Re: what all is involved in lifting a wrangler 4-6 inches? [Re: NITROUSN] #1718630
01/03/15 01:09 AM
01/03/15 01:09 AM
the house on the left.
cogen80 Offline
cogen80  Offline
We lift a lot of jeeps and I own one myself. I hate body lifts and with that being said here is my advice. 97 to 2006 TJ models ride and work real well with a lift. Your factory springs are most likely getting weak and not to OEM height anymore. So 4 new springs and shocks will do the job nicely. 3 to 4 inches will give you the best bang for your buck. Going over 4 inches will cost a lot more and you make a lot of durability and reliability compromises. I like BDS and Zone lifts. So 3 to 4 inch lift. Get a slip yoke eliminator and a cv rear shaft. That way the skid plate will stay stock height and you wont have to modify the 4wd linkage or have stiff shifting if a manual due to shift boot interference.
this is the best advise posted. listen to him. he is dead on.
i know a few guys running the 4 cyl. they have had good luck with them. just have to gear them.
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: Cooter] #1718631
01/03/15 05:29 AM
01/03/15 05:29 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 33" tire line is poppycock.
Okay, YOU know everything. I guess we should just PM you directly for every question from now on.
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: Kern Dog] #1718632
01/03/15 07:03 PM
01/03/15 07:03 PM
bethlehem pa
mikemee1331 Offline OP
bethlehem pa
this site is the best and i'm glad to see this forum is no different than the other ones !
keep in mind that he wants the look but will never actually do any off-roading. that said here is what I've learned from here and a few other sites. either TJ or YJ is fine. i'm good with leaf spring suspension but the coil spring would be newer and probably more plentiful with the added plus of finding one that is just someones daily driver. straight six is what I should look for but a 4 banger might be ok for his use. 33's could present a problem with steering radius and might require a gear change but a 2 inch lift (not body) would be plenty. 31's are probably all he needs to achieve the 'look'. am I on track?
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: Kern Dog] #1718633
01/03/15 08:36 PM
01/03/15 08:36 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Probably not everyone, but YOU might want to before you believe your "axle guy"
My photos are up there, those tires sure seem to be bigger than 33".
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: mikemee1331] #1718634
01/03/15 08:40 PM
01/03/15 08:40 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
He may not be satisfied with the look of 31" tires. But if he is, he can run them on a street driven TJ without a lift, as long as the springs aren't shot. With the correct back spacing, his steering radius shouldn't suffer.
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: Cooter] #1718635
01/03/15 09:16 PM
01/03/15 09:16 PM
Lehigh Acres, Florida
rickstershemi Offline
I mounted my Wrangler 31'S on the stock rims (2001 Sport) and they fit with Zero Rub
Rickster
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: mikemee1331] #1718636
01/03/15 10:12 PM
01/03/15 10:12 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
forget the yj, get a tj. then, look up lift kit.
because of the coil springs or an aversion to square headlights? I kinda answered my own question about lifts by reading inspection codes. now i'm still curious about engines. I understand the straight 6's are easier to work on but what about the 4 cyl? are they just underpowered even with a manual?
yes, to both. get a rubicon tj, and be done with it.
the 4.0 is the engine to go with, along with the manual trans. the 4 cylinder is a slug. you'll burn more gas with it trying to roll larger tires, and you'll have no power. if you go with the 4, you'll soon want the 6. save yourself the aggravation.
just a quick skyjacker 4" lift kit. comes with everything, rolls on 33's with no problems. took a full day to install, in the driveway with no special tools.
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: Golden-Arm] #1718637
01/04/15 04:45 PM
01/04/15 04:45 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
No one has mentioned it, but it would depend on the OP's kid's maturity level as to whether or not the kid should have a 4 or 6 cylinder. Some teenagers should drive under powered vehicles!
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: QuickDodge] #1718638
01/04/15 08:18 PM
01/04/15 08:18 PM
bethlehem pa
bethlehem pa
very true! he's more into the 'sexiness' part than the tearing up the streets and yards part!
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: mikemee1331] #1718639
01/04/15 10:54 PM
01/04/15 10:54 PM
A 4-Banger Sport with stock tires will run 90 on the interstate
Rickster
Re: what all is involved in lifting a wrangler 4-6 inches? [Re: QuickDodge] #1718640
01/05/15 01:13 AM
01/05/15 01:13 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Drive a lifted 6 banger jeep with big tires. A hot rod they are not. Even with stock tires...
