Re: 70 Big Block Challenger [Re: 70BigBlockSE] #1716646
02/01/15 12:29 AM
02/01/15 12:29 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
about 1 1/2" from top of carbs to the underside of the hood scoop
EFI is shorter than carbs!
P.S. I like your intake. Is this a street car or for race?
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: 70 Big Block Challenger [Re: 68cuda440] #1716647
02/01/15 12:37 AM
02/01/15 12:37 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
With a highly modified fiberglass six pack air cleaner assembly.
Re: 70 Big Block Challenger [Re: 68cuda440] #1716648
02/01/15 12:41 AM
02/01/15 12:41 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
It barely clears the hood.
Re: 70 Big Block Challenger [Re: 68cuda440] #1716649
02/01/15 12:44 AM
02/01/15 12:44 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
And this is in an A-body, which has less room than the B/E cars.
Re: 70 Big Block Challenger [Re: 68cuda440] #1716650
02/02/15 02:27 PM
02/02/15 02:27 PM
Jacksonville Fl
70BigBlockSE Offline OP
Jacksonville Fl
this will be all street.
Re: 70 Big Block Challenger [Re: 68cuda440] #1716651
02/13/15 09:58 AM
02/13/15 09:58 AM
Jacksonville Fl
Jacksonville Fl
doing fuel injection with that manifold gets rid of allot of the drawbacks it has. Do you have it running yet?
Re: 70 Big Block Challenger [Re: 70BigBlockSE] #1716652
02/13/15 11:43 AM
02/13/15 11:43 AM
Central US
grancuda Offline
grancuda  Offline
Central US
Just make/stick some 3/4" spacers to go between the sub-frame & K-member & then you shpuld be fine.
Re: 70 Big Block Challenger [Re: grancuda] #1716653
02/14/15 12:23 PM
02/14/15 12:23 PM
Jacksonville Fl
Jacksonville Fl
got most of the wiring done in the engine compartment, although I want to hide the changes the Denso alternator and ready to run distributor will require. Still need the wiper motor but it should be here this month. Next weekend I'll jack it up and start exhaust, brake and fuel lines
Re: 70 Big Block Challenger [Re: 70BigBlockSE] #1939723
10/27/15 02:56 PM
10/27/15 02:56 PM
Jacksonville Fl
Jacksonville Fl
got the exhaust and driveshaft loop. I won't make the November Garlits show unfortunately.
Re: 70 Big Block Challenger [Re: 70BigBlockSE] #1939791
10/27/15 05:17 PM
10/27/15 05:17 PM
Maryland
K
Keepat Offline
Keepat  Offline
K
Maryland
That's some big pipes! Who's exhaust system are you using?
Pat
Re: 70 Big Block Challenger [Re: Keepat] #1939958
10/27/15 09:43 PM
10/27/15 09:43 PM
Jacksonville Fl
Jacksonville Fl
TTI 3", gotta let the 493 get the air out!
Re: 70 Big Block Challenger [Re: 70BigBlockSE] #1980699
12/31/15 10:00 PM
12/31/15 10:00 PM
Jacksonville Fl
Jacksonville Fl
Happy New Year, no work today so I spent some quality garage time. After mich measuring the 3" air filter fits
Re: 70 Big Block Challenger [Re: 70BigBlockSE] #1997579
01/24/16 10:48 AM
01/24/16 10:48 AM
Jacksonville Fl
Jacksonville Fl
fuel line is done, just need to hook up the filter to the pump. By Florida standards it was cold in the garage working, about 50.
