Scored another peice for the stroker!
#1721169
01/04/15 12:59 AM
01/04/15 12:59 AM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I was lucky to get a BRAND NEW complete 6.4 intake including fuel rails, injectors, and throttle body. Brand new, never run. The pile of parts is starting to get bigger, I am down to needing pistons, machine work,(or block, if MA Mopar produces more 6.1s) control box and the usual replacement parts for a build, like bolts, timing chain, some gaskets,oil pump, etc. If the blocks are scheduled to be released as promised on the 8th of this month, I have one on order. If not, I hope to find a nice 6.1 block to work with. Tha would give me 402+ cubes with the 3.888 crank.
Re: Scored another peice for the stroker!
[Re: gregsdart]
#1721172
01/05/15 03:42 AM
01/05/15 03:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I couldn't figure out a way to run the two fours without cutting the hood. I decided it would be nicer to have the original hood as is and also the fuel injection advantage. I here the FI with the variable runners is worth a bunch of mid to low rpm torque, which doesn't hurt my feelings either. The price on the FI intake was very good. I hope I can return the favor to the seller some day
How is the variable runner intake operated.. is that a vac thing or a elec motor
[Re: MR_P_BODY]
#1721173
01/05/15 12:17 PM
01/05/15 12:17 PM
gregsdart
The manifold runners can be switched by an rpm switch, or a computer if it is capable. There are variable runner intakes in polymer that are a copy of the 6.1 barrel intake as well, I think they come from newer truck 5.7 motors. These have a straight intake rather than the slanted one on the 6.4 intake.
[Re: gregsdart]
#1721174
01/06/15 12:08 AM
01/06/15 12:08 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Overall probably the smarter way to go unless you run a scoop and a big coin wet intake like the Drag Pak or a Hogan.....
[Re: gregsdart]
#1721175
01/06/15 01:49 AM
01/06/15 01:49 AM
MR_P_BODY
I was thinking the RPM switch also... but does the door open with a elec motor or a vac motor
[Re: gregsdart]
#1721176
01/06/15 03:17 AM
01/06/15 03:17 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
It was good talking to ya about your project the other day Greg. I hope that lump plays out well for you. I am trying to get my son to buy his Dragpack manifold now while he is thinking about it.
"Just a Bracket car dressed up like a streetcar"
[Re: MR_P_BODY]
#1721177
01/06/15 10:58 AM
01/06/15 10:58 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Electric
[Re: MattW]
#1721178
01/06/15 01:14 PM
01/06/15 01:14 PM
MR_P_BODY
Electric
Thanks.. just trying to figure out some ideas
[Re: MattW]
#1721180
01/06/15 08:28 PM
01/06/15 08:28 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
