Re: 512 stroker build, need suggestions
[Re: dave73chally]
#1717854
12/31/14 10:55 PM
12/31/14 10:55 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Yea I agree, lower compression kit is better for my needs. All things being equal other than piston dome cc, how much of a power decrease will I see between 10.5:1 CR and 10:1 CR?
I think the CR difference is closer to 0.8. Like 10.6:1 verses 9.8:1.
If you are worried about it, and you are going with a smaller cam, go with the bigger dish.
[Re: JohnRR]
#1717856
01/01/15 12:25 PM
01/01/15 12:25 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Awesome, thanks guys. Here's what the basics of my build is going to look like, what do you think?
-512 stroker (440 @ .055 over) -27cc dish, 4.250 stroke, 7.100 rod - Holley Street dominator Intake - 850-950 carb - 440 Source Stealth heads (80cc) - Lunati 60312 .535/.550 lift, .231/.239@.050,.283/.290 advertised, 110 lobe sep, Rpm 2200-6200 - 1.5 comp pro magnum rockers
I think you should stop second guessing your engine builder.
Roger that!
If you cannot trust your engine builder to design your engine......you need to find another engine builder.
I'm suprised he hasn't told you to kiss off.
