Re: too cold to adjust the valves?
[Re: Thumperdart]
#1720290
01/02/15 05:00 PM
01/02/15 05:00 PM
Posts: 4,179 California
mickm
California
I always set em cold but should make no difference that matters. I set my solid roller cold at .014 and end up w/about .020 and it calls for .026 hot so,...........
was just referring to the possibly 20 ambient degrees colder than when i usually set them.
maybe i should just do the smart thing for my fingers and wait until spring...
[Re: Thumperdart]
#1720292
01/02/15 05:18 PM
01/02/15 05:18 PM
mickm
California
I know what you meant and that`s my reason for the tighter than "recommended" clearances not being an issue............
got it dom, thanks!
[Re: Crizila]
#1720297
01/02/15 08:01 PM
01/02/15 08:01 PM
mickm
California
I don't even go in the garage when it's that cold.
well, i may not, depending on just how cold it is!
[Re: mickm]
#1720298
01/02/15 08:23 PM
01/02/15 08:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wouldnt even consider the difference of 20*.. set them the same as you would in 70* weather... the small amount that you would see wont matter.... but I keep my shop at 64* all through the winter if I am going out there... if I'm going away I turn it down to 50* (hot water heat in the floor)
[Re: mickm]
#1720299
01/03/15 12:07 AM
01/03/15 12:07 AM
Posts: 75,280 A gulag near you.
JohnRR
A gulag near you.
I would love it if COLD in my garage was 50 ... it's in the 20's right now ...
[Re: JohnRR]
#1720300
01/03/15 12:16 AM
01/03/15 12:16 AM
mickm
California
yeah, i know. i got it pretty good here weather wise.
valves all adjusted and buttoned up!
[Re: mickm]
#1720301
01/03/15 12:26 AM
01/03/15 12:26 AM
Posts: 43,734 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#1720307
01/04/15 01:32 PM
01/04/15 01:32 PM
Posts: 2,686 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Why do people check lash without putting heat in the motor?
You need to set themn cold before you can start the motor , correct?
It may be a poor comparison, but, All of the motorcycle engines (Japanese) that I have adjusted valves on specify it is to be done cold. So, I think ,that once you know the difference between your hot and cold lash, cold would be fine?
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1720308
01/04/15 01:43 PM
01/04/15 01:43 PM
MR_P_BODY
Mark
On the first time around on a new engine I check cold and hot to get the difference.. from there I always set it cold.. I dont need to burn myself anymore... I set all my stuff on the tight side anyways
[Re: Bigcube]
#1720311
01/04/15 02:22 PM
01/04/15 02:22 PM
Posts: 12,807 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
On my iron block engines, I have not noticed much variation in the difference between the hot and cold gaps. In other words, the difference was consistent. But on my aluminum block engine, there is enough variation in the cold gaps that I don't trust it. So I set my iron block gaps cold, but my aluminum block only gets set hot.
Master, again and still
