Re: Sub frame connectors [Re: 68cuda440] #1714719
12/28/14 09:01 PM
12/28/14 09:01 PM
GA
roadrunninMark Offline
GA
Would bolt on aluminum work as well instead of steel? I know they can be heavy, was thinking if you were going to make them, what about aluminum?
Re: Sub frame connectors [Re: roadrunninMark] #1714720
12/28/14 09:33 PM
12/28/14 09:33 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
You could but for the same size tubing, you'll have a subframe connector that is about half as weak (depending how the metal is prepped). Not only that, but generally aluminum cost more than steel. Even butting to dissimilar metals next to each other is generally not preferred.
Re: Sub frame connectors [Re: roadrunninMark] #1714721
12/29/14 12:04 AM
12/29/14 12:04 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
I'm counting the days until we start hearing reports about fatigue cracks in the now defunct XV welded K frames. Enough said.
I'm with Helmuth Hübener, and no soup is being served today.
Re: Sub frame connectors [Re: jcc] #1714722
01/02/15 06:25 PM
01/02/15 06:25 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
I work with high-performance aftermarket parts daily and the range of quality reminds me of my Dune Buggy days in the 80's. Can't believe what people try to sell and what people continue to buy.
`68 Barracuda 340-S
Re: Sub frame connectors [Re: FASTBACK340] #1714723
01/06/15 04:41 PM
01/06/15 04:41 PM
Dr Dave Offline OP
Dr Dave  Offline OP
I have decided to go ahead with the fully welded to the floor pan style and repaint the bottom. I'm sure I will be much happier and what the heck, it's only $$! Thanks for everyone's input.
Re: Sub frame connectors [Re: Dr Dave] #1714724
02/25/15 10:39 PM
02/25/15 10:39 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Hotchkis set showed up today, it will be a while before thereoj
Re: Sub frame connectors [Re: TC@HP2] #1714725
02/26/15 12:51 AM
02/26/15 12:51 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Mopars are so bendy by this stage of their life that even simple 1x3 units welded to just the front and rear sub frames are a HUGE improvement over nothing. Are they the ultimate, no, but they are a big step in the right direction. Quite worrying about it and put them in.
This guy gets it. I spent $50 on materials and a couple hours making it fit(I am by NO means a fabricator)and they made $500 difference! Don't over think it...tie them together and done!! You'll be glad you did!
Re: Sub frame connectors [Re: FASTBACK340] #1714726
02/26/15 04:17 PM
02/26/15 04:17 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
People can afford to DRIVE an XV car?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Sub frame connectors [Re: astjp2] #1714727
03/03/15 03:48 PM
03/03/15 03:48 PM
dogdays Offline
dogdays  Offline
Thing to remember about aluminum is NOT the tensile strength, it's the modulus of elasticity. That is another way of saying spring constant, if that helps explain. Aluminum has a modulus of elasticity of around 1/3 that of steel. That means for a given amount of stress, the aluminum will deflect three times as much as steel. So to get the same stiffness, the aluminum part has to be three times as thick or whatever dimension matters most. That partially negates the weight savings.
This has nothing to do with strength, which is generally how much stress before permanent deformation.
If using aluminum I'd be much more worried about how to get a decent weld than the effects of dissimilar metals on corrosion.
R.
Re: Sub frame connectors [Re: dogdays] #1714728
03/04/15 01:51 AM
03/04/15 01:51 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
R.
I would actually be more worried about life and fatigue. Steel is fairly straightforward. If you design the load below a given threshold the life is functionally infinite. Aluminum has no such threshold. That is why aluminum parts on air frames are replaced on a schedule. I have never designed with aluminum for service life (steel - yes), so maybe the Corvette engineers know something I do not. Just not so comfortable with an aftermarket aluminum frame. The life testing and level of vetting the OEMs do is not really attainable for aftermarket suppliers.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Sub frame connectors [Re: 68cuda440] #1714729
03/04/15 03:40 AM
03/04/15 03:40 AM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
Anybody try these? US Cartools Bolt in Sub Frame Connectors It looks intriguing, albeit pricy....
Dan
Re: Sub frame connectors [Re: Dans 68] #1714730
03/04/15 09:10 AM
03/04/15 09:10 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Anybody try these? <a href="" target="_blank"></a> US Cartools Bolt in Sub Frame Connectors It looks intriguing, albeit pricy....
Dan
Read this first
https://board.moparts.org/ubbthreads/showflat.php?Number=7904856
Don't be the exception.
Re: Sub frame connectors [Re: Supercuda] #1714731
03/04/15 08:16 PM
03/04/15 08:16 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Dan
Read this first
I've talked to them fairly recently and expressed concern about their previous history. I was assured things were on the up and up. With their eBay store and being able to pay with PayPal, buyers should be fairly covered going that route.
Their Ebody chassis stiffening package is tempting..Chris Lewis is whom I was speaking with.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Sub frame connectors [Re: GoodysGotaCuda] #1714732
03/04/15 08:21 PM
03/04/15 08:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, I dunno if they took care of the guy in the linked thread, but I felt the OP needed to know what he might be getting into.
Re: Sub frame connectors [Re: Supercuda] #1714733
03/04/15 08:22 PM
03/04/15 08:22 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yep, no doubt. I haven't spent any money with them, so I can't say one way or the other.
2020 RAM 1500
Re: Sub frame connectors [Re: GoodysGotaCuda] #1714734
03/04/15 10:10 PM
03/04/15 10:10 PM
Saint Peters, MO
Brian Offline
Brian  Offline
Saint Peters, MO
I've installed the entire chassis stiffening kit on my Duster. No issues with the purchase or installation.
1971 6.1 Gen III Hemi Duster
Re: Sub frame connectors [Re: GoodysGotaCuda] #1714735
03/20/15 07:47 PM
03/20/15 07:47 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Ordered Sunday, showed up today.
