re: 6bblFLASH] #1721775
03/07/15 12:42 PM
03/07/15 12:42 PM
N.E. Ohio
N.E. Ohio
Did some digging around and took some measurements.
I am going to use screw in Qa1 ball joints and make my own steering knuckles then I can put the tie rods where I want.
Probably not going to touch the the ground for a long time.
Might be mid summer till I get back on it.
It stinks getting old. I need more repairs than the car LOL
