Re: Finally my 544 stroker 6 pak, can't wait .....
[Re: Porter67]
#1717413
01/05/15 02:31 AM
01/05/15 02:31 AM
Posts: 126 Oregon
Jamie McGrath
What is the height and width on a oem intake and what do you end up after gasket/intake matching.
I have more to add but would like to know the specs prior to sticking my foot in my mouth.
The intake is as wide as any other 440 intake I don't think that matters much, or does it? But its 5.63in tall, the intake port openings should be 1.10 wide X 2.12 tall stock. If that helps you any?
I can see opening them up for a gasket match and then reaching as far as you could get inside, but what about the areas you can't reach? And doe's Extrude Hone really work?
[Re: JohnRR]
#1717414
01/05/15 11:19 AM
01/05/15 11:19 AM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
I didn't mean to take this thread in the direction it has gone, there may be a few more ponies in it but the real test is once it's in the car and running.
I haven't seen the dyno sheets but I assume the AFR was close to being correct or it wouldn't have come off the dyno.
Thank you John, and of course there is final tuning to be done ONCE IT IS IN the 3400lb car, thank you for those that were happy for me, i have my machine shop that i TRUST 110% and would go no place else, reason i shared early is because i first tried a motor shop in delray with a guy named Dan, he took all my parts and $6000,was lucky to get most of my parts back, Dan nearly wiped me out. Direction this turned was not what i expected,pull a motor out 2/23/14,lose half your parts, Dan's family keeps my cash "saying good luck" another builder grabs most of my parts from Dan's shop, and He screws me for $50000, telling me motor is almost ready to be dyno tested, October i go to shop in florida, all my stuff still in the newspaper and boxes i sent to DAN, so took my stuff finally back home, lost a total of $8000, and a few thousand more in parts that got left at Dan's. So now i post to share what has me happy as hell, i had to by more parts and pay for the third time, and This machine shop got it right EXACTLY what I WANTED.The tune obviously will be tweeked once it is back running in my car.So thanks to those who supported my happyness, i'm not a rich man, and two builders took me for a ride, Dan's money i will be paying back in my 401k for the next 3 years his brother Tim said i will never see that money again, Fat Brian at palm beach auto,forked over most of my money when i flew to his shop and physically made him pay me back, as i shipped my parts back to MASS. My Machine/builder built me just what i wanted, and I'M HAPPY,Thanks to the few moparts buddy's i got that didn't rain on my excitement
[Re: Mr.Yuck]
#1717415
01/05/15 12:01 PM
01/05/15 12:01 PM
Posts: 75,136 A Banana Republic near you.
JohnRR
now I know why my buddy asked me "are you going to work the intake before you put it on?" are they really that bad? How much more can you pick up? Mine is right out of the box.
Bad, no, but there is only so much you can get out of them, that's why the Weiand manifold exists for an all out race effort.
Anything you can do to clean up the flow is going to help, they at a certain point it becomes a cork, on a motor like what you have, no.
[Re: Dunnuck Racing]
#1717417
01/05/15 12:26 PM
01/05/15 12:26 PM
JohnRR
I have a fairly hot street 440 build in the shop that is getting a Six pack. I plan to do some flow testing and porting to go along with the porting on the RPM heads I will be doing.. I can post some results if it will help anyone Keith
It would be good to see the results ...
There are times I wish I had access to a flow bench to test out a couple of intakes I've picked up over the years to bolt them on a head and see what kind of change they cause to intake flow .
