Re: chamfered bearings????
[Re: sixty7gtx]
#1720482
01/08/15 04:08 PM
01/08/15 04:08 PM
Posts: 8,353 fredericksburg,va
cudaman1969
fredericksburg,va
Last i checked the s/s Hemis are running Mercedes, maybe Honda, bearings, very small and narrow. It would depend on the rod-piston weight-rpm plus good oil film. I would never worry about chamfered bearings
Thank you for your message!!!!!!!!
I take care of my Engine. Never beat on it. I have approx. 1000 miles on my motor. I put brad penn oil in it. What do you think of synthetic oil???
Synthetic oil as it gets older goes to the higher viscosity, reg oil goes to the lower(10w30). I add the STP zink to my older diesel Mercedes, Dakota gets 0w30 syn, Mobil diesel oil for the cummins. Mustang GT 500 uses 0w50. Was running Mobil 1 in race car,might change?
